Question about Sony KDF-E55A20 55 in. LCD Television
SONY KDL 40 X3000 - Sound but no picture
Half screen started to go dark red/darker, then came back to normal. Now if switched on it has a shakey/ghosty picture followed a few seconds later by a dark screen.
The TV is ex-display, we've had it for two weeks, but still it did not do this at the start.
We have had satellite connection for the last week. I have checked the leads, tried the on/off technique - it is bizarre!
Appreciate any help!
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
    Problem Solver:
  • 10 Answers
Does it do this with other input devices? Sounds like a electrical surge.
Posted on Jun 18, 2017
mistersony
  • 320 Answers
SOURCE: Sony Bravia KDL-40V2500
The panel or TCON board has failed, the solution is the same replace the panel. Not worth the cost, get a new TV
Posted on Oct 18, 2008
welcomejee
  • 10594 Answers
SOURCE: HELP! KDFE55A20 watching TV and screen goes black and loses sound
Yes, its most probably lamp issue.
Please but original Sony lamp from Sony store and replace it in TV.
Posted on Mar 07, 2009
welcomejee
  • 10594 Answers
SOURCE: 60 inch wide screen sony lcd
Symptom shows its Lamp Replacement time in KDF-E60A20 TV
If you have not replaced TV Lamp yet then change it.
Lamp is available in Part Store and lamp procedure is written in User Manual.
Posted on Mar 27, 2009
welcomejee
  • 10594 Answers
SOURCE: Sony KDL-46V3000 Bravia LCD Black screen
Please count Sony KDL-46V3000 standby light blinks as there would be interval of 3 seconds between blinks. Let me know how many times light blinks as its an error code.
Posted on May 17, 2009
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
Why is sony bravia dark screen
If your TV seems to be darker than you think it should be, it is possible that the problem is with the light sensor. The light sensor will automatically adjust the picture brightness based on the ambient light that is in the room, (i.e. if the room is bright the picture will also be bright, if it is dark the picture will also be dark).
To turn this feature off go to Settings > General Setup > Light Sensor.
Feb 27, 2015 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony 52 inch bravia picture went dark
Hate to give you some bad news...But most likely you have a defective screen. You may be lucky and just have a bad T-con board. Which will do the same thing. But, this is a slim chance of it being the issue. As I have had many of these with bad screens. And only 2 were the T-con board which the color was off and pict was darker than normal. It is the board at the top center of the TV.
Apr 24, 2014 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Sony bravia kdl-40s2010 top half of screen is fading
Most sets use two boards (each drives the image on half the screen) some combine both into a single larger board but if a even half of the screen is doing something the other half is not that is where the problem likely is.
Different makers use different names for this like T-Con or Y out etc.
You if interested might Google the model number with "parts" which may provide you a list of the boards in this set along with prices in some cases.
Dec 17, 2012 | Sony Bravia KDL-40S4100 40 in. LCD TV
My Sony model KDL-40S4100 is dark. I have a picture and can see whats going on, but the screen is just not bright. I'm thinking that its the backlight, but how can I tell for sure??
The only way to tell if a backlight (if set has one) is bad is to measure the voltage on the power board and at the back light itself---most voltages are marked on power board or a Service Manual would pinpoint them.
If the voltages are normal and back light is on but DIM only option would be to replace the board that drives it or the actual back lights'
If you Google the model number with "parts" you should be able to locate the back the parts involved.
May 21, 2012 | Sony Bravia KDL-40S4100 40 in. LCD TV
Upper half of screen is darker than the lower half
Its back light in LCD Panel problem, there are approx 20 CCFLs in 40" lcd panel and one or two in upper half is not providing enough light to give proper brightness so you see bit darker image.
As per Sony policy, lcd panel will be replaced to fix this issue and local tech can fix it on component level (replacing bad ccfl) if he/she agrees because its risky work.
Hope this nfo will help you.
Dec 28, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Picture get dark than light
On your remote control, press the huge circle, which should be settings or menu, there, go on brightness, put it up to max if u want bright, and low if u don't .If the problem still happens, ask customer service to help, or return it!!
Feb 19, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony bravia
It sounds like the backlight is going bad or possibly the panel. Let me see a picture of it. Talk to you later. Jay
Feb 01, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
One half of screen sees darker than other
Problems described are related to Backlight.It is possible that backlights of affected area have become weak.
You may need to contact the company for repairs and Yes the Repairs may not be cheap.
Samir
Nov 01, 2007 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony KDF-E55A20 55 in. LCD Television Logo
65 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
