Question about Sansui HDLCDVD260 26 in. LCD Television
I have a Sansui HDLCDVD260, 26in Television that I can't get the monitor to work on. TV works fine, DVD player works fine but when I hook up the SVGA cable to use as a computer monitor it just shows a blank screen. I have adjusted my refresh rate to 60hz as instructions say and I still have nothing. Can you help
  • schurky56 Dec 30, 2008
    I have a 19" Sansui flat screen that does the same thing. Everything else works fine, except nothing happens when connected to the computer. I've called the customer service number, and got the same answer from a number of of technicians?? change the resolution and refresh accordingly. Which I have, still nothing. Is my computer too old, or not compatable? It's a 2002 Windows XP version.
I have a same Sansui HDLCD 2600 which did not have anything happen when try to switch on. no lights even on the power led. where can I get the replacement parts?
Posted on Jun 28, 2009
  • Sansui Master
  • 520 Answers
After you have set the refresh rate to 60hz and the display mode to the recomended setting, shut down the computer. Turn on the tv and select the pc input on the tv. Connect the computer to the tv and then power up the computer.
Posted on Jan 01, 2009
Hooking dvr up to tv with a 15pin svga tv says change source resolution?
I have several DVRs, and have had similiar problems. I would first plug the DVR into a monitor and make sure it works. If so, then while you can see the menu, change the resolution.
Oct 27, 2017 | Philips Lm181e06 Lcd Panel Grade A Lg Dell...
I bought a dvd player i also i have direct tv not sure if cords are hooked up correctly
Read ur DVD player owner manual?The DVD player have a HDMI hub.Used a HDMI cable to hook up the DVD player are the easiest way.The Satalite Direct Tv is working,fine on ur tv right?So don't worry about it.
Sep 30, 2010 | Maxent MX-27X1 27 in. HD-Ready LCD...
My dvd player is a jvc oct. 1999 it is connected to the tv. through a modulator, all the wires hooked up right for sound. The t.v. sound works but when the dvd plays it does fine but no sound. the serial...
Are you by chance using a SVGA cable alone? I am not sure of your cable configuration, but the SVGA cable only sends video.. this sounds like your issue. Check your cables to the modulator box from the DVD to make sure the RCA jacks are from audio l/r out on the DVD to ausio in on the modulator.. hope that helps..
Stan Skaggs
Sep 28, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
NO SOUND FROM DVD
Try different sound settings in the dvd menu.
Oct 15, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Cables
Greetings 4mother,
It would really depend on what type of hook up you are using. Most of the time a plasma television would be hooked up with either and HDMI or component cables. Your local store should be able to make a solid recommendation based on the items hooked up to your television such as cable or satellite box, dvd player, etc.
I hope this helps.
Thank you,
Dorothy
Go Ahead. Use Us.
May 10, 2008 | Pioneer PDP-425CMX 42 in. Plasma...
SANSUI HDLCD2600 TV W/DIGITAL TUNER
This is likely your DVD player, not the tv.
First go into the setup menu of your DVD player and make sure "subtitles" are turned off.
Next, put a DVD into the player and when it gets to the menu, go into the audio setup.
If subtitles are turned on, turn them off. If subtitles are turned off, turn them on and exit the menu, then go back into the menu and turn them off again. I've seen this reset this same problem on some DVD players.
May 06, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Sansui 42" Palsma
I assume you are saying that the DVD player only has RCA jacks. It would be good to know if the DVD player has Component output as that is the preferred output. You will know this if the RCA jacks on the DVD are color coded green, blue and red.... You would by a set of component cables, hook to DVD matching colors and then find the same color code on input of the TV. You must also run the red and white cable from the DVD output to the TV input for audio. The input on the TV would be labled component in or input and a #. Simply select the input, or source button on remote to select the input that matches your choice and all should function. If there is no component on the DVD output and only a composit hook up (color code by yellow, red, white) again just match that to the corresponding input on the TV.
Jan 06, 2008 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
SANSUI 218 - 250gb DVD Recorder Black & White
Send it back under warranty -- needs new main board.
Rudolf
Oct 20, 2007 | Sansui VRDVD5000 DVD Recorder/VCR
Sansui HDLCDVD260 26 in. LCD Television Logo
445 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
