Question about Tomtom One XL GPS Receiver
CAN YOU CHARGE UNIT IN HOUSE
The booklet says you can charge the unit for 2 hours in the house but it didn't come with a ubs cord that can plug it into a electrical outlet
  • 211 Answers
The cord that attaches your TomTom to the computer for updates may also be used as a charging cord via your computer.
Posted on Jun 16, 2009
How to charge
• IMPORTANT: This unit is delivered partially charged.
Plug into an extension cord FOR 40
hours before using.
You cannot overcharge the unit using the AC charging method.
• To recharge this unit, use only the supplied AC charging adapter.
• All ON/OFF switches should be in the OFF position when the unit is charging or not in use. Make sure all switches are in the OFF position before charging. Here is the instruction book:
http://ecx.images-amazon.com/images/I/81US%2Bom6xKS.pdf
here is the booklet.
Jul 21, 2014 | Stanley Tools 500W Portable Power Station"
Fuji battery charger BC-45 - red light blinks when I put in battery and battery does not charge
Ok all mine had the same problem however problem has been solved! The power cord that plugs into the charger is a common cord you may have laying around the house. I switched the power cord to my charger and the dreaded blinking stopped! Its just a bad power cord to the charging unit! Hope this helps!
Aug 03, 2010 | Duracell AA/AAA NiMH Battery Charger with...
I neglected to plug in the cord to my cigarette lighter and the charge ran down to 0.I am on a trip and did not bring the charging cord. i tried plugging into lighter in car but it stays on for a feww...
leave it switched off and plugged in.
This would give it chance to actually charge as using it from dead with it plugged in does not always allow some GPS to charge properly.
You neglected to say which brand so its hard to give a 100% answer.
Most GPS should have enough charge withing 4 hours but from dead some older units require anywhere up to 18 hours according to some of the manuals i have laying around
Bob.
Bob
Jun 23, 2010 | GPS
It worked fine one minute and about 10 minutes later it would not turn on at all. Batteries not the problem as plugging it into the power cord or the computer hookup does nothing.
Its because ur internal memory battery is dead or no charge so please keep the unit charge in all possible ways for about 2 hours. Some palm tops have base stand and a seperate place on the base stand to charge the normal battery. So make sure u leave the unit for charge for a longer period of time say 5 hours.
Thankyou
Jul 31, 2009 | Palm Z22 Handheld
My MPC t2300 laptop wom't turn on.
The Transport T2300 has an internal battery that will run the laptop for several minutes after the main battery goes dead. This feature allows you to save your work and shut down safely. If you run the laptop until both batteries are dead, even a brand new battery can't start the unit again. You have to follow this procedure:
1.Unplug power cord
2. Remove any attached periphal components including the cd rom and/or floppy disk module if you have one. Both remove with a push button switch located on the bottom of the unit.
3. Plug in power cord and charge the unit for a minimum of 24 hours straight. 30 hours is better. This whole time will be spent slowly recharging the internal back up battery.
4. Once that is done, unplug power cord again and reinstall any floppy/cd drives. Plug power cord back in now and charge for at least 24 hours again.
If your backup battery is dead, you can't charge the main battery or turn the unit on. The longer you charge, the better. We had one unit here that had to be on the initial battery backup for 72 hours before it finally took hold. Then, one overnight recharge on the regular battery and all was well.
If you need drivers or manuals for the 2300, all are available on cd at mpcsupport@cox.net for around $9.50 including shipping, handling, and owners manual
Apr 11, 2009 | MPC Computers TransPort T2300 Notebook
WE CHARGE THE MAGELLAN GPS AND TURN IT OFF. BUT WHEN WE GO TO USE IT AGAIN IT IS DEAD. I ONLY HAVE THE LIGHTER OUTLET TO HOOK UP FOR POWER SO WHEN I NEED TO PROGRAM IT IN THE HOUSE I DO NOT HAVE A WAY TO...
Hello kdiltzbook,
Most GPS units can be charged three different ways:
1. Connection to a computer via USB port
2. Connection to a automobile via cigarette lighter plug
3. Connection to a wall outlet via an AC adapter
Typically most GPS devices these days include only the USB cord. Some GPS units also include the cigarette lighter plug. For most GPS units the cigarette lighter plug and AC adapter are optional accessories have to be purchased in addition to the GPS.
You don't mention which model of Magellan GPS you have so I am not sure which cords your GPS should have included. It sounds like you have the cigarette lighter cord and the USB cord? I am sure that Magellan has an AC adapter available for your GPS. You will want to contact them directly (their website is http://www.magellangps.com) or visit an electronics store that sells Magellan GPS receivers (such as Best Buy™) to purchase the adapter.
However, most GPS receivers can be charged from the USB programming cord on the computer. However, ensure you are plugging the cord directly into a USB 2.0 on the computer itself NOT a port on a USB hub. (A USB hub may not output enough power to actually power and charge the GPS.)
You will also want to check and replace the fuse on the automobile plug.
I believe that both the USB and automobile cords should be charging the GPS. If neither adapter is charging the unit then the problem may be the GPS unit itself. The GPS may have a bad battery or problem with its charge circuitry. If that’s the case the unit may require factory service as the battery pack is generally not considered to be end user replaceable.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 07, 2008 | GPS
Will not charge in car
Pilki i have the same problem, though with the original items.
Jun 24, 2008 | Tomtom GO 910 GPS Receiver
Tomtom One XL GPS Receiver Logo
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
