Question about Whirlpool Washing Machines
No cold water. I have hot, but not cold.
I have a whirlpool estate washer and I do not have any cold water coming into my machine.
  • Whirlpool Master
  • 3,463 Answers
Turu off the cold water to the m/c, and hold hose into a bucket or something similar, turn water back on again, and see if you have a supply, if water there, then check the filter i the valve it it has one, and clean if req'd, reconnect hose and try again, if still no cold fill ,then the inlet valve is probably faulty, you will need to replace same.
Plz rate this solution.
Thanks.
Posted on Dec 25, 2008
Rinse cycle does not work. everything else does
Verify water flow to BOTH hot and cold inlet valves. Dirt can plug screens and Dad sometimes turns off water, trying to save $$. BOTH inlet valves need water flow.
Jun 11, 2011 | Whirlpool Estate TAWS750PQ 27-Inch Washer
My cold water on my whirlpool estate wont turn on only hot water works. When i set the cold /cold water water wont turn on . On hot/cold it turns on but only hot water comes out.
first thing to do is of course check to make sure the cold water is turned on.  sorry i had to put that in there.  you can take off the cold hose at the washer and check to see if there is a blockage such as calcium deposits which can block the line. if all that is clear then you will probably need to have the inlet valve replaced.
Jul 30, 2010 | Washing Machines
My new estate washer with 4 water selections actually only has 2, hot and cold. The warm water setting fills with lukewarm water for a while then shoots in cold water for a while and back and forth. In the...
Yes, this is normal. All newer washer have auto temp control fills. This is to meet energy saving requirements. The less hot water used the more energy saved. Most hot settings on washers give out basically lukewarm water. The detergent made today is made to work well with cooler temperature water, so things will still come out clean.
Feb 01, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Cannot get cold water to come into the washer
Turn off the water and reverse the hot and cold water connections going into the faucet, then turn the water back on. If only cold water comes out of the unit when on hot temperature then you need to order a water valve solenoid which I suspect is the problem or wash only in cold water. They are replaced by removing the back washer panel a couple of bolts, one connector, and two hose clamps. Remember to restore the hot and cold water connections.
Jul 14, 2009 | Whirlpool Washing Machines
Hot and cold water mixup
Switch the lines and grin and bear it!!
Jun 20, 2009 | Whirlpool Washing Machines
Spin cycle not removing enough water from clothes
your manual states that it can be caused by cold rinses and or spin cycle not getting completed. please try to rinse in hot or warm and see if that does not solve your problem
Dec 20, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Cold water dosn't come out
Close your faucet valve on wall & unscrew your hoses to check screens on hoses & machine. Clean out well. See that the water pressure is good. Refit, check for leaks. If this is not the problem change your inlet valve, it is easily done.
Sites for spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Pl rate if helped.............
Jun 09, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Cold water won't come out on Estate washer by Whirlpool? Why?
HI THANKS FOR THE QUESTION . tHE PROBLEM WITH YOUR WASHER IS THAT YOU NEED A NEW WATER VALVE .tHANKS FORTHE QUESTION tHE APPLIANCE DOC
Jun 09, 2008 | GE WHRE5260E Top Load Washer
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washing Machines Logo
83 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
