Question about Video Game Consoles & Games
USB driver will not install
I just bought this game for my 9 year old but the USB scanner device driver will not install. I run Windows XP with all the updates and service packs installed. I cannot find any links on the web to a driver. Where can I find one to get this device to work properly.
  • Anonymous Jan 18, 2009
    game will not install .. The dvd drive is not reading the disk
UPDATE!
Posted on Dec 26, 2008
Is there a driver for my Epson Perfection 1200U scanner which is compatible with Windows 10?
Its working perfectly with Epson 2400U drivers.
  • Download and install the Perfection 2400U drivers from Epson USA, version 3.04A http://www.epson.com/cgi-bin/Store/s...rm=OSF_W_10-64
  • Connect and turn on your scanner
  • Run Device Manager
  • The Perfection 1200U will be shown under under Other Devices
  • Select Update Driver
  • Choose 'Browse my computer for driver software"
  • Choose 'Let me pick from a list of device drivers on my computer'
  • UNCHECK the 'Show compatible hardware'
  • Click on 'Epson' in the Manufacturer box, and the scroll down through model until you find "Epson Perfection 2400', and choose that, and press Next
  • Ignore the 'Update Driver warning - choose 'Yes'; to continue to install.
  • The Perfection 2400 will now be shown in Device Manager. Note that the Perfection 1200 will still be shown under Devices & Printers
  • Run Epson Scan and test the scanner. You may need to log out and log in again for program to work
Nov 03, 2016 | Epson Perfection 1200U USB Flatbed Scanner
Tip
USB devices not recognised or not working properly?
Try these steps to reinitialize your usb ports on your pc
1. Unplug ALL USB devices connected to the computer. If you are using a USB mouse and keyboard, temporarily use the older type PS/2 devices if you have them, if you don't then just leave them connected.
2. Hold down the windows key and press r
3. Type devmgmt.msc into the run menu and press ok
4. Click on the + sign next to the Universal Serial Bus Controllers
5. You might need another mouse to do this if you have a usb mouse.. I recommend you get a ps2 connector mouse which goes into the green round connector in the back of your pc.
6. Right click and uninstall first the usb root hubs. all of them then uninstall the rest of the devices you see under Universal serial bus controllers
7. Ones you have uninstalled everything you should see the Universal serial bus controllers there at all.
8. Now go ahead and restart your pc.
9. Ones you have restarted the pc your usb ports will reinstall in a moment stand by while it installs all of them. If you get warning messages click ok or continue installation.
10. Now go ahead and plug the usb devices back in. Install software if required, all usb devices if not faulty or broken should work now. Also note the error code if you get one?
This solution doesn't fix all usb problems so if you have a yellow ! mark there and device status reports a error code. Then it might not be a problem with your usb ports.
Thank you for reading, do leave suggestions, comments, feedback below.
Ekse
usb mouse drivers for windows xp mouse trackball mouse drivers bluetooth mouse computer problems 2.0 usb driver microsoft windows scanner driver usb 2.0 air mouse computer service usb hubs update drivers fix windows computer services computers hub usb usb drivers usb 2.0 hub laptop mouse usb switch 4 port usb 2.0 hub wireless mouse usb driver fix computer windows xp pro usb optical mouse computer support computer repairs update driver 4 port usb hub usb security usb cable windows xp microsoft windows xp computer repair windows xp professional upgrade windows
on May 04, 2008 | Microsoft Windows XP Home Edition
I have downloaded the disc for visioneer 4400 usb scanner. The software is there but Vista says there is no scanner hardware? It had been working on my old desktop but now I am trying to install it on my...
make sure that when you installed the software, that the scanner wasn't plugged into the laptops USB port. That is a known issue with USB devices. If they are plugged in during the install, there's a good chance that they may not work. Always wait for the software to prompt you to plug the device in
Mar 04, 2011 | Visioneer 4400 Flatbed Scanner
How can i install visioneer one touch 8900 usb scanner in Windos 7?
The 9420 visioneer Scanner driver will run the 8900 scanner.
first,go to visioneer and download the .MSI file for the 9420. Run it. The driver files will be found in directory: C:\Visioneer\OneTouch 4.0\9420 Drivers.next, find the 8900 drivers.they will be in c:\ Windows\twain_32\vizscan8xxx. open the file and look for rtscan.dll Rename it old rtscan.dll.if you can't find them,either use Device manager to show you where they are. or you can reinstall the Driver(Xp\2000\Me\Win 89 from Visioneer site. Rename the rtscan.dll file which will be in the twain_32 folder(see above).
copy all the files in 9420 Driver file to the c:\Windows\twain_32\vizcsan8xxx folder. turn your scanner on.windows should find the drivers and install the scanner.
Sep 18, 2010 | Visioneer OneTouch 8920 Flatbed Scanner
Fujitsu fi-4120c scanner on Windows 7
Hi ocdaveymac
Fujitsu fi-4120c scanner drivers can be found at
driverupdate us .
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Mar 09, 2010 | Fujitsu fi-4120C Path-Through Scanner
Canon Canoscan D1259U2F dont have any driver for Windows 7 64-bit
the only successful method I found for using CanoScan D1250U2F in 64 bit Windows 7 (I guess the same would be for 64 bit Vista) is to use Windows XP Mode in Virtual PC (attach the scanner as USB device and that's it - works perfectly)
I had a problem with Windows 7 detecting the device as CanoScan (needed for Windows XP Mode to detect is as USB device and allow attach) - the solution was to unplug the scanner, plug it in and CANCEL Windows 7 hardware detection process before it finishes - this leaves it as "CanoScan" device (auto-detect will leave it as "Unrecognized device" and with that unusable/un-attachable in Windows XP Mode)
latest versions of Windows XP Mode will make your hard drives accessible as network locations (no need for external media)
Jan 01, 2010 | Canon CanoScan D1250U2F Flatbed Scanner
Scanmaker 3800 works perfectly with XP. Vista reports : scanner not readt check connections. Would appreciate a so;ution. Device Manager also reports device is working, No conflicts.
This works for Windows 7 I think it works for vista too:
You can download: ScanWizard 5 version 6.63 Here: ftp://microtek:microtek@files165.cyberlynk.net/microtek/pcfiles/drv_sw5_v6_63_ad.exe
Extract to folder on desktop. 1. Plug in your Scanner 2. Go to Control Panel (Windows 7 - 64 and 32 bit) 3. Go to Device Manager 4. Go to Imaging devices (or Other devices) 5. Find what windows have installed Right Click 6. Update Driver Software.. 7. Click - Browse my computer for driver software 8. Click - Let me pick from a list of device drivers on my computer 9. Click - Have Disk 10. Browse to your desktop or position where you extracted 6.63, point to "....drv_sw5_v6_63_ad\Disk1\Vista\AMD64\..." Pick any of INF files I picked first 11. You will see 4800 Scanner and USB 2.0 Scanner, I picked first 4800 then USB 2.0 and both works.
I managed before to do it with simple install but well, it works .. ;)
Sep 07, 2009 | Microtek ScanMaker 3800 Flatbed Scanner
Umax driver for Vista - Cannot use the scanner since I had a new laptop.
go to the website for umax and you should be able to download the driver you need.
May 20, 2009 | Umax Astra 6400 Flatbed Scanner
Windows can't find driver for FI-5660C
THE PROPER WAY ON INSTALLING USB DEVICES 1. Do not plug in your device right away. Install all drivers and software first! 2. Reboot 3. Plug the power or turn on your USB Device 4. Plug in the USB Port. 5. Windows Will detect the Device Automatically. Finish! Hope this helps.
Sep 19, 2007 | Fujitsu fi-5650C Path-Through Scanner
Video Game Consoles & Games Logo
83 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
