Question about Lowrance 5300C GPS Receiver
Need to know how to do a hard reset on the unit-lowrance533
Need to know how to do a hard reset on the unit-lowrance 533 model
    President:
  • 379 Answers
Try this ,
1.) turn off unit
2.) press and hold pages key
3.) press and hold power key
4.) release both buttons when the USA map appears
was for the 5300 searies , hope it helps ya.
Posted on Dec 25, 2008
  • Rick Byrd
    Rick Byrd Jan 03, 2009
    follow up - did this information FIX YA ? thanks for voting .
Need owners manual for lowrance model# elite 4 hdi
here you go
[PDF]Mark-4 HDI & Elite-4 HDI - Lowrance
https://www.lowrance.com/.../Lowrance.../ELITE-4_HDI_OM_EN_988-10576-001_w....
Installation & Operation manual. Mark-4 HDI & Elite-4 HDI. Operation manual ... Lowrance Mark-4 & Elite-4 HDI ...... Selects the transducer model attached.
[PDF]Elite-4x HDI - Lowrance
www.lowrance.com/.../Lowrance.../ELITE-4X_HDI_OM_EN_988-10586-001_w.pdf Installation & Operation manual. Elite-4x HDI. Operation manual .... 4. Basic Operation ' Elite-4x HDI. Selecting Pages. To select a page, press the keypad in the direction of the desired page and ..... Selects the transducer model attached to ...
[PDF]Mark-4, Elite-4,5, 7,9 Operation Manual - Lowrance
https://www.lowrance.com/.../Lowrance.../MARK_ELITE_SERIES_CHIRP_OM_EN_98...
... Elite-7 & Elite-9. Operation manual ... NOTE:This manual covers Mark-4, Elite-4, Elite-5, Elite-7 and Elite-9 units. As a result ..... Selects the type of transducer model attached to your unit. ..... HDI 83/200kHz (Medium/High CHIRP. 83/200kHz ...
manual for lowrance model elite 4 hdi Google Search
Oct 21, 2017 | Lowrance Boating
Tip
Lowrance LCX power up problem
On Lowrance LCX-19 and I would assume other LCX series units.
The T3 Transformer shorts out and when the sonar kicks in it causes the unit to go over current and will eather cause the unit to reset and start again or blow the fuse. If you have the ability you can re-wind the transformer.
The primary is 46 turns of 24awg inverter duty magnet wire,
The secondary is 164 turns of 26awg inverter duty magnet wire.
Be sure to keep the same winding direction as what you take off as it may be phase sensitive. Be sure to use mylar tape between the primary and secondary windings.
Just a note this board has very heavy power planes and is very hard to solder/de-solder on.
If you have any questions or need help you can contact me at info@jtechnicalservices.com
on Jul 20, 2010 | Lowrance LCX-19C GPS Receiver
How do you manually reset a lowrance eliite 5
You can try holding in the zoom in/out buttons (+/-) as you push and release the power button.
Hold the zoom keys until you hear a beep.
If your hard restart is successful. You should see the GPS screen with prompts for language etc.
if you cannot get the system to cooperate and all you see is the "Lowrance" screen, then you are experiencing a Castro pic system failure and the unit needs to go back to Lowrance.
Jun 21, 2015 | Lowrance Elite 5 Color SonarGPS Combo
How to reset hds 5m
For a 'soft' reset, turn the unit off. Press and hold 'Pages', Press and release 'Power'. Release 'Pages' when the waiver appears. This reset preserves data.
For a 'hard' reset, turn the unit off. Press and hold 'Zin' and 'Zout'. Press and release 'Power'. Release all when the waiver appears. This reset clears all data.
Feb 18, 2013 | Lowrance HDS5m GPS Receiver
HDs 8--detecting bait fish?
its hard to describe a school of bait fish on the screen less you know what your looking at you need to go on line to www.lowrance and go to there what bait fish looks like on your screen page it will show you all you need to know and how to set your unit to know what your looking at and how to read your screen on your unit
Feb 06, 2013 | Lowrance HDS-8
Lowrance globalmap 2400 on/off button stuck, unit tries to turn on then screen is blank, tried wiggling back and forth no luck, should i send it in for repair and where to...live in carroll county, md....
You can try a hard reset:
1. Turn unit off
2. Press and hold ZIN, ZOUT, and PWR until you get the "WARNING, DO NOT RELY..." message.
If that doesn't work, try installing the latest updates from http://www.lowrance.com/en/Downloads/Product-Software-Updates/
If it still doesn't work, and you can't get through to Lowrance by phone, try emailing them by going to http://www.lowrance.com/en/Support/Product-Support/Contact/
It probably won't be worth repairing the unit. You will be better off putting that money into a current unit which will be much better than the 2400 and probably less expensive than the 2400 was when it was new.
Mar 23, 2009 | Lowrance Globalmap 2400 GPS Receiver
Lowrance 330c screen says '' boot failed''
Try a hard reset:
1. Turn the LMS-330 off
2. Press and hold the ZIN, ZOUT, and PWR buttons
3. Release the three buttons once you see the "warning, do not rely..." message appear
If you get that far, the problem is solved. If you get boot failed again, try installing the latest update which can be downloaded from http://www.lowrance.com/en/Downloads/Product-Software-Updates/
If you still get boot failed, you will need to get the LMS-330 repaired/replaced. You can contact Lowrance support at 800-324-1356 or email them by going to http://www.lowrance.com/en/Support/Product-Support/Contact/
Mar 22, 2009 | Lowrance LMS-330C GPS Receiver
Lowrance 330c gps unit
A "soft reset" can be accomplished by pressing and hold "Pages" key and press and hold "PWR" key till USA map comes on , then release both. A "hard reset" requires press and hold both "Z in" and "Z out" buttons and press and hold "PWR" button releasing all three when USA map appears.
Oct 18, 2008 | Lowrance LMS-330C GPS Receiver
We have a X23 Lowrance. It was working OK then it just went to flashing 0.5m with bits of blue colour over the screen. We have switched it off and then on again, but still flashing 0.5m. Can you help?
First check and clean the transducer. Make sure it's level and clean of any dirt oil or fuel. You can do a hard or soft reset also but you'll lose all stored data and it will reset all of your settings. You can find out how to do a hard or soft reset on Lowrance hompage. www.lowrance.com I would get you the exact address but their web site is a little messed up this morning.
Jun 25, 2008 | Lowrance Iway 500c GPS Receiver
Lowrance 5300C GPS Receiver Logo
223 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
