The primer bulb will pump up if the blower is inverted. It will not pump up if started in the normal position. After starting the blower quickly runs out of gas.
SOURCE: ryobi gas trimmer
I don't mean to over simplify this, but are you using fresh gas? Gas string trimmers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with string trimmers, and it fixes the problem 75% of the time.
Hope this helps!!
chad
SOURCE: My ryobi will start but dies about 5 minutes later
Try running the machine with the gas cap loose. There could be pressure builiding up in the system due to the cap being too tight. There is no vent on these systems like an automobile. If the gas cap is overtightened this could be your problem as the cap is equipped with a gasket that allows the vapor to vent through the cap. Overtightening could be sealing off your vent
SOURCE: ryobi ss30 weedeater not starting after repair,to the primer bulb
Follow the instructions exactly. If it won't start, take out the spark plug to see if it is wet, or dry. If it is too wet, the motor may be flooded. If it is completely dry, you have to figure out why it's not getting gas. I am assuming you are pressing the bulb the recommended number of times, and that there is gasoline in the bulb, providing some resistance to your pushes with your thumb.
SOURCE: Ryobi blower will not start unless primed by
If it is under 2 years old, I would take it to a warranty repair center. The carburetor have been giving some problems so they have needed to be replaced because they are sub standard quality.
Testimonial: "Great reply thank."
SOURCE: RYOBI RBL-30MVA 30cc when pressing the primer bulb
The diaphragm in the carb may need to be replaced. Make sure all your fuel lines are fine. On these inexpensive blowers the fuel lines tend to get brittle and crack and fall apart.
Testimonial: "thanks, will this be a costly thing to get done? will Ryobi replace the part?"
