Question about Sony PlayStation (PS) Console
Console When a disk is in the console the sound from the tv is scratchy and fuzzy, but only at the beginning and end of the disk. I cleaned the disk and it didn't help. I put in another game disk and the same thing happened. It is not the tv or DVD player because the sound doesn't occur when playing a DVD or VHS. I hope this doesn't mean - chuck the player! I hope there is a simple solution! thanks a bunch.
  • teena peardon Apr 29, 2007
    Still have the problem I sent in a couple of weeks ago. To be honest, I am not too impressed with the response time, but I guess beggars can't be choosers! Any info I can get will be appreciated.
My playstation does not read controller conection in order for the controller to work i need to insert a memory card for it to work and for two player games like yugioh in order to play p1 goes and then we hace to unplug the first controller and insert the second one
Posted on May 02, 2007
    President:
  • 2,961 Answers
It may be that the laser is aligning itself after trying to run the disc, you may need to run a cd cleaning and aligning disc in the playstation, although, it maybe that the laser is on it's way out.
Posted on Apr 29, 2007
SOURCE:
TV Screen Goes Fuzzy Every 10 Seconds
Try using the av cables for N64 instead of using the rf switch then.
Apr 30, 2012 | Nintendo 64 Console
How do I fix a fuzzy screen
A fuzzy television screen is generally not the fault of the game console itself, but of your television.
The Xbox 360 is an HD game console, and from personal experience, trying to render an hd image in 480i Standard Definition will cause it to look somewhat fuzzy regardless of the television.
Just to make sure it is not the Xbox, I would, if possible, suggest you try the 360 on another television, preferrably with the HD cables (remember that there's a switch on the cable itself that you will need to switch from SD to HD).
Unfortunately, if you do not have access to a high def television, you can always fiddle with the contrast and sharpness on your standard def TV to reduce the fuzzyness, but the screen will always be somewhat fuzzy.
I realize this is probably not the answer you wanted, but to solve this problem for my own Xbox, I ended up purchasing an inexpensive HD Television.
Nov 01, 2010 | Microsoft Xbox 360 Console
My genesis model 1 turns on but the screen stays fuzzy i tryed the rf out to the back of the tv it still is fuzzy. T try it with the yellow and white wire cords that go in front of the tv still fuzzy...
The game cartridge terminals and the console receiver require disassembly and cleaning as per this service.
It is easy enough to do yourself with the proper tools. If you would like, we can perform this service for you.
Thank you and best regards.
Apr 12, 2010 | Sega Genesis Console
Got a fuzzy sound all the time wen theres sound. u can here the game but sounds fuzzy
are you using the 3 connections white red and yellow to the tv make sure there in correctly if they are try using another cable if the problem persists and its under warranty send it to Microsoft
Nov 14, 2009 | Microsoft Xbox 360 Console
TV screen is fuzzy
Follow the steps below, Hope this helps
1. Try another Av cable ( Audio video Cable )
2. Try another television
3. If the steps dont work, call xbox customer support to have your xbox serviced. Good Luck! hope your console still has warranty
This issue means that your xbox 360 console is having a problem with its Video Card.
Mar 28, 2009 | Microsoft Xbox 360 Elite Console - Black
Today my 360 had a strange problem, there was a scratchy noise from the t.v. and the graphics did some kinda wierd pixelation and the game froze with the screen froze and no sound. The scratchy noise was...
i take it you have tried another game....and as far as the tv goes it may only b that input i work for a cable company and see this quiet often so try plugging the xbox into another input if that doesnt work you may have a bad disk drive or a bad hard drive....like i tell everyone else if you have a friend that lives close buy take it there and hook it up use there hard drive and cables that way you know for sure it isnt the system
Feb 22, 2009 | Microsoft Xbox 360 Console
What is the best way to clean a Playstation 2 console?
if you are having problems with a play station 2, the first thing you need to do is buy a staples cleaning disk. once you have the disk all you have to do is put the CD in and play track 2. this will make your ps2 eye adjust so that the brushes on the disk will wipe it clean of dirt and other stuff.
Feb 18, 2009 | Sony PlayStation 2 (PS2) Console
Screen failure
sounds like ur xbox is about to go red light soon. It is fixable and i can list the steps for fixing it if u'd like. Kinda complicated, but ive fixed 30+ systems using the process
Jan 13, 2009 | Microsoft Xbox 360 Console
Xbox Picture is Fuzzy, and sound makes picture worse
Your TV. Try it on a friends' TV using the proper cables and whatnot and see if that is the prob. I reckon it would be. Oldarse TV's may not handle the newer signal well..
Craig
http://compusure.org
Aug 20, 2008 | Microsoft Xbox Console
Sony PlayStation (PS) Console Logo
50 people viewed this question
Top Sony Video Game Consoles & Games Experts
juanmireles1
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
