Question about Weber Gas Go-Anywhere Grill
Gas grill My Weber gas grill will not light. Propane tank is full and new.
  • Lynn Smith Apr 15, 2007
    The grill is a stand-alone, auto-start, full-size grill.
  • 944 Answers
If you are sure that gas is coming out of the burner(s) at a roughly normal rate, then the only way it will not light is if you have a bad tank of propane. If you mean it lights but wont stay on, then the safety thermocouples (need to be hot to allow gas to flow) may be faulty - more likely somehow out of position - they can be gently bent back into place but not more than a couple of times. (the way to check if these are the problem is to make sure you are lighting the grill with the control knob in the "light" position - usually held in for a few seconds - this will bypass the thermocouples) If the problem is that the autostart feature is not working, then please post back with details and we can hopefully help identify the problem. Hope this helps - please post again with more info if not :)
Posted on Apr 21, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Apr 21, 2007
    P.S. if the gas is not coming out of the burner at all regardless of the position of the control knob, then there is either damage/blockage to the supply pipes somewhere, or more likely the gas regulator is somehow blocked/stuck or faulty - these do have a tendency to corrosion and can often be fixed with a bit of WD40 or similar and a sharp whack - else replace the regulator, they are not too expensive.
Why won't my Weber grill ignite after installing a
Disclaimer- be careful when working with gas. Starters in gas grills are just about novelty anymore. Often, they only light 1/3rd or 1/4th of the burners and they usually stop working within one grilling season. I recommend using a wand lighter. Try to light just one burner but if doesn't light in 5 to 7 seconds, turn the gas off and wait to try again. Incidentally, you are turning the gas on at the tank, right? You should hear it when you turn the burner on.
Apr 24, 2012 | Grilling
My grill has full propane bottle but doesn't seem to be getting propane! Any help would be appreciated.
Check there is gas at the burners and that the orfices are not block or the burners are bot blocked .
Turn on burners let pressure out of line turn off tank remove gas line then reconnect to tank and turn on tank slowly see if this works
Mar 12, 2012 | Weber Baby Q Grill
How to change a weber natural gas grill to propane
According to Weber, "There is no conversion kit available to convert any Weber gas grill from one gas type to another. Any attempts to do it will void your warranty."
Sorry, but if it's any consolation, Propane Gas burns cleaner and hotter that Natural Gas in an outdoor environment. Which translates into faster preheating and hotter searing temperatures.
Hop e this helps and happy Grilling!!
Mar 19, 2011 | Weber SUMMIT S-620 Propane Grill
My weber genesis silver starts up, but doesn't get hot enough to cook the food. Seems like not enough flame out of either front or back burners. I tried Outting in a full propane tank, but that didn't...
Try these steps in order.
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
  10. Your grill should now heat normally
Sep 06, 2010 | Weber Genesis Silver B Grill
I have a Weber Q grill, propane tank is full but propane is not getting to burners. I do have a spark when I press the ignition. Where is it likely to be plugged up?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Aug 20, 2010 | Weber Q300 Grill
Can't light the bbq
You make have turned the propane tank valve on too fast. Close the valve, disconnect it, reconnect it and very slowly turn the tank valve back on. That should solve your problem.
May 31, 2010 | Weber Genesis E-310 Gas Grill
Genesis GE310 Gas Grill: I just installed a full propane tank on my Weber, ...
Maybe just clearing air out of the line, other than a minute would not be normal.
May 18, 2010 | Weber Genesis GE310 Gas Grill
Weber Spirit one month old...went out, changed tank, won't light
The regulator that comes with Weber grills shuts the gas flow off if it detects the slightest leak. Disconnect the tank an reconnect. Check connections with soapy water for any leaks. Another problem, though uncommon for a new grill is a defective regulator. You have a 1 year warrenty on your grill so contact Weber if you continue to have problems.
Apr 26, 2010 | Weber Spirit? E-310 Propane Grill
New Tank won't light Weber Grill
Try checking the regulator, this is the round metal piece connected to the gas line. If this is not level flat the valve inside will not let propane flow through.
Apr 15, 2010 | Weber Spirit? E-310 Propane Grill
Grill willnot light
there is a blockage in the line!!!
Jun 10, 2009 | Weber Genesis Silver A Grill
Weber Gas Go-Anywhere Grill Logo
457 people viewed this question
Top Weber Grilling Experts
Paul Carew
Marvin
Marvin
Joseph Hoffmann
Are you a Weber Grilling Expert? Answer questions, earn points and help others
