Question about Toys
No instructions for setting pin #
No instructions came in box. How do I set the pin # ?
    Problem Solver:
  • 3 Answers
What product are you talking about>?
Posted on Dec 25, 2008
Tip
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} PANASONIC CONVERGENCE IC REPLACEMENT:
What you will need;
Two new STK-392-110 convergence Ic’s
Solder
Liquid solder flux
Desoldering braid or wick
A good soldering Iron
Some denatured alcohol
A small toothbrush
A Philips screwdriver or screw gun to REMOVE SCREWS
A PAIR OF GLOVES
  1. UNPLUG TV SET.
  2. Remove back cover of TV set.
  3. Remove entire front speaker grill on set(it pulls off and may resist being removed)
  4. Locate and unplug speaker wires (they are plugged into the main circuit board).
  5. Locate three cables with wires that come from the Front keyboard—two of them have to be unplugged from the main board(all plugs are different sizes but note where they go)
  6. Remove 2 long philips silver machine bolts from the front of the set (behind the grill).
  7. Remove 4 more in the back of the set; two are located at the extreme back edge of the plastic frame and hold the chassis down; two more are located on either side and also go straight down; note which are which and set them aside.
  8. Using gloves pull the entire metal box (it is called a light box) out of the set; there are hand holds on either side—careful as the metal has sharp edges.
  9. Remove the box from the set and locate the two Convergence IC chips; they are located on identical metal heat sinks with fins and they should have the STK-392-110 number clearly printed on them in white (they are black)
  10. Turn the light box over on its side and UNSOLDER ALL 18 PINS ON EACH IC. It is a good idea to apply liquid solder flux to the pins on both chips now. I recommend using a de-soldering braid for this—get all the pins completely de-soldered.
  11. Inspect the dozen or so light blue resistors in front of them; most are marked 2.2 ohms—if any are white in the middle you will need to replace them at the same time; best way is to check all of them like checking a fuse----they protect the set if one of the STK’s shorts in any way.
  12. With the STK’s completely unsoldered turn the box upright and remove the two screws on each IC. If the chips have never been replaced you will need to tap them loose with a putty knife or flat bladed screwdriver.
  13. Remove both IC’s.
  14. Apply heat sink grease to the two new IC’s and install them one at a time; this part can take some time and it is important the pins on the new IC’s are perfectly straight---once you get them in, Hand tighten both the screws on each IC---do not use a screw gun—you can strip the screw holes out. Clean the bottom of the circuit board where the chips were soldered with some denatured alcohol and apply liquid solder flux to all the pins.
  15. Presuming you have already found/replaced any bad resistors turn the box back over and solder carefully both of the two new IC’s in, --do not short any of the pins to each other when you do this and when you are done it is a good idea to take a close look at both to make sure all pins are soldered and not touching each other with soldering you have just done. I suggest you do clean the pins on the bottom of the circuit board again with denatured alcohol.
  16. Slide entire light box back into the cabinet.
  17. Reconnect the plugs you removed when you removed the box. At this point take a lens cloth or a paper towel with glass cleaner sprayed on it and clean the three large black lens-if they are dusty the picture will be darker and not as clear as is should.
  18. Position the box so it is all the way in place and none of the wires or plugs are pinched.
  19. I usually at this point turn the set on before I replace the Six bolts that hold it in—2 from the front and the four in back----this way if you have a problem you can remove the box faster.
  20. If the set comes on and now has normal Convergence go into the customer menu and adjust the convergence in the multi-point mode----CAREFUL! THE FIRST OPTION this set usually offers is a green cross in the middle of the screen—do not adjust Green!
  21. Once you have the Red and Blue in the center adjusted find the second convergence mode---it will give you 8 or nine points on the screen with instructions on how to change from blue to red---use the original remote with the thumb wheel or cursor buttons to adjust.
  22. NOTE: SOME of these sets need to have the Convergence adjusted in first: full/4:3 and second in the other two zoom/wide zoom and third on the HD input with a HD signal coming in. There is also an option at this point to go into the Technical menu and fine adjust the convergence all over the screen—if you need this I can give you instructions based on the model you have—most of the time adjusting the set in the customer mode will produce a good result.
  23. I know all this may seem complicated to you, but this repair should take about an hour or so and just take your time when you get to adjusting the set.
  24. If all looks good turn the set off and Unplug it; install all 6 of the chassis bolts back; replace the back cover and the Speaker grill and plug the set back in.
  25. You may find it useful to go over the convergence Adjust again—to get all the points as good as you can. There is a hidden Tech menu that will allow a finer adjustment of the entire screen----it is somewhat difficult to access and there are a lot of buttons on the remote that then do different things.
  26. Most of the time adjusting in the customer menu will give you a very acceptable picture.
SD TECH
on Dec 01, 2009 | Televison & Video
Tip
Convergence Repair for most 2000-2006 Panasonic Projection sets
I have had so many people with this kind of problem ask that I have composed the following instructions:
If picture looks 3D and in the customer menu convergence is skewed or red or blue will not move in some direction here is what is needed to fix this problem.
What you will need;
Solder
Liquid solder flux
A small toothbrush
A PAIR OF GLOVES
  1. UNPLUG TV SET.
I also have similar step by step instructions for Mitsubishi sets made around the same time as these sets.
How to replace convergence ic on rear projection hd tv.
Panasonic convergence instructions for repair
What you will need;
Two new STK-392-110 convergence Ic?s
Solder
Liquid solder flux
A small toothbrush
A PAIR OF GLOVES
  1. UNPLUG TV SET.
  5. Locate three cables with wires that come from the Front keyboard?two of them have to be unplugged from the main board(all plugs are different s but note where they go)
  8. Using gloves pull the entire metal box (it is called a light box) out of the set; there are hand holds on either side?careful as the metal has sharp edges.
  10. Turn the light box over on its side and UNSOLDER ALL 18 PINS ON EACH IC. It is a good idea to apply liquid solder flux to the pins on both chips now. I recommend using a de-soldering braid for this?get all the pins completely de-soldered.
  11. Inspect the dozen or so light blue resistors in front of them; most are marked 2.2 ohms?if any are white in the middle you will need to replace them at the same time; best way is to check all of them like checking a fuse----they protect the set if one of the STK?s shorts in any way.
  12. With the STK?s completely unsoldered turn the box upright and remove the two screws on each IC. If the chips have never been replaced you will need to tap them loose with a putty knife or flat bladed screwdriver.
  13. Remove both IC?s.
  14. Apply heat sink grease to the two new IC?s and install them one at a time; this part can take some time and it is important the pins on the new IC?s are perfectly straight---once you get them in, Hand tighten both the screws on each IC---do not use a screw gun?you can strip the screw holes out. Clean the bottom of the circuit board where the chips were soldered with some denatured alcohol and apply liquid solder flux to all the pins.
  15. Presuming you have already found/replaced any bad resistors turn the box back over and solder carefully both of the two new IC?s in, --do not short any of the pins to each other when you do this and when you are done it is a good idea to take a close look at both to make sure all pins are soldered and not touching each other with soldering you have just done. I suggest you do clean the pins on the bottom of the circuit board again with denatured alcohol.
  19. I usually at this point turn the set on before I replace the Six bolts that hold it in?2 from the front and the four in back----this way if you have a problem you can remove the box faster.
  20. If the set comes on and now has normal Convergence go into the customer menu and adjust the convergence in the multi-point mode----CAREFUL! THE FIRST OPTION this set usually offers is a green cross in the middle of the screen?do not adjust Green!
  22. NOTE: SOME of these sets need to have the Convergence adjusted in first: full/4:3 and second in the other two zoom/wide zoom and third on the HD input with a HD signal coming in. There is also an option at this point to go into the Technical menu and fine adjust the convergence all over the screen?if you need this I can give you instructions based on the model you have?most of the time adjusting the set in the customer mode will produce a good result.
  25. You may find it useful to go over the convergence Adjust again?to get all the points as good as you can. There is a hidden Tech menu that will allow a finer adjustment of the entire screen----it is somewhat difficult to access and there are a lot of buttons on the remote that then do different things.
SD TECH
Jun 07, 2011 | Panasonic PT-51HX41 51" Rear Projection...
I have installed a new adjustable thermostat unit (E1-BCANRT1W). Temp is set at 91 deg and I am using the timer. Two time periods are set and the switch is set to timer (not ON). The unit comes on at...
Double check your slide switch.
For timer: set switch to TIMER
For thermostat: set switch to ON
If slide switch does not operate, then Autocirc may be defective
Laing (800) 554-6853
http://waterheatertimer.org/pdf/Laing-E1-E3-E10-install-instructions.pdf
http://waterheatertimer.org/pdf/Auto-circ-manual.pdf
http://waterheatertimer.org/Water-heater-recirculation-system.html
1) Household AC wiring will not affect the timer.
You can check your outlet using cheap circuit analyzer from home center.
The clock rotates one direction and the pins push small lever down which turns motor on-off.
When the OFF pins pass, the small lever snaps back and the motor turns ON.
I cannot immediately find operation manual for the E-1 model.
Typical ACT303 auto circ manual says following:
2) If timer controlled operation is desired, set timer and move slide switch to TIMER:
Manual says: tabs/pins are outward for ON times.
Another sentence says UPWARD, so I don't know which way the pins are set for sure.
So if you want timer ON for 2 hours, you would set 4 consecutive pins outward or upward.
ON for 6 hours, set 12 consecutive pins outward or upward.
If the timer turns ON in reverse of instructions, then set the pins that way.
Autocirc does not make the timer, they buy timer modules from clock-makers like Grasslin, Intermatic, etc.
3) To operate Autocir thermostatically without the timer, slide switch to ON position.
The clock dial will continue rotating
Apr 14, 2011 | Laing Thermotech Autocirc Undersink...
How to lock this phone so that unauthorised personnel cannot make outgoing calls
Okay. Here are the instructions to set an extension pin and lock. If you lose the pin, you will lock yourself out of the phone and it will cost you to get the instructions to clear it.
From your phone, dial *799 1 PIN # PIN # . The PIN is 4-10 characters and you repeat it. Now, to set it dial *771 on the intercom. Your set is now locked. To unlock, dial *770 PIN.
To erase your pin, dial *799 0 PIN.
If you lose your pin, the system manager will have to clear it. Also, if someone makes too many attempts to find your pin, it locks the set :-)
Good Luck.
Carl
Sep 11, 2010 | Panasonic KX-T7633 Corded Phone
PT53WX52F PANASONIC HALF MOON AT BOTTOM OF THE SCREEN. LOOKS LIKE A CD SPINNING. REPAIR GUY SAID 300-400.00 TO FIX. CAN I DO IT MYSELF
It sounds like convergence problem--red or blue skewed and will not adjust--what is called 3 D like picture.
If you can solder and are handy here are the instructions for PT53WX52 with this problem:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} What you will need;
Solder
Liquid solder flux
A small toothbrush
A PAIR OF GLOVES
  1. UNPLUG TV SET.
If this has helped you, rate this solution as I do this here for free.
Nov 12, 2009 | Televison & Video
Hi , Just got some great info about my
Here are the instructions:
Solder
Liquid solder flux
A small toothbrush
A PAIR OF GLOVES
  1. UNPLUG TV SET.
Nov 10, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Have ibm T23, crashed whilst daughter was using, now get system bios and video bios shadowed. Can only access f1 and f12 please help, step by step instructions needed
you have to RESET BIOS.its a bit complicated do not attempt if unsure.
Remove side of computer box. there should be printed somewhere on motherboard bios reset. it could be a button or a set of 2 pins with a jumper on one pin fit jumper over both pins restart shut off computer remove jumper fit back over single pin (not get lost) reboot and see if computer boots up. go back into BIOS rest to default for first try after which set it for best
Jul 15, 2008 | Computers & Internet
Toys Logo
280 people viewed this question
Top Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
