If I start the car and let it idle for more than 2 minutes there is no noise but if I start driving right away she screams for a good 10 seconds
Sounds like a loose accessory belt
I am very new to mechanics where is the accessorie belt, I realized the fan is not running, I must fix that I guess to help cooling and it might be the problem... but it sounds like a belt to me
This is the belt/belts that run the altenator,a/c,p/s etc.
How can I tell if its loose ?? it seems they are all around the same tension... I know my clutch slips going up steep hills as well and the engine leeks a bit of oil, just enough to be noticeable but not enough that it drips on the ground ..
SOURCE: Same problem
throttle is probably going out you can try to clean it but they are usually bad when the epc light is on
SOURCE: intermitent high idle
Have your timing checked. Retarded timing can cause the issues you have. A quick adjustment could fix it.
how do I check the ignition timing ?
Ok so I was driving the other day and noticed it was agressively more difficult to shift, is there a way to adjust the timing in the transmission or is this going to be a little harder then that??
I checked the fuses they are all good but the fan does not run.. I am working on finding another motor for my model.. may take a while
Today I also noticed White smoke while I was driving... what does this mean?
