Question about GE 46GW947 46" Rear Projection Television
Channel changing I am unable to change channels. Digital indicator changes on screen as channels are selected but image remains unchanged. Input is standard cable. Do not have user's manual to consult.
  • 87 Answers
You can obtian the user manual at http://www.thomsonnetwork.com/EN/Public. It is likely that during intital set up you selected iether VCR or cable box. If so unplug the tv for about 5 minutes. Whenit is turned on again you will get the intial setup screen. Select "nl" when asked if you have a VCR or cable box.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Posted on Jul 13, 2007
SOURCE:
How do I retune my Samsung smart TV 40"with 3D
Country (Area)
Broadcasting > Channel Settings > Country (Area)
Select your country so that the TV can correctly auto-tune the broadcasting channels. This depends
on the country or region.
When the PIN input screen appears,enter your 4 digit PIN number.
Digital Channel
Change the country for digital channels.
Analogue Channel
Change the country for analogue channels.
Manual Tuning
Broadcasting > Channel Settings > Manual Tuning
Scans for a channel manually and stores in the TV.
If a channel is locked using the Channel Lock function, the PIN input window appears.
This function depends on the country and region
Page 147 of this User Manual located on this page will give you more information. (Sorry it wouldn't let me link the PDF manual directly)
UE40H6240AK UE40H6240AKXXU Support SAMSUNG UK
Sep 09, 2014 | Samsung 40" 1080p 3D Slim LED Smart TV...
How do we scan/program in local tv channels. We bought an external antenna, but get no picture. Typically, there is a protocol for scanning channels into the set. Model is Sansui TVS2746B, and the set was...
Okay, does this tv have a built in DIGITAL tuner? Most tv's only have an analog tuner. You can tell the difference while you are changing the channels. If the channel indicates 2.1 or 2.2 and so forth, it is on a digital channel mode. If you change the channel and it indicated 2, 3, 4, etc. it is analog. If it has digital capability change the input until you see 2.1, 3.4 etc. If you cycle through all the inputs on the tv like, input 1 (TV) input 2(DVD) input 3(HDMI) and so forth and you never see the digital channel you most likely do not have a digital tuner. You will need to purchase a digital converter which will convert it to analog and you can watch it by placing you tv on analog channel 3 just like the old vcr's. Hope this helps and please don't forget to rate this solution.
Jan 22, 2011 | Samsung TSL2793HF 27" TV
No image from coaxial cable or any of the video inputson a panasonic CT-32G34
you have to have the TV set to the right input, look on your remote for input selection. Or try changing the channel on your TV
Feb 07, 2010 | Panasonic CT-32G14 32" TV
Unable to to get cable channels in modulator. Set to cable, channels 73/75 but "connection" grayed out. Cable signal strong. Able to read Digital channels on Local set up with same i/p.
mfbmeb,
The connection button is not utilized from the "Modulator Setup" screen. When changing the channel for TV 2, you can arrow over to either air or cable and pressing select. This will select that option and change the channel to either 60 for air or 73 for cable. Once this selection is made then you would move to the "Done" button and press select. You will return to the "Installation" menu, then cancel out till you are back to the TV screen. I hope this helps.
Ray Calo
DISH Network
Dec 16, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Tv has only snowy screen. Used the remote to
What to do if you have an all snowy picture (blue screen or the TV displays unusable signal-no signal or no sync)
1 – If you are using a digital cable box or satellite receiver (make sure it’s on) and be sure your TV is set for either CH3 or CH4 (which ever you usually view it on). If you usually view it through video inputs (video1 or 2 etc.) make sure the appropriate input is selected.
If you still don’t get a signal see if you get picture using the DVD or VCR (if available) if you do than plug the satellite or Dig. Box temporarily into the place of the DVD (unplug DVD) you may have to use some A/V cables (RCA yel./red/wht like the ones on the DVD) to hook to the tv from the sat./dig. box. If you get a signal then the sat./dig box is ok. If not the Sat./dig box is not sending a signal and is either defective or needs to be rebooted (unplug wait 5 min try again).
2 – If you are using standard cable or antenna (source) if possible check that the source is good by connecting to another TV. Otherwise try running the source into a VCR and then out to the TV using video inputs (RCA yel./red/wht like the ones on the DVD) and then selecting the appropriate input. Try seeing if the VCR plays using standard CH3 (or CH4)
If the VCR plays on video input but not when connected to CH3 (CH4) then the tuner of the TV may be defective – see if you can use the VCR to change channel using the VCR remote.
Be sure to vote/rate me if this helped Thanks!
Nov 24, 2009 | Toshiba 32AV502U 31.5 in. LCD HDTV
Changing to digtal. I have a digibox but with the regional changeover yesterday to digital, I can no longer get any channels. I cannot find where to reschedule the channels on the menu. Please can you...
Look in a Setup menu for a Channel Scan or Auto Scan selection. You may have to set an Input or Antenna setting to the appropriate input (cable or antenna)
Jul 23, 2009 | Televison & Video
Turned on set....screen all black except a dark blue rectangle in center which reads:Failed to receive broadcast [E202]
That message is presented when a selected digital channel is too weak to decode. Let us hope that something was accidentally changed:
Is the channel legitimate?
Is the antenna/cable still connected (to the Digital input)?
Go into menu - setup - channel setup. Is the selection of either cable or air channels correct for your situation?
Use menu - setup - Antenna Setup-DIGITAL to examine the signal strength. Is there nothing at all, or is it just a question of strength?
Odds favor a change in channel setup that you would not have made intentionally, or a simple physical problem (input cable, etc.). Start from scratch, and check the settings and connections you originally made. Hopefully it will be simple and cheap!
May 22, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
How to hook my directv to digital input to lcd tv j32l637
I don't know what flat screen tv you have,but you must be aware of the coaxial input behind the TV.It could be analog input,digital input and OUTPUT!!
Anyway,if you connect your basic directv box to your digital input,it will not serve you any purpose to get HD channels and you don't have the HD directv box.The TV will not display digital channel for you because if you use coaxial input to TV,you should be under either channel 3 or 4 and be sure either channel had been saved under memory.In order to change channels,you will need to change it from your directv box.
JUST LIKE a VCR connect to TV.TV will be under channel 3 or 4,and you will change your channels from the VCR.Don't forget to scan all the channels from the VCR!
solutiondoct
Nov 11, 2008 | Televison & Video
GE 46GW947 46" Rear Projection Television Logo
117 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
