Question about Daewoo DVR-06
Daewoo DVR-06 turns itself off while playing back
Hi. My Daewoo DVR-06 turns itself off while playing back a movie randomly. At first I tought it had IR interference coming from fluorescent bulbs but aparently it isn't so. I've searched all over the internet and I've found descriptions of similar problems but I couldn't find the fix. Anything you can do for me? Thanx Javier Canal-Quijano
  • Glen Eden Nov 07, 2007
    Daewoo service suggested the parental control setting - didn't fix it for me
    Suggest you Email to
    service@e-daewoo.com
I have the same machine. It was randomly turning itself off 3 or 4 times during a regular 2 hour movie. In the setup menu there is an option to reset all the settings to the default original factory settings. I did so, went through the entire setup process again and my machine has not turned itself off since. I liken it to "rebooting".
Stan Lauskey
Posted on Nov 09, 2007
Microwave interferes with TV
Take one fluorescent light-bulb -- not connected to anything -- and a darkened room. Start the microwave, and see if any emissions from it activate any of the fluorescent materials inside the light-bulb.
Mar 15, 2014 | GE JVM1653 Microwave Oven
Dish remote doesn't work when tv is first turned on. After about 10 min then it will work. What is the problem. I can change channel on control panel on box itself.
You are receiving IR interference from the fluorescent bulb in your tv heating up.
The best resolution would be to contact dish to confirm if your remote can be switched to UHF or if can get one that will.
You may also try repositioning your box slightly as long as it doesn't require un hooked the cables.
Mar 01, 2014 | DISH Network Televison & Video
DAEWOO DH-6100P wont play original dvd's (from any region)
press open/pay insert disck, and close the tray.
put your password, if do not recognize your p. put oooo default password, and ready.
God bless you
Jul 14, 2012 | Daewoo DVR-06
Infared won't work unless room is brightly lit
Just to provide clarification regarding the IR remote control- unfortunately its the opposite. A brightly lit room can negatively affect the infrared signal the remote uses to transmit the signal from the remote to the receiver- additionally interference may also be caused by fluorescent lighting. Another recommendation regarding IR signal interference is to; power everything off but leave the receiver & your TV on. Then proceed by powering one component on at a time, then testing the remote after each component has successfully been turned on. This process will also help you determine if a component may be causing the interference. Hope this helps! -Kirstie DISH Network
Nov 01, 2010 | DISH Network IR Remote Control
My verizon fios remote control stop to control the 65" cinema series toshiba tv.the remote seems to be ok.The oryginal tv remote doesnt control it also.I think that there is something wron with the tv...
Yes, most likely the sensor is at fault - more precisely it's connections to the motherboard are iffy. You must take the back cover off the tv and reseat them. While you are there check their soldering points - with age they tend to melt and get loose.
Jul 28, 2010 | Televison & Video
We have a Hunter ceiling fan with a remote control, that appears to be possessed. It occasionally turns on or off by itself. What could cause this... interference from a neighbors remote?
Hi.
Usually there are jumpers inside remote circuit and on IR sensor, by changing them you will exclude the possibility of IR interference.
IR is a light signal, therefore it is highly unlikely that the problem is coming from your neioghbors, the problem looks more like a defective IR sensor on the fan, that is not a too unusual fault.
I suggest calling Hunter Ceiling at the number listed on the owners manual to see what they think about the problem.
Regards.
Mar 02, 2010 | Hunter Dryers
TW cable remote does not work after Mitsubishi LCD TV turn on
Yes, try that. It is easy to do and doesn't cost anything. You've tried new batteries in the remote as well right? There are two types of remotes, IR (Infrared light LED is used) and RF (Radio Frequency). With an IR unit I do not see any way there can be interference as long as you don't have an IR lamp around the TV and TW DVR box. On the other hand, with RF, depending on where you live and other factors, there could well be RF interference. You'll have to locate the interference and remove it. In this day and age, things such as LED and CF light bulbs DO cause RF interference. If you use these kinds of lights in the room AND you know that the remote is an RF remote then try turning all the lights off in the room and try again.
Oct 05, 2017 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
IR interference from LCD TV..on comcast dvr ...remote for dvr box will not work if i have the tv on..it a sylvania ......37" LCD HD TV model number LC370SS9
I have the same issue. I've tried every version of Comcast box there is available. Nothing. Next I'm trying taping off the Sylvania IR and running the volume through an old receiver I have. That is, of course, that there isn't a solution posted here first. Will report back later.
Jan 16, 2010 | Sylvania Televison & Video
Can't record from my digital cable tv to my sylvania dvd/vcr ..........
Depending on the unit your going to need to check the back of the DVR for video out ports... My DVR has VID/HDMI/VCR/1394/SaTa and IR ports I use the VCR out to record with... because on my DVR I can say "Play this movie... now record to VCR and it will only play the movie on those VCR ports not on my TV so all I gotta do is hit record on my VCR... As long as you have audio/video jacks on the VCR. Then even some have it blocked so you can't do that... depends on model. So try recording on the VCR using the video ports instead of the COAX cable.
May 05, 2008 | Televison & Video
Accurian ADR 3223 DVR
http://www.techolio.com/forums/phpBB2/search.php?fid[]=7
Dec 06, 2007 | Televison & Video
Daewoo DVR-06 Logo
341 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
