Question about Refrigerators
Water drips into refrigerator
Water drips from freezer compartment into top shelf of fridge
  • jimcuellar Dec 26, 2008
    tborn6 good call on the pluged drain. there is no external drain tube but after removing the back panel and thawing out some ice with my plastic welder i found the drain. once the ice was gone i boiled some water and used a turkey baster to squirt hot water down the tube to finish the thawing process. thank you
  • Anonymous Mar 28, 2014
    inside fridge compartment is dripping onto top shelf
  • 700 Answers
Sounds to me that maybe your draain lin is clogged up in your freezer compartment above your refrigerator. Look for a clear tube that should be runnig down either on thre outside or on the back wall and clear it out after you make sure that its not frozen. if it is then use either a light bulb or hair dryer to thaw out. Thanks for using FixYa.
Posted on Dec 25, 2008
Hi GE top freezer fridge - 5 years old( no ice
Well for one thing that unit was manufactured 10 years ago. But it sounds like the defrost drain is clogged and the water is running down the inside of the unit. The evaporator (not condenser) is on the bottom of the freezer compartment. The bottom panel of the freezer comes out. They are a bit of a pain to do, but can be done.
Jan 03, 2010 | GE GTS22KBP Top Freezer Refrigerator
Water dripping in the refrigerator and freezes on the top shelf. It seems to be coming from the freezer compartment. There is a square piece of metal missing from the top of the main compartment. One can...
Removed everything from the freezes. Removed a false bottom from the freezer floor, 2 screws. There was an ice build up under this plastic bottom. I let the ice melt with the de-frost cycle (or frost free cycle). No more water dripping into the refrigerator compartment.
Dec 15, 2009 | Whirlpool Refrigerators
Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
Jul 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
May 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Fridge is leaking from freezer to top shelf
This is the drain tube that runs in the back of the freezer on the bottom is pluged. Take a sprayer with some hot water in it and flush out the system. Remove the food so that you dont get any of the stuff on it.
May 21, 2009 | Refrigerators
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 12, 2009 | Whirlpool ET1FTKXK Top Freezer...
Refrigerators Logo
165 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
