Question about Mitsubishi WS-65809 65" Rear Projection Television
MY 65 INCH MITSUSHI TV FLICKERS ON AND OFF
The picture flickers on and off when we watch TV or any movie constantly then will play regular TV for a few minutes can someone tell me whats wrong and how do I repair it. PLEASE HELP!!!!!!!!!!!!!!!!
  • grfccorp Dec 25, 2008
  • 10,594 Answers
What is the model number of your TV?
Posted on Dec 25, 2008
  • Shahid Electronics
    Shahid Electronics Dec 26, 2008
    Genius:
  • 1,011 Answers
Sir,
POSSIBILITY # ONE: Lamp. The gradation of the lamp illumination versus the mirror reflection rate sometimes produces a flicker effect. Replacing the lamp solves this problem. I know they are kind of expensive, but maybe you can return it if it does not solve the problem.
POSSIBILITY # TWO: A result of the progressive scan and 3/2 pulldown seams in the video stream. When film source material is converted to video (24 fps to 30/60 fps) and then progressive scan converted, there are switching holes that will sometimes produce a instant of no frame or two frames that skip each other. These makes a flicker that is not obvious to some but very obvious to other viewers - and is accentuated with DLP. Or, it could even be the video processor inside the Mitsu unit is not fully developed and is not good at smoothing out the flicker. You would normally see this kind of flicker only on material that was produced on film, such as movies. However, some video productions are produced on film, then converted to tv feed. So, it may be difficult for you to tell which program is film based!!
If there are other possibilities, I would like to know about them. (Cleaning the filter seems to me to be just regular maintenance item. Got to keep if clean and keep the lamp as cool as possible for long life, etc.)
thanks
good luck
  • Asfiya Ahamed
    Asfiya Ahamed Dec 26, 2008
    Sir,
    If u have warranty period claim the new one or call technician for support. Better u must replace lamp (99% will be solved) it would be fixed.
    thanks
    good luck
BROKEN SCREEN
You now have a 55" parts unit !!! A replacement 55" panel will most llikely cost as much as a new set !
Jan 10, 2013 | Samsung 55" UA55C7000 MULTISYSTEM LED 3D...
HOW TO STOP NON CABLE TV FROM FLICKERING
Get a better antenna or if possible a outside one--set can only deal with the quality of signal that it gets.
Dec 21, 2012 | Philips Televison & Video
PS3 Flickers on and off on the screen
Is could be your TV and not the PS3. When the resolution of the screen changes, you TV will flicker to adjust to the new resolution. My TV flickers in a similar way when playing games of lower resolution than my HDTV.
Jul 13, 2009 | Sony Playstation 3 (PS3) Console
Unit intermittently makes the TV flicker the sound and picture.
I would be checking and trying new leads from the antenna part of your telly to where they go into the wall , we had a problem with a new tv that used to turn itself off and on we got the tv replaced with another new one and it still did it . it turned out to be a faulty cable from the pay tv box on top of the telly as they emit FM waves just like the radio and it was sending signals to the remote on the tv to turn it off
May 17, 2009 | Samsung HT-WX70 Theater System
Screen flickers when I play a BD movie on my PS3
Does it do this with all Blu-Ray movies?
Have you tried a different HDMI cable?
Jun 18, 2017 | Sony Playstation 3 (PS3) Console
Flickering
When the TV is flickering, do you notice any noise in the audio? If so, it could be a loose connection inside the set or a High voltage transformer going bad. Does it constantly flicker or come and go. If the latter, can you slap the side of the TV or jar it to get the problem to come and go? If so, it is likely a bad connection inside the set. I'm assuming that when you were playing the movie that you used the A/V input jacks rather than using the tuner on channel 3. Otherwise the tuner could have bad connections or bad grounds inside. A repair shop will most likely have to fix this problem. If the set was over 9 years old however, I'd upgrade to a new HDTV set.
Jan 01, 2007 | RCA P46812BL 46" Rear Projection...
Wavy Picture and Flicker
Now we have here a falure to communicate!!???LOL good movie bacjk in the late 60'S Can you guess what one?? your problem sounds to me like a main B+ capacitor, or a capacitopr off the main scvan sweep dirived power supply> good luck
Jun 24, 2006 | Toshiba 46H83 46" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
37 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
