Question about Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV
TV will not power up...standby light just flashes green
I have a KDF-55XS955 tv that is less than 2 years old. I have a problem where my tv will not start up. when i turn it on the standby light just flashes green. There is no set number of times. It seems to do it like 36 times and then pause and starts over again. I had a similar problem before and I unplugged the tv from the wall for a bit. Once i plugged it back in, it has been working for over 6 months. now the problem has surfaced again. I have contacted sony about this problem, no information was given over the phone of course and a technition needs to be sent to my house. I was wondering if anyone had any ideas what part might have gone bad? The lamp light is not on so im assuming that the bulb inside is still good. How can sony make a tv that doesnt even last 2 years!
  • 4 more comments
  • Anonymous Nov 19, 2007
    Mine is a Sony KP-51WS520 that is doing the same thing. It is only about 2 1/2 years old. I didn't buy the extended warranty because I was buying a Sony. So much for reputation.Called Sony...no help.
    My Sony 55" is 2 1/2 years old. The green power/standby light flashes many times then the tv will eventually turn on. I replaced the bulb recently so I know that's not the problem. I bought Sony based on reputation and product quality. Called customer service and told me to check that bulb is secure and to unplug tv then reconnect.
  • patricia tomlinson Dec 11, 2007
    the t.v. just shut off by it self and when i tried to turn it back on the standbye light comes on and flashes for a while the the lamp light comes on and the t.v. shuts itself off.
    the t.v. shut off in the middle of a program. when i attempted to turn it back on it went into stanbye mode. after the green light flashes the lamp light comes on and the t.v. shuts off again. whats the problem
  • Anonymous Mar 08, 2009
    tv will not power up, red light flases 6 times then start again
  • missyjreed Mar 09, 2009
    Television shuts off after being on a short time, then shuts off immediately after subsequent power-ons. Red power light flashes four times. Overheating does not seem to be the problem, as there is no warning message and fan is working properly and TV ventilations are not blocked at all.
I had this same problem and simply unplugged the tv and then plugged it back in. Problem solved. I've had the TV about 1 1/2 years and no problems until now. I'm glad it wasn't something more of a problem.
Posted on Oct 02, 2007
Hello dbldown768, I had some what the same problem. The tv would just blink & sometimes come on & sometimes not. If I let it set off awhile it would work. So I changed the bulb & it worked great. Hope it helps
Posted on Aug 25, 2007
Dear dbldown768, I have a paperweight that's just over 1 year old that does the same thing. I paid $90.00 to have a tech come out hoping it was a warranty issue or a defect that sony covers. They check the bulb and it was good but had to take the tv. They called a day later with a $500.00 estimate and said the problem was the C-board blew because the vent fans got clogged with dust because the tv was too close to the wall. The tech said it needed to be at least 12" but funny the instruction manual says 4". I contacted sony and asked them and they couldn't find the manual but would take my word for what it said. They gave little indication which was correct. They sort of stood by the manual but claimed not to be a tech. After digging I found that this tv was put on the market without proper testing as required and they already admitted to a problem with the optic block. Check out this web page http://attorneypages.com/hot/sony-grand-wega-tv-problems.htm. Although our problem isn't the optic block the fact that sony has owned up to placing the product on the market without proper testing makes me feel it's sony's responsibility. The webpage says that customers feel that sony is giving them the run around until some cutoff date of 9/30/07, I've found nothing but run around myself. I'm planning on submitting a claim either way, contacting the Better Business Bureau, Sony's Executive Reviews Committee and I'm considering getting my free consultation because this is awful! I hope the webpage is helpful and best of luck to us both!
Posted on Jun 14, 2007
SOURCE:
I have a Sony KDF-E50A10 Grand WEGA LCD. The picture cuts in and out and the green standby light flashes. One expert said the STKs need to be replaced??? How can I do this...please advise in detail.
Replace your lamp. Your DLP set does not have Stk ic's in it. I don't know what expert told you that but I can assure you he has never worked on a TV. You can purchase the lamp from www.dlplamps.com
Jan 18, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
Tv will not turn on red standby light blinks 6 times
tv will not turn on red standby light blinks 6, on a sony grand wega kdf-55xs955 55 in. rear projection hdtv television
Jun 19, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
Sony Wega kdf-50E2000 Keeps turning off and on
Before you replace the lamp I recommend trying to clean/dust the lamp component and lamp plug in area. I had the same problem and was able to resolve it by simply blowing the dust off the lamp components and fan. Use a can of high pressure air to get into the cracks and crevices.
Jun 04, 2009 | Sony KDF-50E2000 50" HDTV
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony TV Screen
Is you model listed below?
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV Logo
191 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
