Question about DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder
I want to run my DVD player through my DVR player.
I hooked my DVD plug in's, (red end, yellow end, and white end), to the input jacks on the back of my DVR. I do not get an input signal or either I am not looking in the right place to get the signal. Any tips or is this a possible scenario?
  • 374 Answers
Dish network receiver only have outputs. There are not any inputs on the receiver that would allow this but if your dvd player has an iput source you could run the Dish receiver to it and then the dvd player to the TV. Sorry to be the bearer of bad news. Thanks for using FIx Ya and let me know if I can further assist you.
Posted on Dec 31, 2008
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
Can't hook-up RCA wires in back of tv, dvd recorder,and directtv dvr I don't know which go to input or output red, white, yellow
from your dvd,plug the yellow to video output red and white to audio output. then plug the other end of the yellow to video input on tv and the red and white to audio input on tv. from tv, plug the other rca cable yellow to video output and red/white to audio output and the the other end yellow to dvd recorder video input and the ed and white to audio input
Nov 13, 2010 | Hyundai Televison & Video
Whehe do plugs go on back of unit? have direct tv
First off, you need to hook up audio and video by using an A/V cable to connect the DVD player to the TV, yellow, white and red jacks are coded, match the jacks up, put one end of A/V cable to DVD player OUTPUT jacks and the other end to INPUT jacks in back of TV. Also same with Direct TV receiver, hook top set of jacks to TV, with A/V cable, also connect coaxial cable from satelite to matching satelite input jack. Connect power cables, and then you're set. Good luck to you!
Dec 12, 2009 | Televison & Video
How do you hook a dvd player up to a hitachi vcr?
Not knowing the model VCR or TV your asking about here is the most common connections. You will need a video/audio RCA patch cable. This type cable is always included when purchasing a new audio or video appliance. If you don't have this cable they are available at your local Radio Shack, Best Buy and other electronic stores.
On you DVD player locate the three OUTPUT connectors at the back of the unit and plug one end of the color coded (yellow, white, red) patch cable into the corresponding jacks.
Plug the other end of the patch cable into the VCR INPUT jacks, once again matching the yellow, white, red, at the back of your VCR.
That's It!
To see your DVD player on the VCR be sure to select INPUT or LINE on your VCR remote. Some VCR's have an additional set of input jacks at the front of the VCR, usually labeled Front or Line 2. Use whichever one is most convenient.
Aug 29, 2009 | Televison & Video
Cannot get DVD's to play on our TV.
It depends on what kind of inputs your TV has; here are a few of the most common, all of which your DVD player supports (best quality first):
1) COMPONENT VIDEO (Red, Green, Blue)
If your TV has three inputs for video colored red, green, and blue, this is your best bet for quality video from your DVD player. You may need to buy a component video cable from the store (somewhat pricey, but great quality) which consists of three cables (again, red, green, and blue) stuck together. Just plug the red/green/blue cables into their correspondingly-colored ports on both the DVD player and the TV.
That covers your video. To set up audio, you just need some regular red/white RCA cables. On the DVD player, plug the red/white cables into the correspondingly-colored audio out jacks NEAREST to the red/green/blue cable you used earlier for video, then plug the other end into the audio in red/white jacks on the TV.
2) COMPOSITE VIDEO (Yellow)
If your TV has a yellow input for video, just use a regular yellow RCA cable. Plug it into the yellow video-out jack on the DVD player, then plug the other end into the yellow video-in jack on the TV.
To set up audio, you just need some regular red/white RCA cables. On the DVD player, plug the red/white cables into the correspondingly-colored audio out jacks NEAREST to the yellow cable you used earlier for video, then plug the other end into the audio in red/white jacks on the TV.
3) COAXIAL JACK (Antenna port)
If your TV only has a coaxial jack that you currently plug your antenna or cable line into, you'll need to buy an RF modulater and a short length of coaxial cable (you can find these anwhere: Walmart, Radio Shack, etc).
Plug the RF modulater into an electrical outlet, then plug your antenna/cable line into the "antenna in" jack on the RF modulater. Take the coaxial cable that you just bought and plug it into the "antenna out" jack on the RF modulater, then plug the other end into the antenna/cable jack on the TV. The RF modulater should have a switch on it somewhere that sets either the number 3 or 4; depending on which number you pick, that's the channel that your TV has to be switched to to view the DVD player.
Now you're all set to connect to your DVD player. Just follow the instructions in section (2), only now you're going to plug your cables in the RF modulater instead of the TV.
(I hope this wasn't too confusing; it really is a lot simpler in practice than it is in explanation...)
May 04, 2009 | Televison & Video
I just had directv hooked up, I have a dvr receiver, I was told I did not have enough hook ups on the back of my tv, so therefore, I went and bought a switch or combiner. Now, how do I need to run the...
Newer directv hd receivers must connect to the av input (yellow,red, white) connections on the back/front/side of your tv. If your tv only has one of these av inputs then you will need an RF modulator for your dvd player. You will connect the (yellow,red, white) connections from the dvd player to the rf modulator and then connect the tv out on the rf modulator to the tv rf jack ( the silver threaded barrel on the back of the tv) Tune your tv to channel 3 to watch a dvd and then back to the av input channel for the directv receiver.
Apr 14, 2009 | Directv D11 DTV Receiver
I'm confused how to connect my DVD player with the TV. which cables connect where. I dont have a user manual.
Mukhhe,
good day,to connect your DVD to TV screen follow this steps.
1) prepare your RCA cable ( 3 colored cable yellow/red/white)
note: always remember this
yellow = video
red and white = Audio (left and right)
2) at the back or front display of your TV screen you'll see RCA socket marked as "AV1 input" "AV2 input" etc... if your screen is only mono sound you can only see two sockets Yellow=video white= audio
3) at the back of your DVD player connect the RCA cable following the color code yellow to yellow white to white and red to red. after you connect the cable to your dvd player now connect the other end of thr RCA to your TV screen input.
make sure you'll connect it to "A/V input" not "A/V out" then after connecting all the cables, from the remote commander of your TV screen press a button indicating "A/V" some mark as "TV/AV" press this button until your screen display the back ground display of your DVD player.
cheers,
mark
Jan 30, 2009 | Spectroniq PDV-70X
I am hooking up a dvd player with the black and white wires
The most basic hook up you can do is use a composite AV cable(yello/red/white). This cable should have come with your player. Check your TV it has those available inputs. They are also color coded. On the back of your player, there is only one yellow colored jack so there should be no problem in identifying where to plug the composite video cable(yellow). Put the composite audio cables (red and white) to the DVD player Audio Out jacks (red and white). Then plug the other end of those cables on the back of your TV. Just make sure they are INPUTS on the TV and colored the same - yello/red/white.
Then find your TV's correct viewing channel. It is not channle 3 or 4. Depending on the TV brand, it may be called AV, INPUT, VIDEO, GAME, SOURCE, AUX, EXT., etc. To find that channel, you may need to check the instructions on your TV manual. Most of the time, there are buttons on the TV remote control or on the TV itself. Sometimes, you need to go into the TV Menu.
Mar 27, 2008 | Philips DVP5140 DVD Player
DVD player hook-up problem
Using the composite video connection method is pretty straightforward. you will be dealing with one video cable (marked in Yellow), and two audio cables (marked in White and Red) Red is right channel and white is left channel if stereo, if mono use the white marked cable. Look at the back of your DVD player you will see the video out RCA jack (marked in yellow) plug one end of the video cable into this jack, the plug the other end of the cable into the TVs Video In jack (marked in yellow) Then plug the audio cables into the Audio Out RCA jacks of the DVD player Red marked cable to red jack White Marked cable to white jack. After this is done plug the ends of the sother side of the cable into the Audio input of the TV white to white, red to red. At this point you should have video and audio once you set the menu of your tv to accept input from the Composite input and the audio jacks. I hope this helps.
Sep 10, 2007 | Televison & Video
DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder Logo
223 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
matt martin
matt martin
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
