Question about Nikon ProStaff Laser 440 Rangefinder
JUST GOT LASER 440 FOR CHRISTMAS AN CAMT GET IT TO COME ON AN WOR
We tested the battery an it tested good. We can not get the laser to work an range find anything an we are not sure we know how to work it. Can you tell us what to do? My son is very upset an I need help to make it work. Its serial number isVJ339581. It complies with 21 CFR 1040 10 1040 11. Thanks for your help. Sonya
  • 100 Answers
As far as I know, you point it at something a distance away and press the power button. They're a very simple device but will likely not work indoors or over very short ranges.
If you're still having problems with it, it should still be under warranty, I would return it to the store immediately. If you have any issues with the store staff, do not leave the device with them and contact Nikon directly for help with warranty. You should never have issues with a product out of the box.
Posted on Jan 11, 2018
2 Suggested Answers
SOURCE: Nikon ProStaff Laser 440 not working
Here is the address to send your rangefinder for repairs.
  • Nikon INC.
  • 841 Apollo St. Suite 100.
  • Elsegundo, CA 90245-4721
  • Attention: Repair Department
  • Phone (800) 645-6678.
I had the same issue with my Nikon Laser 800 rangefinder. I sent it in and they wanted $311.00 to fix it so I bought a new one for $300.00 off EBAY. Today I was missing around with my old rangefinder and noticed after I put the battery in I could hear something loose in the rangefinder. There is a little metal tang in the bottom where the battery goes that holds tension on the battery that was bent down. I bent it back up about 3/16" and put the battery back in, now it works fine.
Posted on Mar 13, 2008
Purchased the Landscape Laser Lights for Christmas.I cant get the remote to work when I'm close to it.Turnedon with remote but will not turn off or change.AmIdoing something wrong-battery tested good.
Make sure the receiver window on the unit is not blocked. Even a partial blockage can negatively affect the communication between the unit and the remote. Clean both windows, the one on the remote and the one on the unit. Don't use products but instead, some mild soap and water on a microfiber cloth.
Nov 29, 2016 | Miscellaneous
Measurement is off approx. 4' to 5'. Any way to re-calibrate to have accurate measurements?
I didn't find the Prostaff laser 440 rangefinder on the website for Nikon.com, but I did find the 550 model. The specs follow:
Specifications
  • Measurement Range 11-550 yds
  • Increment Reading 0.5/1 yds
  • Magnification 6x
  • Angular Field of View (Real)
  • Angular Field of View (Apparent) 34.9°
  • Viewfinder Display meters/yards
  • Eye Relief 18mm
  • Diopter Adjustment +/-4°
  • Power Source 1 CR2 Lithium Battery
  • Size (Length x Width x Height) 5.1 x 1.5 x 2.7 in
  • Weight w/o Batteries 6.3 oz
  • Objective Diameter 21mm
  • Exit Pupil 3.5mm
  • Supplied Accessories CR2 lithium battery.
I did not read that there is a recalibration for the unit, although a consumer might expect that. Has it ever been dropped to your knowledge?
http://nikon.com/products/sportoptics/support/index.htm
The above link has contact information for service of the unit via telephone numbers.
Jul 23, 2010 | Nikon ProStaff Laser 440 Rangefinder
Won't range even after reset
Well after going through the reset procedure (holding both buttons down for 30 seconds) the unit didn't appear to be working. Being somewhat new to the proper use of this device it appears that it might be sensitive to low light conditions or certain objects. After playing with it more I'm now able to get it to work but there are still certain conditions where it won't give me a reading.
Feb 12, 2009 | Nikon ProStaff Laser 440 Rangefinder
  • Nikon INC.
Dec 01, 2007 | Nikon ProStaff Laser 440 Rangefinder
Nikon 440 pro staff range finder wont read distance
I just got mine to work. It was doing the same thing. I guess I re-set it. I figured there had to be some way to re-set it. So I pushed the mode button and the power button simultaneously for 30 second. Then it worked! Wooptidoo :)
Nov 01, 2007 | Nikon ProStaff Laser 440 Rangefinder
Nikon Pro Staff 440 Range Finder
there is a silver quarter sized screw out cover on the battery compartment.  It has a slot so you can use a coin or screwdriver to remove the cover.
Oct 12, 2007 | Nikon ProStaff Laser 440 Rangefinder
Nikon ProStaff Laser 440 Rangefinder Logo
103 people viewed this question
Top Nikon Optics Experts
George Merkley
George Merkley
Paul &...
Paul &...
Are you a Nikon Optic Expert? Answer questions, earn points and help others
