Question about Nikon CA-1104-SMK for D70SLR
Autoocus doesn't work
I have a NikonD70s approximately 2 years old with two autofocus lenses. Recently autofocus stopped working with both lenses. Otherwise the camera seems to work normally. Is there any fix for this problem short of taking it in to a shop?
The first thing to check is that autofocus is enabled on the camera body.
The auto/manual focus selector switch is located on the front of the camera, just below the lens release button (on the left side as you look through the view finder). Make sure that the white dot on the selector lines up with the white dot under the AF (autofocus).
If this does not solve the problem, make sure that your lenses are set to autofocus mode as well.
Posted on Apr 27, 2009
Autofocus on Nikkor 18-55mm lens doesn't work
probably you have problem with the focus motor, i ever have same problem and need to replaced the focus motor.
Jun 08, 2013 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Autofocus problem with 70-300mm is usm
Replace the broken ribbon cable in the lens
Sep 23, 2012 | Canon EF 70-300mm f/4-5.6 IS USM Lens
What is the use of MF lenses
Many manual focus lenses date to before the development of autofocus technology. Unlike every other Japanese camera manufacturers, Nikon has not changed their lens mount since the beginning. 50-year-old lenses fit and work fine on the newest camera bodies (except that there is no autofocusing, of course).
Also, for some uses you don't want to rely on autofocusing.
Sep 19, 2010 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
Autofocus Does Not Work
there is couple of possibilities like wise when you zoom lens manualy and can you heard the hard noise then could be AF unit itself faulty. AF unit gear is gone.
could be AF shaft broken thats why not focusing
for that please bring to canon service center
Jul 04, 2010 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
I have a Nikon D60 and my autofocus has stopped working. It is not because of the lense because i have tried other lenses and the auto focus won't work with them either so it must be an issue with the...
You should check custom menu setting 2, and make sure it's set to one of the auto modes. Make sure the lenses you are using are AF-S and not regular AF lenses. The D60 has no autofocus motor, so autofocus only works with AF-S lenses.
I always suggest folks take a look at Ken Rockwell's website also, here's a link to a specific page on autofocus on the D60.
Post a comment here if none of this works and I'll see what else we can do.
http://www.kenrockwell.com/nikon/d60/af-settings.htm
Jan 08, 2010 | Nikon D60 Digital Camera
Will my quantaray tech-10 NF AF zoom lens (for me
Yes, with caveats. The autofocus won't work on D40/D60/D3000/D5000. The metering may not work in all modes on all cameras. Since you didn't specify which camera, I can't give you a better answer than that.
I have 30-year-old Nikon lenses working fine on my D90, but without metering. And the old lenses date before the invention of autofocus.
Nov 27, 2009 | Cameras
Nikon D300 - Auto focus point won't move. Autofocus doesn't work.
The lock that's around the 4-way button that moves the AF point will stop it from moving. The AF switch (says C,S,M) on the body below the lens release button gets knocked to manual and turns off the AF
Oct 11, 2009 | Nikon D300 Digital Camera
Lense will not work with SLR Nikon D90
This lens is too old for the D90, it has not got the electronics for metering and autofocus.
You can use it manually in M mode but you will have to set the aperture and shutter yourself.
The D90 manual has a section on compatible lenses, page 228 in my version.
This recommends CPU lenses for the D90, type G and D.
Dec 25, 2008 | Nikon Zoom 80-200mm f/4.0 AIS Lens
70-300DL Macro Super autofocus problem
It is likely that the lens will need parts. Sigma is not the best for repair parts. Typically, the small nylon gears that control the AF break. It is still a useful piece in manual focus. Repair costs would likely exceed its value.
Feb 17, 2008 | Cameras
Nikon CA-1104-SMK for D70SLR Logo
146 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
