Question about Microsoft Xbox 360 Console
My wireless router wont pick up my xbox
It works fine when connected directly to the router but when we try to go wirless it will notnreconize it
    Problem Solver:
  • 5 Answers
I don't believe the device is bluetooth. I think thats why you'd have a problem otherwise. You may be able to check online for items that are... such as routers and look for adapters to attach to your xbox to make it accept it. Otherwise it won't work.
Posted on Dec 25, 2008
My xbox 360 cant pick up my wirless connection do you no why ?
have you got a new xbox 360 or old xbox 360 as the old version doesnt have wireless built into it
Mar 12, 2011 | D-Link AirPlus DI-524 Wireless Router
The router wont set up a wireless connection in the xbox so the internet does not work.
you need a wirless device to plug into the xbox 360 or u can use a long ethernet cable
Jun 27, 2010 | Belkin N1 Vision Router
How can i get xbox live wirless working after buying the adapter. I have bought the xbox wirless adapter and i am having trouble getting wirless.
Okay, to connect to Xbox Live using Wireless Internet you will need this:
One Xbox Wireless connection unit, There are two types, the black and white versions. The black one is able to pick up the most diverse signals and has a higher potential for speed so I recommend that one.
You will also need, of course, a high speed internet source (modem) and a wireless router connected to the modem. When looking for wireless routers look for ones with marks claiming to be compatible with Xbox Live or a Windows OS. Those have been tested to work with Xbox.
Before trying to set up your Xbox Live, make sure your Router is set up with your computer, and set to be used as a wireless router. That's another tip all together but just follow your installation CD.
Okay so here we go!
First, Connect the wireless networking adapter to the back of your Xbox.
If you have a network cable plugged into your xbox, unplug it. Check to make sure the adapter's light is on.
Here's what the light's mean:
On the gray adapter:
No light: It's not getting enough power( try plugging it another USB slot)
Green light: It is connected to a wireless router, gateway or wireless access point.
Red light: It is not connected, and is ready for configuration.
Flashing red: There is a malfunction. (try again, if the problem persists return it for a replacement)
On the black adapter:
Green light: It is connected to a wireless router2_bing.gif, gateway or wireless access point.
Flashing green: The adapter is attempting to connect to a wireless router, gateway, or access point.
Now the CONFIGURATION, the reason most of you are reading this:
Turn your Xbox on and go to "My Xbox"
Go to "System Settings"
Go to "Network Settings"
Go to "Configure Network"
On the basic settings tab select "Wireless mode"
Select "Scan for Networks"
Select your Wireless source.
NOTE: If your Network isn't listed you will have to manually enter it.
To do this select "Specify unlisted network"
You will need to enter your SSID
Then choose which security you used to set it up on your Computer (ie: WPA, WEP...) Then enter your security code. If there is no code then select "no security"
Your adapter should have a green light now.
Now go back to "Network Settings" and select "Test Xbox Live2_bing.gif Connection"
If it works your good to go!
If not read visit: http://support.xbox.com/support/en/us/Solutions/wizardhost.aspx?wizardid=xlcsv1
Hope this tip helps :).
Dec 31, 2009 | Microsoft Wireless Network Adapter Xbox...
Wireless router cannot connect to XBOX Live
I have a linksys 10/ 1000 card and a 2wire wirless router and had the same problem. You need to go to your control panel and double click the wireless network. Once you set it up you need to make sure that if you have a firewall that the xbox has permission to access the net. Also all wireless devices have a security measure some have WEP keys and others have passwords you need to find out what yours is.
Jul 20, 2009 | Microsoft Xbox 360 Console
When I secure my wirless network xbox live wont connect
If your xbox is also connecting wirelessly, you have to input also the wireless security key on your xbox to be able to connect.
Jun 29, 2009 | NetGear RangeMax WPN824 Wireless Router...
Belkin N1 Wireless router wont fully connect to laptop
if you connect your xbox and it works than it is not your isp
go to your network setup and try it with fix ip and DNS to you vista laptop wirless card /fixed card ip setup
goodl luck get back if this does not work with more info on your network setup
Jun 12, 2009 | Belkin (F5D8231-4) Wireless Router...
I cannot connect to xbox live because my xbox360 cannot find my network
i had this exact problem. the reason mine wasn't working was because the security settings for my wireless router were set on wp2a and the xbox 360 can't pick this up. change your wireless router security to wpa and you should be fine...after i did this it saw my network and i was fine
Jun 02, 2009 | Microsoft Wireless Network Adapter Xbox...
Unable to get IP address on SMC2804WBRP-G
You need to setup security on the laptop/access point. Apparently it has been setup in the router.
Jan 25, 2009 | SMC Barricade g SMC2804WBRP-G Wireless...
Xbox 360 wireless connection
If you already have wireless router you will need something like this:
http://www.xbox.com/en-US/hardware/x/xbox360wirelessnetadapter/
Or you can always buy a third party wireless device that is capable with Xbox 350.
Nov 16, 2007 | NetGear WGR614 Wireless Router
Microsoft Xbox 360 Console Logo
151 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
shaun taylor
mitch_3020
mitch_3020
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
