Question about American Standard 2294.011.020 Afwall Elongated Wall-ADA Retrofit Toilet
The fill valve in my toilet tank leaks.and water level can not be
How do I adjust the water lel in my tank without overflow?
    Sergeant:
    Champion:
  • 239 Answers
There are different fill valves if you have the one w/ two screws on top you have to tie down the one on your left hand side if you have the one w/ a side plastic long screw adjust that one
Posted on Jan 04, 2009
Water keeps filling in toliet even after full
hi Patricia.
Overview Toilets haven't changed much in the last 80 years. After a flush, water still fills a tank, lifting a float that shuts off the water when it reaches a certain level. A lever still opens a flapper to cause the flush, falling back into place when the water level drops. So it's no surprise (nor any consolation) that we face the same flush problems today that our grandparents did. Sometimes the flush is too wimpy, sometimes the toilet keeps running, and sometimes the bowl doesn't refill.
Our ace plumbing consultant has a simple four-step strategy to solve 95 percent of these problems. You can complete the first three steps in five minutes. That'll solve most problems. The fourth step is usually easy too, but not always. More on this later. These steps work for most toilets but not for pressure-assist models.
Check the fill tube
Overflow tube problem
Push the fill tube firmly onto the fill valve. Make sure the fill tube sends water into the overflow tube.Remove the tank lid and find the fill tube. It's a small flexible tube that runs from the fill valve to the overflow tube. While the tank refills, this tube squirts enough water down the overflow tube to refill the bowl after the completed flush. If this tube falls off or the water stream misses the overflow tube, the bowl won't fill and your next flush will be wimpy (that is, won't develop a strong siphon). Reattach the fill tube and make sure it perches about 1 in. above the rim of the overflow tube. Flush the toilet and watch the water stream to make sure it goes down the overflow tube.
Adjust the fill height
Check the float
Adjust the float to set the water level. Pinch the clip and slide the float up or down on the rod. Keep adjusting the float until the water shuts off at the proper level.The water level in the tank is controlled by an adjustable float. A float that's set too low produces a weak flush; if it's set too high, water spills into the overflow tube and the fill valve won't shut off. The toilet keeps running. Look for the fill level mark on the inside back of the tank and mark it on the overflow tube so you can see it more easily. If you can't find it, measure down about 1 in. on the overflow tube and make a mark. Then flush the toilet and see if the water reaches and stops at that mark. If not and the toilet keeps running, adjust the float up or down. If you have an old toilet, you'll have to bend the brass rod that connects to the float ball to make adjustments. But with newer toilets you usually turn a screw or slide a clip along a rod. Flush the toilet after each adjustment.
Also make sure that the water level is at least an inch below the C-L (critical level) marked on the fill valve. You can adjust the height of many valves to raise or lower the C-L.
Occasionally the fill valve simply won't shut off, which means that it's defective. If so, turn the water supply off at the shutoff under the tank. Buy a replacement valve (sold at hardware stores and home centers). You don't have to match the old one; many, like the one shown, fit most toilets. It's a 15-minute change-out.
Adjust the flush handle/flapper chain
Flapper chain fix
Adjust the chain to leave a little slack with the flapper closed. Then cut off the excess, leaving about an inch.A chain that's too short or tangled won't allow the flapper to close and water will continue to leak into the bowl. This causes the fill valve to cycle on and off to refill the tank. A chain that's too long, or a flush rod that hits the the tank lid, won't open the flapper wide enough to stay open for the full flush. You'll find yourself having to hold the lever to complete a good flush.
To avoid these problems, adjust the linkage in the chain to leave only a slight bit of slack when closed. Cut the chain at the rod to leave only about an inch extra to reduce the potential for tangles. Then put the tank lid back on and make sure the flush rod doesn't strike the lid when you press the lever. If it does, bend it down slightly and readjust the chain.
Replace the flapper
Change the flapper
Unsnap the old flapper and take it with you to the store to find an exact replacement. In addition to the closest replacement, pick up a "universal" type.If you've completed the first three steps and your toilet keeps running, chances are you have a worn-out flapper. Turn off the water, remove the old flapper and take it to the store to find an exact replacement. (Hardware stores often carry a wide variety.) Most flappers snap over ears on the overflow tube. Others have a ring that slips over the tube.
Now here's the catch. You may not find an exact match. The range of flapper styles has mushroomed over the last 15 years, and you may find 15 to 20 flapper options on the store shelf. Some packages include specific brand and model information (so note yours before you leave home). Others have a "universal" label. If you can't find an exact replacement, try the closest one and pick up a universal type as well. They're cheap, and the extra one just might save you a second trip to the store! (Avoid the "adjustable" types unless you're replacing an adjustable one.)
Install the new flapper and make sure it opens and closes freely. Then test it. If the toilet keeps running or runs intermittently, you're not getting a good seal. Try a different flapper if the toilet won't stop running.
If you just can't find a flapper that seals, consider replacing the entire overflow tube/flapper. On most toilets (two-piece), this means removing the tank. It's not difficult and you don't need special tools. It'll take you about an hour, and you'll avoid that expensive plumber service call.
if you go to this link it will show you step by step on how to fix it. How to Stop Running Toilet Family Handyman
Nov 27, 2017 | Home
The fill valve will not shut off in the toilet tank. Water continues to run out of the overflow tube of the valve into the overflow tube of the toilet., even after the valve has been adjusted.
After flushing the toilet, water still fills the tank till then the shuts off valve reaches a certain level. When the shuts off valve reach the level it disconnect the water connection to the tank and the filling process of the tank shuts off.
So, if your fill valve didn't shut off then maybe there's a problem with the shuts off valve, open the fill valve and fix it. If you can't fix it call a plumber for it.
Jan 20, 2016 | Keeney Manufacturing Keeney K830-15 Toilet...
Ive replaced 3 toilet fill valve with 440a Fluid master fill valves height is good water level good.After a while it sounds like there is leak by from all toilet.Flappers have been replaced. What coul
check the overflow pipe in the cistern tank as some fill valves do not stop completely but allow input of water after the noise has stopped. This allows the water level to rise up and the water to flow out into the toilet bowl. Reduce the water level height by adjusting the cut off level and when the water rises past the new level the increase pressure on the valve will shut it off.
Sep 16, 2014 | Fluidmaster 400A Toilet Tank Repair Fill...
Have a new 400A and water level is normal in the tank : upon flushing the bowl fills almost to an overflow?
What's wrong with that that's were it should be.with a 2.5 gal tank that water level is corect.Iff think that's too much, adjust the water level adjust clip, by sueezing clip and move it down to adjust the water levelto lower.
Sep 10, 2014 | Fluidmaster 400A Toilet Fill Valve Cap
The water level in the bowl is too low after flushing. Can I adjust it somehow to leave more water in the bowl?
Make sure the fill tube in the tank from the fill valve is in the overflow tibe inside tank. The tube allows bowl to fill with water to correct level.
Aug 30, 2011 | Toto Drake ADA Compliant Toilet with...
The water in the tank continues to leak out and the tank has to continue to refill. I have replaced the flapper, I have taken the tank off the toilet and check gasket alignment. The tank does not leak...
There are only a coulple of places that the toilet could leak or, overflow and give you this problem. When you replaced the flapper valve, did it have an extra piece of rugger on it? Universal flappers have a round piece on them that are designed to fit over the overflow tube. If you flapper had this piece and you don't have need for it, you need to cut that out, if the flapper "hooks" to the overflow assembly. Leaving that piec on can contort the shape of the flapper and make it so it won't seal. If you are noticing constant movement(slight swirl) in the bowl, make sure the back tank is not constantly overflowing into overflow tube. If this is the case, your water level is too high. You will either need to adjust the water level and/or replace the fill valve. If you can hear the toilet running or leaking, push down on the flapper, if it stops, you have a problem with the flapper and/or the chain adjustment. When you install the flapper, you have ton make sure the chain is long enough to let the flapper fall and seal but, not so long that it can tangle or get between the the flapper and it's seal below it.
Jun 19, 2011 | Jacuzzi Home
Toilet system will not completely stop dripping, resulting in constant drip from overflow. How do I stop it?
Is the drip comming from the small fill tube going into the overflow? If so you may need to raise it a little. The nost common leak is from the flapper or seal. On rare occasioms the flush valve itself has a defect that will cause it to leak. Take a close look at the problem and Im sure you will find it. I hope this helps.
May 14, 2010 | Home
How do I adjust tank fill valve to increase water level in toilet?
There are many different fill valves out there so it would be a little hard to tell you how to adjust your particular one without knowing the brand and type of the fill valve.
So I will give you a generic adjustment.
Look for someway/something to adjust your float in the toilet tank.
There should be a screw, moveable metal, something that will adjust your float.
Once you locate the adjustment, you can then adjust your water level in the toilet tank.
Adjust the water level in the toilet tank to be about a 1/4-1/2 inch before it flows out of the overflow tube when the water shuts off.
Good Luck, I hope this helped.
Please rate me, Thanks
Mar 11, 2010 | Home
Toilet tank looses water over time
As long as there is no water leaking from the tank to bowl connection, you are OK. You would know if it was leaking here, because you would have water dripping out onto the floor.
Verify that the water level in your tank is below the top of your new flush valve's overflow tube. If the water level comes to the top, it will overflow into the toilet bowl. This can be easily fixed with an adjustment to the fill valve.
If the water is not overflowing into this tube, then the only way you can lose water is through the flapper. You said you changed the flush valve, which would have come with a new flapper attached to it, but maybe buy a new flapper and see what happens???
Jan 19, 2010 | Eljer Aqua-Saver 12" Two-Piece...
Is there a manual. The water keeps running.
the fill valve shut off level setting is too high. water in the tank is overflowing in the overflow tube. adjust fill valve to shut off at lower tank level
May 12, 2009 | Jacuzzi Bath Era BK37 959 White toilet...
American Standard 2294.011.020 Afwall Elongated Wall-ADA Retrofit Toilet  Logo
281 people viewed this question
Top American Standard Home Experts
Mike
john h
hvd713
Level 1 Expert
Are you an American Standard Home Expert? Answer questions, earn points and help others
