Question about Sansui HDLCDVD260 26 in. LCD Television
PC input doesn't want to work
I have a Sansui HDLCDVD260, 26in television and everything works except the PC part. I have adjusted my refresh rate to 60hz as the instructions said but when I plug in the svga cable all I get is a blank screen. If I unplug it I get a No signal box but when I plug it back in box goes away. I have an Nvidia 7800 Graphics card for my computer, and I do not have a multi media computer.
2 Suggested Answers
SOURCE: I have a Sansui HDLCDVD260,
I have a same Sansui HDLCD 2600 which did not have anything happen when try to switch on. no lights even on the power led. where can I get the replacement parts?
Posted on Jun 28, 2009
Need to change input signal to 1440x900@60hz
go to control panel and then display settings and adjust the resolution and refresh rate that way. if you don't have the option and your video drivers are up to date then your video card doesn't support a resolution that high.
May 10, 2012 | Dell OptiPlex GX150 PC Desktop
All across the screen a lot of black colored dashes are appearing. everything is fine but these dashes doesn't look good
Try selecting Auto Adjust from the monitor's on screen display. Should be accessible from the buttons on the front of the monitor.
Also try downloading and using the latest drivers for the monitor.
Also try checking the monitor's technical specifications and making sure that the refresh rate on the computer is set to the optimal refresh rate per the monitor's manufacturer.
Jun 21, 2011 | Computers & Internet
How do i connect my pc to my LG 32LF77SO I CAN GET SOUND AND VISION
Most HDTVs today have a 15-pin VGA input so to hookup a PC, just connect a VGA monitor cable from the PC monitor output to the HDTV VGA input port. This gives you video. For audio, you can connect a stereo audio cable (3.5mm) from the PC soundcard speaker jack (usually green) to the HDTVs audio input port next to the VGA port. Next you need to adjust the settings for video resolution and refresh rate on the PC so that the HDTV is compatible. Look in the HDTVs owner's manual for a chart showing the acceptable video screen resolutions (1024 X 768) and refresh rates and adjust the PC accordingly. You should now have video and audio on the TV. For a laptop, it depends on what outputs it has, VGA, HDMI or S-Video but this can be done as well.
Mar 26, 2011 | LG Televison & Video
When conecting a pc up no display
Sansui tv's with a PC input are usually 60hz tv's. Try changing the refresh rate on your PC to 60hz. You will need regular computer monitor to make the change on your PC.
May 19, 2010 | Sansui HDLCD-1900 19 in. LCD Television
I bought an HP-desktop from a friend of mine, i plugged it in and it would not load onto Windows screen. I thought the reson may be lack of a Driver for the HDLCD1955. The computer works on a regular...
On current Sansui lcd and led tv's you must change your PC's refresh rate to 60hz to match the tv's refresh rate. How you do this will depend on what PC you have as well as what operating system. I hope this helps you.
Bobya.
Apr 04, 2010 | Sansui HDLCD-1900 19 in. LCD Television
My screen is black when its hooked up to my pc
For a Sansui tv, select the pc input on the tv and change the refresh rate on your computer to 60hz to match the refresh rate on the tv.
Feb 07, 2010 | Sansui HDLCD-1900 19 in. LCD Television
CONNECTING TO PC
On a Sansui tv, select the PC input on the tv. Change the refresh rate on your computer to 60hz to match the tv's refresh rate. You will need a regular computer monitor to do this.
Aug 15, 2009 | Sansui HDLCD-1900 19 in. LCD Television
TV isn't displaying pc image
Double check your refresh rate. It must be set for 60hz for Sansui tv's.
Dec 30, 2008 | Sansui Televison & Video
I have a Sansui HDLCDVD260, 26in Television that I can't get the monitor to work on. TV works fine, DVD player works fine but when I hook up the SVGA cable to use as a computer monitor it just shows a...
After you have set the refresh rate to 60hz and the display mode to the recomended setting, shut down the computer. Turn on the tv and select the pc input on the tv. Connect the computer to the tv and then power up the computer.
Dec 25, 2008 | Sansui HDLCDVD260 26 in. LCD Television
Sansui hdlcddvd26s
Try setting your refresh rate to 60hz.
Sep 07, 2008 | Sansui Televison & Video
Sansui HDLCDVD260 26 in. LCD Television Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
