Question about Microsoft Windows XP Home Edition
Device driver flags
Ok, you fixed my no recognition of cd drives with the registry edit solution, do you have one that will me clear flags in my device manager screen...one for multimedia controller and one for video controller?
Larry
  • 38 Answers
Pls check that your CD drive is connected properly to the motherboard. For your mulmedia controller and video controller, you need driver CD for both as windows is not recognizing your device. So you need to get the driver CD for both the hardware.
Posted on Dec 26, 2008
Cd drive doesn't work
Check that the data-cables and power-cables for your drives are tightly connected, both at the "back" of the CD/DVD drive, and where the data-connector connects to the motherboard.
Also, on the back of each CD/DVD drive are three "pairs" of pins,
labelled MA(ster), and SL(ave), and C(able)S(elect).
Confirm that both drives have a jumper at the CS position,
or move the jumpers so that one drive is at the MA position,
while the other drive is at the SL position.
You must avoid setting _BOTH_ drives to 'MA' or _BOTH_ to 'SL'.
Nov 23, 2009 | Dell Dimension 4700 PC Desktop
Cdwr code 41
To resolve this issue, edit the Windows registry to identify the CD-R drive or CD-RW drive as a recordable drive. To do this, follow these steps.
WARNING: If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Microsoft cannot guarantee that you can solve problems that result from using Registry Editor incorrectly. Use Registry Editor at your own risk.
1. Click Start, and then click Run.
2. In the Open box, type regedit, and then click OK.
3. Expand the following registry subkey:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning\Drives
4. On the File menu, click Export.
5. In the File name box, type backup of drives key, and then click Save.
NOTE: You can restore this registry subkey by double-clicking the backup of drives key.reg file that you saved.
6. In the left pane of the Registry Editor window, click the Volume{GUID} folder under Drives, where GUID is a 32-character hexadecimal globally unique identifier.
NOTE: If you have more than one CD-ROM drive in the computer, an additional Volume{GUID} folder is listed for each drive.
7. In the right pane of the Registry Editor window, double-click Drive Type.
8. In the Value data box, type 1 or 2, depending on the drive type, and then click OK.
The drive type should be 1 if it is a CD-R and 2 if it is a CD-RW.
9. Quit Registry Editor.
10. Click Start, and then click My Computer.
11. Under Devices with Removable Storage, right-click the CD-R drive or CD-RW drive, and then
click Properties on the shortcut menu that appears.
12. If the Recording tab is displayed, the drive is successfully recognized by Windows as a recordable
device.
13. Click Cancel.
NOTE: If you have more than one CD-ROM drive, DVD-ROM drive, or CD-RW drive in the computer and the Recording tab is not displayed, an incorrect drive may have been configured as "recordable" in the Windows registry. To troubleshoot this issue, follow these steps:
1. Follow steps 1 through 9 to edit the Drive Type value of the Volume{GUID} folder whose
value you previously changed.
2. In the Value data box, type 3, and then click OK.
The drive type value of 3 indicates that the drive is a standard CD-ROM and is not writable.
3. In the left pane of the Registry Editor window, click the next Volume{GUID} folder.
4. Follow steps 7 through 8 to change the Value data entry to 1 or 2, depending on the drive type.
5. Quit Registry Editor, and then follow steps 10 through 12 to confirm that the Recording tab is
displayed in the properties dialog box of the CD-R drive or CD-RW drive.
XXXXXXXXXXXXXXXXXXXXXXXXXXXXX
SYMPTOMS
After you install Microsoft Windows XP, the CD-ROM drive, the DVD-ROM drive, or CD-ROM R/W drive may not be visible in the My Computer window. Additionally, there may be question marks on the devices that are listed under CD-ROM drives in Device Manager.
CAUSE
An incorrect device driver was installed for the CD-ROM device.
RESOLUTION
To resolve this behaviour, use the following methods in the order in which they are presented.
Method 1: Remove Registry Entry
3. Locate the following registry subkey:
HKEY_LOCAL_MACHINE/System/Curretcontrolset/Control/Class/{4d36e965-e325-11ce-bfc1-08002be10318}
5. In the File name box, type savedkey, and then click Save.
6. Click the REG_MULTI_SZ data type UpperFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes. NOTE: If this data type is missing, continue to the next method.
7. Click the REG_MULTI_SZ data type LowerFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes.
8. Quit the Registry Editor, and then restart the computer.
Method 2: Replace Existing Driver
1. Click Start, and then click Control Panel.
2. If Control Panel is in Category view, click Performance and Maintenance, and then click System.
-or-
If Control Panel is in Classic view, double-click System.
3. On the Hardware tab, click Device Manager.
4. Click the drive with the question mark next to it.
5. On the Action menu, click Uninstall. When you are prompted to confirm the removal, click OK.
6. Repeat steps 4 through 5 for any other drives with question marks.
7. On the Action menu, click Scan for hardware changes.
NOTE: If Windows XP cannot locate the driver for your device, the device may not be supported by Windows XP. To see the list of supported devices, see the most recent Windows Hardware Compatibility List (HCL) at the following Microsoft Web site:
SYMPTOMS
After you remove either compact disc (CD) recording software or other software from your computer, your computer may exhibit the following behaviour:
• In My Computer, there is no access to your CD-ROMs.
• In Device Manager, the following error message appears in connection with any CD-ROM device that is part of your computer system:
The device is not working properly because Windows cannot load the drivers required for this device
(Code 31).
• Device Manager displays the following error message:
A driver for this device was not required, and has been disabled (Code 32 or Code 31).
You may also receive an error Code 39 message that indicates that the driver is corrupted.
• Device Manager displays the following error Code 19 message, which means that the registry returned some unknown result:
Your registry might be corrupted. (Code 19)
• You may also receive the following error message:
Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
RESOLUTION
To resolve this behaviour, follow these steps:
1. Start Registry Editor (Regedt32.exe).
2. Locate the UpperFilters value under the following key in the registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
3. On the Edit menu, click Delete, and then click OK.
4. Locate the LowerFilters value under the same key in the registry:
5. On the Edit menu, click Delete, and then click OK.
6. Quit Registry Editor. NOTE: After you remove the Upperfilters value and the Lowerfilters value, if you notice lost functionality in a particular program, such as CD recording software, you may need to reinstall that software. If the problem recurs, consult with the software vendor for assistance.
7. Restart your computer.
STATUS
This is a known issue that can occur when you remove Easy CD Creator version 5.01 or earlier or DirectCD version 3.01c or earlier. This issue may also occur with Easy CD Creator version 5.01 and with DirectCD 3.01d or later.
MORE INFORMATION
There may be other third-party CD-writing software products that exhibit similar behaviour. Some or all of the troubleshooting steps in this article might apply if such a product also adds entries under the UpperFilters or LowerFilters value in the registry, either by adding its own filter drivers or by removing the registry keys and values outlined in this article that begin with:
Oct 08, 2009 | Acer Computers & Internet
Device Manager found a problem with the driver and can not be fixed automatically. Need to download the Integrated CD-RW/DVD Combo Driver.
If the drive is showing an error (or is missing) in device manager, do the following:
Start Registry Editor (Start, Run and type in regedit then click O.K)
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Hope this helps
May 04, 2009 | Sony VAIO PCG-K23 Notebook
Cd and dvd drivers not working
Hope this helps
May 02, 2009 | Acer Aspire 5315 Notebook
Device driver flags
When you double click on the devices with the yellow exclamation mark what is the error or error code? You will probably have to update the drivers for these devices. What make of pc or motherboard do you have? You can usualy get updated drivers from the manufacturers website.
Dec 25, 2008 | Microsoft Windows XP Home Edition
My DVD drive on my Toshiba Satellite A75 S206 isn't recongized
I was able to find this by insomniac on CDROM Guide:
You don't need drivers for optical devices (CD and DVD drives) as Windows has native support for them.
It sounds like a corrupt Registry entry, which is common with XP.
The following should fix it.
Dec 19, 2008 | Toshiba Satellite A75-S206 Notebook
COMPAQ Presario V2000 external drive
Dec 14, 2008 | HP Compaq Presario V2000 Notebook
How to solve the code 19 errors
Error Code 19 means that the registry is corrupted. Try the following fix:
  1. Click Start and then click All Programs.
  2. Click Accessories, and then click Run.
  3. Type regedit, and then click OK. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  4. In the right pane, click UpperFilters. On the Edit menu, click Delete.
  5. When you are prompted to confirm the deletion, click Yes.
  6. In the right pane, click LowerFilters. On the Edit menu, click Delete.
  7. When you are prompted to confirm the deletion, click Yes.
  8. Exit Registry Editor.
  9. Restart the computer.
If this does not work, try uninstalling and reinstalling the computer by:
  1. Click Start and then click Control Panel.
  2. Click System and Maintenance, click System, and then click Device Manager.
    In Device Manager, expand DVD/CD-ROM drives, right-click the CD and DVD devices, and then click Uninstall.
  3. When you are prompted to confirm that you want to remove the device, click OK.
  4. Restart the computer.
Nov 22, 2008 | Sony (2450455) CD-ROM Drive
Dvd rw
Please go through the below provide steps.
Fixing Code 39 Error
If your CD-ROM drive is not visible in My Computer, you may see the following error message displayed with the CD or DVD drive item in your Device Manager. (Steps to open Device Manager are discussed later in the article.)
"Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)"
Using Device Manager
To fix this error, first try to update the driver from the Device Manager. To open Device Manager, right-click My Computer on your Desktop, and then on the Hardware tab, select the Device Manager button.
In the Device Manager window, identify the CD or DVD drive item (with Yellow exclamation mark), right-click on it and select Update Driver. Follow the screen instructions to update the device driver and restart your PC.
Using Registry Editor
If updating the driver does not resolve the problem, it indicates that there is a problem in the registry. To fix this problem, you may have to remove a few keys from the registry.
Note: Be careful while working with the registry editor because changes done to the registry using the Registry Editor are irreversible and mistakes can leave you with more problems than when you started. Therefore, it is recommended that you make a backup of the registry before proceeding with the changes.
After you have removed the registry keys listed below, you will have to reinstall all applications that you use for CD or DVD recording to make them work properly.
To fix the error by editing the registry, perform the following steps:
  1. Exit and close all applications currently running on your PC.
  2. On Start > Run type Regedit and press the Enter key.
  3. Next, navigate to the following registry key:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\ Control\Class\ {4D36E965-E325-11CE-BFC1-08002BE10318}
  4. Delete any of the following registry entries if they exist under this key:
    • LowerFilters
    • LowerFilters.bak
    • UpperFilters
    • UpperFilters.bak
  5. Restart your PC and open My Computer to ensure that the CD-ROM drive is visible.
  6. Also, open the Device Manager again to ensure that the yellow exclamation mark and the error code is now gone.
  7. Restart your PC and open My Computer to ensure that the CD-ROM drive is visible.
  8. Also, open the Device Manager again to ensure that the yellow exclamation mark and the error code is now gone.
Thank you........
Sep 18, 2008 | Computers & Internet
Microsoft Windows XP Home Edition Logo
49 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
