Question about Sector 3251908015 Mountain Master watch
It`s not working
I felt down while skiing with my watch in the pocket but the watch didn`t hit the ground and it stoped working
Try pressing all buttons at the same time and hold it for 5 seconds to reset the watch.
See if this trick works?
Posted on Feb 23, 2009
If the stem does not lock in, will it still be waterproof?
You need to get out your jeweler's loupe (best at 5x & 10x)... and look for the threads to "*****" (ski-rue) down your winder-stem (not a lock).
(Features a Ski-rue down crown & back case)
YOU can pretty much be assured that if the "stem" collar is malfunctioning (broken) the "water-proof" element is compromised (that's most likely the least of your troubles).
More importantly... if the STEM does not properly "tighten" it can
cause further damage against gears which MUST align with it... further it can come all the way out and be lost... Not an inexpensive part.
Best direction would be to get it serviced by an authorized agent.
TAG Heuer Aquaracer 500M Quartz Mens Watch WAJ1110 BA0870
TAG Heuer Aquaracer WAJ1110 BA0870
Jaxa style Suissetek XL Wrench Case Opener for Large Screwback Watches
Mar 30, 2016 | Tag Heuer Aquaracer Quartz WAJ1110.BA0871...
Changing the battery in a mickey mouse pocket watch
The first answer is a canned answer. Seen it before. Examine the edge of the pocket watch. Start at the stem and look for a slight gap where the back cover meets the case. It is usually at the stem side or hinge side. Once located take a strong sharp knife and carefully pry up the back cover. It should remove fairly easily. I have about 12 pocket watches and they all work the same way. Once open there may be a small screw or two holding the battery in place. You will need a precision screw driver set or a small screw driver for glasses.
682b943c-dbb9-4041-9abb-ed1a67105d52.jpg eff96e41-9266-48e7-9603-ac9206c667a0.jpg 03735b42-603a-41af-9aa7-4d445bd017dc.jpg
Jun 30, 2013 | Watches
I have a pocket watch that is engraved with 1904. It is numeric, and has a small face on bottom for the seconds. There is a sticker that states it is from The Dueber Watchcase Manufacturing Co. It states...
Didn't I just provide remarks for you on this matter?
Please take your watch to a jeweler in your torn and have it cleaned, adjusted and oiled.
Apr 15, 2011 | Watches
I have a Majestron quartz pocket watch. How do I replace the battery?
  • Flip over your pocket watch. Remove the back of your watch. The back of watches are either screwed on by four small Phillips head screws (unscrew them) or the watch has a press inserted back (slide a thin knife blade under the edge of the back of the watch and pry it off).
  • Remove the circular watch battery out of the back of the watch.
  • Take the battery to any department store or watch store and purchase a new replacement battery.
  • Insert the new battery into the back of the watch.
  • Screw on or push on the back of the watch. Set the watch to the correct time.
  • Aug 23, 2010 | Watches
    How do I adjust the length of the bracelet (watch band) for a Casio EF106D-2AV bracelet watch?
  • Select a clean, flat work surface where you can perform your watch band adjustment. Put down a piece of felt to protect the face of your Casio. Turn on a lamp near your workspace to better illuminate the watch components with which you will be working.
  • Lay your Casio face down on the protective felt. Look for the small arrows on the back of some of the watch links; these arrows indicate the removable watch links and the direction their pins should be removed.
  • Locate the pin hole above the arrow on the removable watch links. Insert the tip of a watch pin removal tool, or push pin, into the pin hole. Apply pressure to the link pin, in the direction indicated by the arrow, to free the pin and remove the link. A pair of needle-nose watch or jewelry pliers can be used to help pull out stubborn link pins. Remove as many links as necessary for your watch to fit perfectly.
  • Reserve the links and link pins that you remove from your Casio Edifice watch. Store the removed watch components in a small, clear, plastic zipper bag. These components can be used when repairing or expanding your Casio watch band.
  • WARNING:Casio recommends that customers have their watch bands sized by an authorized Casio watch dealer. Sizing the band of your Casio Edifice yourself may void the manufacturer's warranty on your watch. Contact Casio customer support for more warranty information.
  • Aug 21, 2010 | Casio Edifice EF106D2AV Wrist Watch
    Sweep second hand sticking on colibri pocket watch. How can I correct. I just had battery replaced.
    mcdevito75 here, This is a very common problem easily fixed, when the battery was change the repair prerson could have interfered with the seconds hand bending it ever so slightly so it hits the other hands or it became loose, return to the person who changed the battery, they"ll take the back off and fix that seconds hand. Remember this may be no ones fault so I don"t know about any extra charges for service on your watch. This is just my info to you.
    Jul 02, 2010 | Colibri Swiss CSQ Pocket Watch
    The digital display on my Fossil JR-7747 has gone blank. No difference even with new battery. Is there any way to get a replacement works for this model as I really like its simple lines and appearance.
    if you replaced the battery you self you didn;t ground out the dig memory. if you open up hte watch nere the battery the id a small hole in the movment with a little tiny hole and there will be and airow pointing to the hole . you need to put a small paper clip down the hole to the bottom and then touch the other end to the top of battery. that should clear the memory and you problem
    Jul 12, 2009 | Watches
    My Fossil VT2657 no longer works. I can see no physical damage, but it hasn't been used in years. I'm not even 100% sure how to wind it, but after quite a bit of winding in both directions it still...
    it has a battrey or and atomatic winding gear. watch makers a stoped self winding watches due to people over windinfg and braking the watch. check battery it might be dead. or just shake the watch back and forth untill it starts again
    Jul 12, 2009 | Fossil VT2657 Pocket Watch
    My watch has stopped working
    mcdevito75 here, Unless you have a good knowledge of takeing apart, even just the back off your watch / pocket watch it"s best to look for a small watch repair shop in your area, but here is what you can do to possibly start your watch / pocket watch. If your watch / pocket watch hasn"t been wound in some time and that time varies from watch to watch, the oil in the watch can become a bit thick so as to not allow the mechanism to work smoothly, leave the watch / pocket watch in a warm place, window sill in the sunlight wrapped in a paper towel for anywhere between a few minutes to 1/2 hour, after the watch / pocket watch has been warmed up hopefully the oil in the mechanism has liquified enough to allow the movement to start working. You can also give the movement a little boost, after the watch /pocket watch is warm, pull out the stem as if to set the time of day, move the stem and hands, sometimes this action will get the watch ticking again. If this fails, BEST BET specially if this is an expebsive or keepsake watch, look for a small watch repair shop in your area for serviveing. approx. $45.00
    Mar 19, 2009 | Colibri Mechanical Collection Pocket...
    Sector 3251908015 Mountain Master watch Logo
    207 people viewed this question
    Top Sector Watches Experts
    staicuma
    Level 1 Expert
    richie46
    Are you a Sector Watch Expert? Answer questions, earn points and help others
