Question about Kenmore Oasis HE 27082 Top Load Washer
It sounds like something is stuck the washing machine drain
  • jaimeepearlm Dec 27, 2008
    Thank you! Happy Holidays!
  • 179 Answers
Would not surprise me probably coins to access the pump take the back off on the bottom you will see two pump the one for the drain is the one on the left (when looking at the back of the machine) unhook it and dump it be sure to have plenty of towels to soak up the water
Posted on Dec 26, 2008
I have a beko eco care wma1613s washing machine. It does its full cycle but after the wash cycle it doesnt drain the water. Can you help?
sounds like the drain pump blocked or something is stuck in it stopping it from working, i took mine out, cleaned it and it works fine now
May 14, 2010 | Washing Machines
I have an Electrolux EW 548 F Washing machine. It stopped while in a cycle and it won't continue or let me open the door to get the clothes out.
It sounds as if something has got stuck in the filter jamming the drain pump,try draining the water out either through the filter but beware of the amount of water.Or take the drain pipe at rear and try to drain iinto a container or through the nearest door to an outside drain.Once the water is out you should be able to open the door.Then you will have to find out if some object is stuck in the filter(located at bottom right hand side).
May 03, 2010 | Electrolux Washing Machines
KEnmore front load washing machine pulled in a little bit of water and stopped, door locked and small buzzing/vibration sound. unplugged to reset - did not work, tried it again and it drained a little then...
there is something stuck or blocking the drain pump.
use a wet dry shop vac and attach it to the end of the drain hose to remove the water.
then remove the hoses from the drain pump and look for any obstructions.
Feb 20, 2010 | Washing Machines
Maytag Model #MAT13MNAGW When the machine gets to the spin cycle it doesn't spin but makes a buzzing sound. Something like the buzzing sound that a welder makes when the rod sticks.
this means that there is something stuck inside your drain pump.if you still have water in the machine you can use a wet/dry shop vac and attach it to the end of the drain hose and remove all the water in the tub.
once that is done check your drain pump for obstructions if there is no obstruction look at the hose that comes down from the bottom of the tub to the drain pump
Feb 08, 2010 | Washing Machines
My wash machine won't drain
sounds like you got a blocked empeller on drain pump,coin or something,also drain pump could have failed,a sock could be stuck at drain pipe from drum,hope this helps
May 12, 2009 | Samsung WE356A5W Washer/Dryer Laundry...
Washer will not agitate
There is either something stuck in the drain pump or the motor is defective. The drain pump is connected to the front of the motor, if you remove see if the motor works without it. If it does work, check to see if there is something stuck inside the drain pump or if it is seized.
Feb 21, 2009 | Kenmore 22422 Top Load Washer
Sounds like something stuck in the washing machine when draining
Something has become stuck in the drain pump.
1. Remove the back cover. The drain pump is in the lower left corner.
2. Tilt machine forward for easier access.
3. Unplug the pump motor power plug.
4. Loosen the hose clamp from the tub.
5. Remove the drain hose connection from the pump.
6. Remove the three screws securing the pump to the tub.
7. Remove debris from pump.
8. Replace pump.
9. Merry Christmas...
Dec 25, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Ge washer model#wjsr2080t6ww
Sounds like something is stuck in the drain pump, maybe a sock. Remove the front panel by sticking a small screwdriver or putty knife just above the front panel to release 2 clips. Drain pump is located bottom right with 2 hoses connected to it. Drain the machine and remove the hoses. Check for obstructions.
Apr 07, 2008 | Washing Machines
Kenmore Oasis HE 27082 Top Load Washer Logo
44 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
