Question about Dolphin 7600 Barcode Scanner
Dolphin® 7200 RS-232 Mobile Computer
Were can I find a manual for the Dolphin 7200
RunCo VX1000c RS-232 communication codes
Hi Kevin,
The manual for the RuCo VX1000c is available at http://www.aboutprojectors.com/pdf/runco-vx-1000ci-manual.pdf
The RS232 codes and protocols are towards the back of the manual. According to the manual, the PFP connects to the projector using a CAT5 cable.
HTH.
Jan 02, 2013 | Office Equipment & Supplies
Heena has only rs 2 and rs 5 coins,in her purse. if in all she has 80 coins in her purse amounting to rs 232. find the number of rs 5 coin.
Is this a maths school problem?
You need to use algebra -
2x + 5y = 232 (heena has a number of 2 and 5 coins in her purse which add up to 232)
x + y = 80 (heena has x number of 2 and y number of 5 coins which tally to 80)
therefore, x = 80 - y
so going back to first equation, 2(80 - y) + 5y = 232
160 - 2y + 5y = 232
3y = 72
y = 24
and going back to x, x = 80 - y
x = 80 - 24
x = 56
so heena has 56 rs 2, and 24 rs 5. So the answer is 24.
Jan 26, 2011 | Computers & Internet
Can't get the PC to display on a TV through the RS-232 interface.
You can not connect a monitor to an RS-232. If your video card does not have a monitor output, you cannot connect a tv monitor to your computer... and the fact that it only shows the original monitor on the drop down menu tells me you can't add a TV to your system
Mar 18, 2010 | Acer Aspire 3000 Notebook
Can we use IR Insted of RS 232 to control the HDX 7001 XL Model Pls replay
my passport key no:6800418409 plese give the passport photo copy pls
Feb 16, 2010 | Polycom HDX 7001 XL Video Conference...
Dolphin 7200 Scanner won't power on
try holding down 7 and 9 then power on + shft + bksp
simultaneously then release 7 + 9 first. Let me know how you get on.
Jun 25, 2009 | HHP Dolphin 7200
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
Pansat 2500a FTA receiver
I would suggest to go here to get a lot more info on how to program this receiver.
Feb 22, 2008 | Televison & Video
Rs 232
try unplugging and uninstalling the rs232 and reboot then turn off then plug the cable back in and turn on. it should detect and install.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/stephen_171aeeebef53a898
Oct 28, 2007 | HP (158800-001) for Compaq Presario 1246,...
Dolphin 7600 Barcode Scanner Logo
291 people viewed this question
Top Dolphin Computers & Internet Experts
matt
matt
NOEL
NOEL
ray gallant
Are you a Dolphin Computer and Internet Expert? Answer questions, earn points and help others
