No sound output - Computers & Internet
    Scholar:
  • 118 Answers
Check the following: 1. Volume Control on the media player 2. Volume control on the operating system 3. Volume control on the speaker, AND the power 4. Check the speaker plug, is it correctly inserted to output/speaker port of audio card? 5. Check your audio setting in BIOS, is it correctly set and recognize by the operating system?
I provide general answer to general questions, if you could be more specific (like type of OS, type of motherboard, media player software, etc.) I can provide more specific answer.
Posted on Dec 26, 2008
Audio output only out of one output
hello sir,
often this is sound IC fault, if one IC there change it and it will fix the other audio output, as the sound IC have two outputs and one of it doesn't output the audio,
if two sound IC's, it's a must one of it is faulty, you better change both for long run of the audio amplifier
good luck
Oct 18, 2015 | Car Audio & Video
When I plug-in my vp1220f floor monitors in to the monitor mix on the pmp 2000 i get no sound or little sounds
If you are referring to the "monitor" output , this is a Pre-amp output which connects to a power amp or speakers that have built-in power amps. The Monitor output is a high impedance output. This output will not drive speakers directly.
Jun 02, 2014 | Behringer PMP-2000 Powered Mixer
I would like to connect my computer to my panasonic sa-ht800v unit and hear the sound thru the surround sound speakers
In general, your PC's sound card (and its controlling software) will determine what it can connect to.
Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts to RCA pair for analog audio connection. Any Line Level input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
The SA-HT800's single LINE Input would accept the Green stereo audio or speaker output from a standard PC, once adapted. Select VCR.
Find your PC's Sound Controls and enable the applicable input. make sure the volumes of both Inputs and Outputs are turned up.
Though not applicable to theGemini, more-advanced sound cards and audio hardware would have similar adaptable 5.1 or 7.1 (paired) analog outputs and / or digital audio outputs that conform to the s/pdif or Dolby Digital standards.
Mar 26, 2011 | Panasonic sa-ht800V Home Theater Audio...
Some my movie(HD) have no sounds output
The likely cause if only some of your movies have no sound output is that your sound system or sound card do not support or do not have the codecs for the sound output that movies sound is encoded with.
Mar 08, 2011 | Computers & Internet
No sound from the HDMI
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector for connecting a monitor or TV. If you use HDMI to connect your display, you must activate HDMI sound by adjusting your Windows settings . If HDMI is not activated, you cannot hear any sound. Because of this, HP recommends that you connect analog speakers to the computer to hear sound during the initial setup of the computer. Use the following steps to activate HDMI sound on your computer: NOTE: If you ever perform an HP system recovery, you must repeat this procedure to activate sound for the HDMI connector.
  1. Right-click the Volume icon by the time in the lower-right corner.
  2. Click Playback Devices . The Sound window opens.
  3. On the Playback tab, click Digital Output Device (HDMI) if it is listed. If it is not listed, click Realtek HDMI Output . Figure 1: Digital Output Device (HDMI) selectionc01503048.gif Figure 2: Realtek HDMI Output selectionc01063625.gif
  4. Click Set Default .
  5. Click Apply .
    • If you used Digital Output Device (HDMI) , click OK to close the window. This completes the steps to activate HDMI sound.
    • If you used Realtek HDMI Output , continue with Step 6.
  6. Double-click Realtek HDMI Output . The Realtek Digital Output Properties window opens.
  7. Click the Supported Formats tab.
  8. Place a check in the 48.0 KHz check box, and make sure that there are no checks in the Dolby Digital check box and all other check boxes. Figure 3: Supported Formats settings in the Realtek Digital Output Properties windowc01503049.gif NOTE: For most TVs to play back audio, the sample rate must be 48.0 KHz.
  9. Click OK to close the window.
Nov 23, 2009 | HP Compaq Computer Speakers
The left side main output won't put out any sound on my Denon AVR-900.
connect your right speaker cable to the left output, if the sound comes out then the problem is on the left speaker ( the cable or the speaker itself ), but if still no sound, then the problem is on the power output of the unit, need to repair them
Oct 20, 2009 | Denon AVR-900 Receiver
I cannot get any sound output from my Acer Aspire T180 desktop PC. I changed the monitor from the original "out of the box" monitor. I have plugged in media speakers but there still is no sound output.
Sounds like a driver problem.
You should be able to get a universal Realtek driver from here.....
http://www.everydriver.com/?t=computer&m=realtek&p=download%20drivers%20for%20realtek&gclid=CIzMwe2-_ZwCFc0B4wodGHlNag
Sep 19, 2009 | Acer Aspire™ T180 PC Desktop
Sound
  • check the following
  • check speaker &its wire & connector for loose.
  • check supply to sound output stage.
  • check components related to sound output stage.like low value resistor & coupling capacitor.
  • check for loose print in sound output stage.
  • hope this will help.
Oct 11, 2007 | Emerson EWF2704 TV
Computers & Internet Logo
61 people viewed this question
Alun Cox
David Payne
David Payne
