Question about Acer Aspire 5920-6727 Notebook
Nothing appears on the screen
When i turn on the computer, i get a black screen , it was working fine, i closed the cover to move it and when i opened it this is what happened, i can hear it run once in a while, no picture
  • 32 Answers
Press the power botton .
It might got into hibernate mode.
Posted on Aug 19, 2009
I changed my ink and now it says cover open when its not and nothing will work now
The problem could be due to a communication failure between one of the printheads (cartridges) and the All-In One (AIO) or by a short in one if the printheads. Please follow the steps below to identify and fix cartridge issues:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
Apr 10, 2012 | Lexmark MFP-X3470 All-In-One InkJet...
How do i reset ink cartridge cl511for my canon ip2700
1. Make sure that the power is turned on.
2. Open the Front Cover.
The FINE Cartridge Holder moves to the replacement position.
3. Remove the empty FINE Cartridge.
(1) Pinch the tabs and open the Ink Cartridge Locking Cover.
(2) Remove the FINE Cartridge.
4. Prepare the new FINE Cartridge.
(1) Take a new FINE Cartridge out of its package and remove the orange protective tape (C) gently.
5. Install the FINE Cartridge.
(1) Put a new FINE Cartridge in the FINE Cartridge Holder.
The Color FINE Cartridge should be installed into the left slot and the Black FINE Cartridge should be installed into the right slot.
(2) Close the Ink Cartridge Locking Cover to lock the FINE Cartridge into place.
Push down the Ink Cartridge Locking Cover until it clicks.
(3) Confirm that the Ink Cartridge Locking Cover is closed correctly.
6. Close the Front Cover.
Sep 20, 2011 | Canon Office Equipment & Supplies
I have a sony va10 F series notebook model VPCF115FM, it was working fine at first but when i shut it down and then later turne it on again, it does nothing...nothing appears on the screen, all i get is a...
It appears that teh computer has entered the sleep mode and not waking.
Press and Hold the power switch for 7-10 secs to turn OFF the computer and again press the power to turn it back ON.
If issue is still not resolved then perform a few more steps for computer booting to black screen.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C270032
You can also perform the steps from the below link for computer that does not wake from sleep mode:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C1002369
After this, change what happens when the physical power button is pressed or when the notebook lid is closed settings. Follow the steps from the below link.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C1002901
Select the option of shutdown for power button and do nothing for the close lid option.
Performing the steps provided can resolve the issue successfully.
Dec 08, 2010 | Sony VAIO Notebook
How do I load the ink cartridges into the Canon Pixma printer MX320?
1. Make sure that the power is turned on, and open the Paper Output Tray.
2. Lift the Scanning Unit (Cover), then hold it open with the Scanning Unit Support on the right side.
3. FINE Cartridge.
(1) Take a new FINE Cartridge out of its package and remove the orange protective tape gently.
The Color FINE Cartridge should be installed into the left slot and the Black FINE Cartridge should be into the right slot.
(E) Closed correctly
(F) Not closed correctly (the cover is tilted)
6. Lift the Scanning Unit (Cover) slightly to set the Scanning Unit Support back to its original position, and gently close the Scanning Unit (Cover).
Oct 05, 2010 | Canon Office Equipment & Supplies
How do i replace the ink on my canon mx340
These are the steps originally from the http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx340#ServiceAndSupport
Install the FINE Cartridges
1. Lift the Scanning Unit (Cover) (A) and fix it with the Scanning Unit Support (D).
Close the Document Cover (E) and lift it with the Scanning Unit (Cover).
important:
  • Do not touch the buttons or LCD (F) on the Operation Panel (G). May result in unintended operation.
  • When opening the Scanning Unit (Cover), the FINE Cartridge Holder moves automatically.
  • If the FINE Cartridge Holder does not move, make sure that the machine is turned on.
  • If the Scanning Unit (Cover) is left open for more than 10 minutes, the FINE Cartridge Holder moves to the right. In this case, close and reopen the Scanning Unit (Cover).
2. Make sure that the FINE Cartridge Holder (H) moves to the installation position.
3. Follow the next procedure to insert the Black g0070683.png and Color g0070684.png FINE Cartridges into their corresponding slots g0070683.png and g0070684.png.
4. Open the Ink Cartridge Locking Cover g0070683.png on the right side.
Pinch (I) firmly and pull up the cover.
5. Remove the Black FINE Cartridge g0070683.png from its package.
important:
  • Handle the FINE Cartridges carefully. Do not drop or apply excessive pressure to them.
  • Be sure to use the supplied FINE Cartridges.
  • Be careful not to stain your hands or surrounding work area with ink on the removed protective tape.
  • Do not touch the Electrical Contacts (K) or Print Head Nozzles (L) on a FINE Cartridge. The machine may not print properly if you touch them.
6. Pull the orange protective tape (J) in the direction of the arrow and remove it carefully.
7. Place the Black FINE Cartridge g0070683.png into the right slot g0070683.png.
important:
  • Do not knock the FINE Cartridge against the sides of the holder.
  • Install in a well-lit environment.
  • Install the Black FINE Cartridge g0070683.png into the right slot g0070683.png, and the Color FINE Cartridge g0070684.png into the left slot g0070684.png.
8. Push down g0070683.png of the Ink Cartridge Locking Cover until you hear a click to close it completely.
View the Ink Cartridge Locking Cover g0070683.png straight on and check that it is locked correctly (not at an angle).
9. Insert the Color FINE Cartridge g0070684.png into the left FINE Cartridge Holder g0070684.png in the same way as the Black FINE Cartridge.
10. Lift the Scanning Unit (Cover) slightly (1) and fold the Scanning Unit Support (2), then gently close the Scanning Unit (Cover) (3).
important: Do not touch the buttons or LCD on the Operation Panel. May result in unintended operation.
11. Make sure that the LCD changes as shown in the illustration and go to the next step.
  • It takes about 1 - 2 minutes before the LCD changes.
important:
  • Once you have installed the FINE Cartridges, do not remove them unnecessarily.
  • If an error message is displayed on the LCD, make sure that the FINE Cartridges are correctly installed.
note: The LCD will turn off if the machine is not operated for about 5 minutes. To restore the display, press any button except the ON button.
Aug 12, 2010 | Canon PIXMA MX310 All-In-One Printer
Power of laptop is on but nothing is happening
So there are many problems which will cause issues of the screen.
1. Software
- Try Fn + F5 or something like that
2. Electrical
- Remove battery, unplug power, hold power button for 60 seconds, turn on computer with power plug only, then shutdown, add battery and restart
3. Magnetic On/Off Switch to detect of Close/Open Lid
- Your magnet switch is fubar some how. Open up the speaker cover and see if your lid actuator switch that come in contact with the magnet on your lid cover is stuck or not (find where the magnet is in the back of the front lid cover, trace where the magnet area actually touches the base of the computer and you will find the switch)
- Workaround, start windows with lid at 30 degree angle
4. Hardware
- You need to replace either Inverter, Blacklight, or everything. =)
Good luck and have fun!!!
Jul 26, 2010 | Compaq Armada M700 Notebook
My lab top when restarted it beats 3 times, screen blank
Nothing to worry, Open your laptop from the back side.Remove the RAM  and reinsert it.
Your system will work fine.
Rate this solution.
Dec 27, 2009 | HP Pavilion dv9700t Notebook PC
My easyshare m1063 will take pictures, but the pictures dont show
I have an easyshare and there's a 2 part lens cover that closes when you turn it off and opens when you turn it on - normally. Mine only closes one part of the cover when I turn it off and opens when I turn it on. Kodak said I could send it in but I may have sat on it and caused it to malfunction. In which case they wouldn't cover it. Yours sounds like it's not opening at all. Look at the lens, and if you see a flat black cover with a wavy line instead of glass when you turn it on, yours is stuck shut. If it's still under warranty they should fix it unless you sat on yours too. Consumer Reports rated these a best buy but somehow this problem fell through the cracks of their testing.
May 28, 2009 | HP Photosmart M525 Digital Camera
Away from computer, screen goes black. cannot resume. have to turn off (reset) computer
It must have gone into sleep mode, Close your laptop screen and open it again, if it doesn't work get professional help
Nov 10, 2008 | Toshiba Satellite 1105 Series 14.1" Flat...
Black screen
you restore the pc back when it was working fine,you can do in safe mode
May 30, 2008 | Dell Inspiron 1501 Notebook
Acer Aspire 5920-6727 Notebook Logo
140 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
