Question about Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2 OHMS => Model PV2000 Car Audio Amplifier
Peavey xr680c mixing amp has power no sound
Had sound system hook up working fine, then all of a sudden no sound coming from speakers , but has power on head lights up and all ; also has a little humming sound on coming from head ...Thanks Greg
SOURCE: Peavey PV215 Speakers
Posted on Aug 30, 2008
  • 476 Answers
SOURCE: Peavey SP5
depends who assembled the speakers as to wheather or not there is any fuse proetection installed.
The drivers are probably gone from the highs because of overloading power surge on the same circuit as the cash register,
the crossover is failed.
Cheap fix is replace crossover
expensive fix replace cones of speaker
Best long term protection is to split up the power loading on the stage and surge/spike guard power boards for staging equipment & have resettable fuses installed at the crossobvers or the respective speaker connections.
Posted on Jan 14, 2009
  • 1175 Answers
SOURCE: peavey amp
You could also use speakers rated less than 400 RMS provided you dont crank the volume knobs all the way up.
I think the CS400 is 200 Watts RMS per channel into 8 ohms
400 watts bridged
Here's the manual. You'll need acrobat to open it.
Posted on Feb 16, 2009
  • 1175 Answers
SOURCE: peavey cs400 amp
That 28V RMS means how many RMS volts max comes out of the speaker terminals.
As long as your speakers can handle a couple hundred watts , youre fine.
Posted on Mar 01, 2009
SOURCE: peavey eurosys 500 watt 4 ohm pa speaker fault.very low volume.
Indeed, sounds like a blown voice coil. Peavey Eurosys cabinets use Scorpion drivers, which have field-replaceable baskets. I assume the cabinet is a Eurosys 500XT? If so then you need a 15" replacement basket - part no. 15425 - about £75, but cheaper than replacing the entire speaker. Can purchase from
Posted on Jul 05, 2009
Peavey sp2 pa speakers quit working
First of all i need some more information, such the power amp you've hooked to them rating in watts and please specify if you are not getting sound from tweeter or 15" BW speaker or both of them, this way i can improve accuracy helping you out.
Feb 03, 2013 | Peavey SP2 PA Passive Speaker
Wish to run sm450v2 Mackie powered speakers thru a Peavey XR8600
The Peavey XR8600 is NOT just an amp, but a powered mixer.
To SAFELY use this with your powered speakers, connect those speakers to the MAIN and MONITOR outputs on the front of the unit with 1/4 inch INSTRUMENT rated cables (NOT speaker cables).
To safely leave the power amps in the XR8600 with no output loads, plug GROUNDING plugs into the POWER AMP 1 and 2 input jacks on the front. This will prevent the power amps in the XR8600 from running with no load which COULD damage them.
Make the grounding plugs from 1/4 inch mono plugs by jumpering the centr aand sleeve terminals of the plug.
Jul 09, 2010 | Peavey Audio Players & Recorders
Peavey XR800F 8 channel - I can't get but very little sound to my big speakers. Help
Troubleshooting is always a "process of elimination." Have you tried hooking up your Peavey powered mixer to another set of speakers? How about connecting the speakers to another audio system? Your term "very little sound" could mean audio input problems, mixer/amp settings or failure and possibly speaker damage (internal passive crossovers). Please be more specific.
Jun 12, 2010 | Peavey Pv 2600 Power Amplifier
No sound coming out of speakers when turned on
If you get absolutely no sound, not even a pop when changing the standby switch, this probably means the rectifier OR the switch has failed. The red light just means power is getting to the power transformer... probably fuse is OK.
Sep 27, 2009 | Peavey Music
Horns don't work on sp2 speakers
I've got Peavey SP2's and SP4XT's and they have one common problem. The 22XT Driver needs replacing from time to time. It could be a power spike, overdriving from amp, over heating or dirt/water in horn. The driver is very easy to replace and costs about $40.00. Remove the horn, carefully lift the horn and disconnect black and red wires. Remember red is always +. Remove driver from horn with socket wrench or socket screwdriver, clean the circular gap on horn with masking tape to remove dirt, hand tighten driver screws, connect red and black wires, carefully set horn back in SP2 enclosure and slowly bring up the power. Also be sure to be very careful when setting the new driver/ coil in the horn. You don't want to damage the coils on the new driver at all!
Jun 02, 2009 | Peavey CH1 Speaker
Peavey PR15-D Powered speakers, Power on but no sound.
Check for impedance ( resistance) in ohms on the speakers disconnected from the circuit using a volt/ohm meter. I think the woofers are 8 ohms and the tweeters are 8 ohms. Also check for bad solder joints where the jacks are soldered to the circuit boards.
May 31, 2009 | Peavey Pv 2600 Power Amplifier
Hooking up sound system
The RSQ player goes into the input section of the mixer.
The mixer effect send goes to the Quadraverb input and the output of the Quadraverb goes back to the effect in on the mixer. Now the Main out on the mixer goes to the EQ then the EQ goes to the compressor/limitor to power amp to speakers.
Apr 02, 2009 | Stanton Sa3 DJ Mixer With Eq System
Two amp
I don't know why you'd set the Peavey to 2 ohm to drive 8 ohm speakers??? My other thought is... I wonder if the phase is correct. try reversing one of the speaker wires Left or right side.
Feb 27, 2008 | Harman Kardon AVR 630 Receiver
Car Audio & Video Logo
100 people viewed this question
Top Peavey Car Audio & Video Experts
Tom Chichester
Are you a Peavey Car Audio and Video Expert? Answer questions, earn points and help others
