Question about Bose Acoustimass 10 III System
How do I connect my Bose 201 speakers to my Bose 3-2-1 system?
There are no external speaker jacks on the Bose 3-2-1 system for additional speakers. Is there an adaptor available to split the speaker lines? I find nothing on the Bose website.
I want to run a line to the Bose 201 speakers into a nearby room for music.
Thanks!
  • Anonymous Mar 31, 2014
    Need more speakers for l1 system
  • 55 Answers
You cannot hook up more speakers to the bose 321
Posted on Sep 21, 2009
Connecting a turntable to a Bose 3.2.1. Series II
Bose 321 GS Series II DVD Home Entertainment System is a newly redesigned, sleek media center that includes a DVD/CD player, AM/FM tuner and inputs for three additional sources. The 3 2 1 GS Series II system now has even greater ease of use and setup. The 3 2 1 GS Series II system is for customers who want the benefit of home theater sound but would prefer the simplicity of two visible speakers, a hideaway Acoustimass module and fewer wires so they don't need to run wires to the back of their room. Media center plays - DVD video (including progressive scan formats), AM/FM, CD, CD-R, CD-RW, digital 5.1, and MP3 files on CD AM/FM radio includes 20 presets, scan and seek Three audio inputs with both analog and digital coaxial jacks, and one optical digital audio input, provide greater setup flexibility Dimensions - media center, 31/6H x 133/4W x 99/10D (8.02 x 34.93 x 25.27 cm); speaker arrays, 21/2H x 51/2W x 41/8D (6.4 x 14.15 x 10.52 cm);module, 141/2H x 83/4W x 191/8D (36.7 x 22.2 x 48.5 cm) Weight in carton - 44 lbs (20 kg) One-year transferable limited warranty
and from the review
Audio-input connectivity is a bit more robust. You can connect three audio sources through analog or digital jacks. The system is compatible with MP3 CDs and can decode Dolby Digital and DTS surround soundtracks from DVDs and external sources.
Bose 3 2 1 GS Series II DVD system review
May 14, 2017 | Bose Audio Players & Recorders
Connecting tv external speakers
If you connected R/W RCA cables to the AUDIO OUT RCA jacks on the rear of the TV and connected the other ends to the TV AUDIO IN jacks on the receiver, you should be able to select an input on the receiver that will deliver sound to the Bose speakers. If you went to TV setup and selected external speakers, you directed output from the TV amplifier to external speakers which is not what you want.
Jan 27, 2014 | Televison & Video
I have a wireless speaker system that home base plugs into an external music source, can In somehow connect it to the Bose 3-2-1?
Yes, it can. The Bose rear panel has RCA jacks for right and left channel audio outputs. You'll need a connecting cable with RCA plugs on the Bose end, and whatever kind of input connector your wireless speaker system needs.
Jan 13, 2011 | Bose 3·2·1 Entertainment System...
Adding Spaekers
If it's an original 321 system (series 1) then it has an audio output on the back. (via RCA jacks) You would still need an amp or receiver to connect the speakers to.. (unless they're powered speakers)
If it's a 321 series II or 321 series III- it does not have an audio output.
If the system has a DVD tray right in the middle of the media center, then it's a series 1.
Otherwise, you'd have to get a 1/8 splitter to come from your Mac's headphone output. (still- you will need an amp/receiver or powered speakers to have both 'rooms' playing the same thing from your computer)
May 29, 2009 | Bose 3 2 1 GSX System
Trying to connect external speakers
check with radio shack to see if they have something that will plug into the rear jack of the Bose...and has leads that you can wire to your speakers
May 27, 2009 | Bose Wave Music System CD Shelf System
Brookstone Wireless Outdoor Speaker with Bose 123 System Problem
AUX usually refers to an INPUT, such as a CD player, etc. No signal comes out of a standard AUX jack, unless it specifically says "Aux speaker output". Instead, look for another speaker output jack, such as remote speaker, B speakers, etc. You may only have one set of speaker output jacks, in which case you would need to connect your wireless speaker to the speaker output jacks along with your main speakers, or buy a little speaker selector switch box to switch between main and wireless speakers. There's usually no harm in connecting more than one speaker set to the same outputs, though it is technically not recommended. In the real world, just don't crank it too loud and you'll be fine. The wireless speaker MIGHT run off of a standard line output also, if the wireless speaker has its own power amplifier.
Dec 15, 2008 | RCA WSP150 Main / Stereo Speaker
Can I hook my TV directly up to Bose 201 speakers?
It depends on the TV audio output connections. Most TVs have low level audio outputs (RCA Jacks) that require a amp but some do have external speaker connections. You will have to refer to your manual or check the back of the set.
Nov 25, 2008 | Audio Players & Recorders
Am setting up a bose GSX 3-2-1 home theater
Need to know the TV connections. On newer TV's there RCA jack connection or ext speaker connections. Usually the external TV speaker connections hook to the woofer and the rest of the speakers are connected to the woofer. The woofer acts as the sound system for the rest of the speakers. With this method you need to mute the internal TV speakers by a swiich on the TV or internal TV setup menus and select ext speakers.
Jan 26, 2008 | Bose Cinemate Digital Home Theater System...
Bose Acoustimass 10 III System Logo
686 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
