Question about Tao XM2go Satellite Radio Receiver
Display of recorded programs does not match the program playing
Hi, I am having trouble with my Tao XM2go. It has been working fine up until this happened. When i listen to my prerecorded programs, the listing on the display is out of sync, it does not match what is being played. Is there a way to reset it, and would that help? I have not done anything to fix it yet. Thanks for any help.
  • TechnoWreck Feb 11, 2008
    After approx 1.5 years of use, the record/playback no longer works. I have heard that flash memory degrades over time. I am wondering if the flash memory can be replaced, and if so, what is the procedure.
There is a very small reset button under the back cover. You will need a small paper clip to reach the button. It is located in the upper left hand corner. The button is not under the batt., it is about 2" above the screw on the side. I don't know if this will solve your problem, but it should reset your radio to its default settings. Good Luck!
Posted on Nov 20, 2007
My Tao xm2go quit working. I've tried re-setting it. I've replaced the battery, I double checked that the charger is putting out the correct voltage with a multi-meter. it won't turn on, either with the...
Try plugging the power adapter directly into the bottom of the radio without using either base/cradle - wait a minute - then see if you get a battery indication.
Jan 18, 2010 | Tao XM2go Satellite Radio Receiver
Xm2go is not receiving
Did you try removing the battery to reset the unit?
Feb 27, 2008 | Tao XM2go Satellite Radio Receiver
How do I copy my recorded XM music onto a cd?
Use audio cable out (1/8" headphone jack) to audio in on CD recorder or PC
Oct 14, 2009 | Tao XM2go Satellite Radio Receiver
My tao xm2go will not turn on
Dear Glen,
My Tao solution is to buy the Delphi MyFi which appears to have an identical interface. See page 10 here: http://file.xm411.com/manuals/MyFiUserGuide411.pdf . This is expensive but service in not available.
digitally,
(/\/\<erwin
Nov 21, 2008 | Tao XM2go Satellite Radio Receiver
Atenna connection when using Altec Speaker or Car Kit
Dear xm2go,
I could not find any service options for my own Tao XM2go unit. The only option appears to be the Delphi MyFi unit which appears to be identical (see page 10 here: http://file.xm411.com/manuals/MyFiUserGuide411.pdf )
digitally,
(/\/\<erwin
Oct 07, 2008 | Tao XM2go Satellite Radio Receiver
Tao won't start
Dear Jim,
My own Tao unit is dying as well. Servicing does not appear to be available. The only solution I have found is to buy the Delphi MyFi unit which appears to use an identical interface (see page 10: http://file.xm411.com/manuals/MyFiUserGuide411.pdf ). What a bummer!
Digitally,
(/\/\<erwin
Jul 29, 2008 | Tao XM2go Satellite Radio Receiver
Will not play all channels
It was just a simple refresh via the internet. thanks
Jun 16, 2008 | Tao XM2go Satellite Radio Receiver
Tao XM2go shuts off for no reason
You could try taking the batteries out and cleaning the contacts, replacing the batteries and/or using sellotape to hold the batteries in place. They could be loose and disconnect when you move it in a certain way. If not the batteries, you could try further dismantling and cleaning, but you may just end up with a clean ball of sellotape that still has problems...! worth a try. stoodleysnow
Aug 30, 2006 | Tao XM2go Satellite Radio Receiver
Tao XM2go Satellite Radio Receiver Logo
75 people viewed this question
Top Tao Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Tao Audio Player and Recorder Expert? Answer questions, earn points and help others
