Question about Makita Drills
Changing a drill chuck
I cant get the old chuck off of my cordless drill
  • 2,176 Answers
If this is a cordless drill open chuck jaws and remove the retaining screw (LH trheads), switch the clutch to drill only and shift gear selector to low. Insert a bent handle allen wrench about the same size as chuck (to keep from flexing) put chuck on workbench or block of wood and have the wrench about 30 degrees and strike the key counterclockwise to remove. You might have to hit a couple times but usually they will loosen up quickly. To install just reverse above. Let me know if I can help further.
Dave
Posted on Dec 26, 2008
3/8" cordless driver can't change the
If debris enters the chuck it may no longer turn for adjustment. Spray plenty of wd40 into chuck and allow plenty of time for oil to do its magic. Hold chuck/drill pointing down and turn drill in both directions to clean out debris. If chuck is too far gone, remove the center screw (backwards thread) and remove the chuck(threaded on). Replace the chuck with new generic part from Lowes (about $25.).
Sep 20, 2011 | Dewalt Drills
I have a new chuck for the drill need to know how to take it off and put the new one in
Thank you for using FixYa. To change the chuck on your cordless drill, open the old chuck jaws to the maximum. Inside the chuck where it attatches to the drill body, there is a Philips headed bolt. Unscrew the bolt in a CLOCKWISE direction. Reverse this procedure to fit the new chuck.
Hope this helps
Duncan
Mar 04, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Cordless Hammer Drill Sfh 151 A 2.0Ah: Hi, How do you change the chuck on the Hilti SF 15...
Hi. open the chuck to the max. inside the chuck you will see a screw. remove it. put the drill in reverse. hold the chuck. a vice may be needed. pull the trigger. this may work, however in my experience, they are very tricky to get off. I have never had a faulty chuck but have had many faulty gearboxes. i have had to buy ney chuck to fit with the new gearboxes because i couldn't get the good chuck of the damaged gear box. good luck.
May 05, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
Chuck wont come off dewalt cordless drill 18v xrp my chuck bolt insid of the chuck wont come out and i need to know if it is reverse thred or not
i cant say 100% sure for that drill but im betting its not.
it probably has red loctite on it which is very tough to break free. put some heat to it. then it will come easily
Mar 16, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
How to change drill bit on black & decker plus pivot cordless drill How to change the bit on a Skil cordless screwdriver 2362 with a keyless check?
Grab the end of the chuck in one hand, and the outer ring of the chuck nearer the motor, and twist the chuck end. try both directions until it loosens.
Jan 28, 2009 | Drills
Porter cable 884 cordless drill
Most chucks have a tolerance the cordless drills where designed for drill bits 1/8 and larger the 3/8 chucks are a little better with the smaller bits .Check your owners manual and see if they have a min requirement listed for the bit size
Sep 27, 2008 | Porter Cable Cable 19.2 Volt Grip - To -...
Keyless chuck question
this 2 chuck are 3/8 jaw opening,double sleeve u can hold the chuck will opening it at the sametime.the sinlge sleeve u have to runs the drill while running slow rev/for to remove the bit etc.
i prefer metal sleeve.
Aug 18, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
How do you change a chuck on a DW995. I took the center screwn left handed screw out. How do you back the old chuck out? how do you remove the chuck there is no allen key in the center of the chuck
position the drill to speed one & drill mode.u need a allen key then clamp it the chuck jaw close & tight. hit the allen key with hammer counter clockwise until its loosen. may have to do it any several times.
Aug 11, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
u need allen key that fit to the chuck. insert the short end to the chuck. tighten the chuck if u can. hold the drill at the edge of the table & smack the allen key counter clockwise. do it again if needed. but before u do it set the speed to #1 position & drill mode.thanx good luck
Jul 17, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Drills Logo
260 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
