Question about Acer Aspire 1662WLMi Notebook
Unlock Computer After Log Off of AOL
When leaving AOL my computer locks up and must be retarted. Using Windows Me System.
Lost administration rights
What operating system are you using? If you are using windows 7 you can try.
1. Start computer and then press "Ctrl+Alt+Delete" twice at Windows Login Screen.
2. Type "Administrator" without quotations in the username box and leave password box blank. Then hit "Enter" to log onto Windows system.
3. Go to "Start->Control Panel->User Accounts" to unlock the forgotten Windows 7 password.
This will work if there has been no changes to the default settings of windows 7. It is the same for windows XP
Apr 07, 2014 | Computers & Internet
Gateway login
What sort of problem at log in >>?????
Forgot password ?
A "setup password" is a password that you must enter to log into a user account on your Gateway laptop.
This can be beneficial if you have a number of people using the same computer and don't want just anyone having access to your personal files.
But if you are the sole user of your Gateway laptop, then it can be more of a hindrance.
As all Gateway laptop computers run a version of the Windows operating system, you can remove the setup password by accessing the Windows Control Panel.
Click on the "Start" menu.
Select the option that reads "Control Panel." If you're running Windows Vista or Windows 7, this will have its own listing in the "Start" menu.
If you're running Windows 95, Windows 98, Windows ME or Windows XP, this will be found under the "Settings" sub menu.
Double click on the icon that reads "User Accounts."
Click on the name of the account that has a setup password that you want to remove.
Click on the "Remove my Password" option.
Enter your current password into the appropriately labeled box.
Click the "Remove Password" option.
Click "OK" to save your changes and exit the "User Accounts" utility.
The setup password will have been removed from your account, and you will be no longer prompted to enter it when you boot up your computer.
Unlock a Gateway Computer
Getting locked out of your Gateway computer can be frustrating, especially when you have school or work deadlines.
You can get locked out of your Gateway computer in cases where a password protected screensaver became corrupt, or if the you have set the default screensaver to use a screensaver that does not exist.
Gateway computers come with Microsoft Windows XP and 2000, including the professional versions of both. Knowing how to unlock your a Gateway computer can save you time and irritation.
Press the "Ctrl," "Alt" and "Delete" keys on your keyboard simultaneously to unlock your Gateway computer.
Type the last logged-on user's login information and click "OK" if you see a locked computer message along with "Only domain/username or an administrator can unlock this computer." Press the "Ctrl," "Alt" and "Delete" keys once again when you see the Unlock Computer window disappear. Log on as usual. Method 2
Shut down the locked Gateway computer by using the Microsoft Windows Resource Kit Shutdown tool.
This tool shuts down and restarts a Windows 2000- or NT 4.0-based Gateway computer.
Note the dialog box that comes up called System Shutdown.
Wait for the shutdown timer to run out and see the Welcome to Windows box displayed on the screen.
Press "Ctrl," "Alt" and "Delete," which unlocks the computer.
Log onto your Gateway computer normally.
Method 3: Backup, Modify and Restore the Registry
Click "Start" and "Run," then type in the command below in the field box exactly as printed:
%SystemRoot%\system32\restore\rstrui.exe
Click "Create a Restore Point," then click "Next" on the Welcome to System Restore page that appears.
Type any name for the restore point, then click "Create" on the Create a Restore Point page. Click "Close" after creating the restore point.
Perform this procedure before you make changes to the registry, just in case you make an error; otherwise, incorrect registry changes could create serious problems with your computer.
Click "Yes" if you receive a prompt to turn on System Restore at this point.
Clear the "Turn Off System Restore" check box by clicking on it, then click "OK," and repeat.
Click "Start," then type "regedt32.exe" (without the quotes) in search field box to modify the registry and unlock the computer. Press the "Enter" key on your keyboard.
Locate the scrnsave.exe value under the registry key below:
HKEY_USERS\.Default\Control Panel\Desktop
Click "String" on the Edit menu, type "logon.scr" (without the quotes), then click "OK."
Look for the ScreenSaverIsSecure value, then click "String" on the Edit menu, type "0," then click "OK."
Quit the Registry Editor
Click "Start" and "Run," then type the command below exactly as printed to restore the registry, then click "OK":
%SystemRoot%\System32\Restore\Rstrui.exe
Click "Restore My Computer to an Earlier Time" on the Welcome to System Restore page, then click "Next."
Note your computer may already be selected to restore to an earlier time--in this case, just click "Next."
Click the system checkpoint on the Select a Restore Point page. Click "Guided Help (Registry Backup)," then click "Next" on the "On This List Select the Restore Point" area.
Click "OK" if you see a System Restore message listing all the configuration changes it will make. Click "Next" when you come to the Confirm Restore Point Selection page.
System Restore will now restore the Windows XP configuration you had at an earlier time, and then it will restart your Gateway computer.
Log onto your computer as usual, and then click "OK" when you see the System Restore Confirmation page.
Nov 26, 2013 | Computers & Internet
Gateway login
You can get locked out of your Gateway computer in cases where a password-protected screensaver became corrupt, or if the you have set the default screensaver to use a screensaver that does not exist.
Log on as usual.
Method 2
Shut down the locked Gateway computer by using the Microsoft Windows Resource Kit Shutdown tool. This tool shuts down and restarts a Windows 2000- or NT 4.0-based Gateway computer. Note the dialog box that comes up called System Shutdown.
Nov 18, 2013 | Computers & Internet
How do i unlock user on my computer
be sure you have the admin password. restart the computer then press f8 then select safe mode. then supply the admin password then go to control panel then users then activate the users you want to .
Jun 29, 2012 | Toshiba Computers & Internet
How to unlock computer
If Error Message Says the Computer is Locked by User
Press "Ctrl" + "Alt" + "Delete" on the keyboard to unlock the computer.
Type the username and password of the user who last logged on to this computer. Click the "OK" button when you are done.
Wait for the "Unlock Computer" dialog box to disappear. The computer has now been unlocked.
Press "Ctrl" + "Alt" + "Delete" on the keyboard again and log on normally by typing in the username and password.
If the Error Message Does Not Tell Who Locked the Computer
Attempt to shut down the locked computer through the server computer. You will have to use the Shutdown tool in the Microsoft Windows Resource Kit (see Resources for download link) to shut down the computer remotely.
Wait for the "System Shutdown" dialog box to display the locked computer. Although the dialog box appears, the computer will not actually restart.
Wait until the "Welcome to Windows" dialog box appears on the locked computer.
Press "Ctrl" + "Alt" + "Delete" on the keyboard before the screensaver becomes active and log on normally by providing your username and password.
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
Apr 12, 2011 | Toshiba Satellite Pro L300 Notebook
My dell inspiron 1545 is locked. i am the main administrator. how can i unlock it?
hi
http://www.kellys-korner-xp.com/win_xp_passwords.htm
or
http://www.lostpassword.com/windows.htm
find your solution from above links
Aug 01, 2010 | Dell Inspiron 1545 Notebook
My computer is locked up
You can try doing a system restore by pressing f11 as soon as the computer starts up... otherwise, you can just perform a system recovery (which will restore the computer back to factory settings and will result to data loss).. If you are not ok with that then maybe you can try password recovery software found here. Password cracking is not guaranteed to work though.
Jun 20, 2010 | HP Compaq Presario V2000 Notebook
How can I unlock my computer montior log on screen ..My Windows XP screen shows a small window that says ...this computer is locked and only >>>>> (I) can unlock it...but I can't ...help. I...
Hi
It is not th emonitor that is locked it is your PC, if you do not know the password the easiest thing to do would be to restart it
This is done by pressing and holding in the power button on your PC until the PC/Laptop shuts down and then restarting!!!
Please leave feedback/vote if my answer was helpful
Feb 10, 2010 | Computers & Internet
My notebook pc is locked up and will not unlock with my password and how much does this costs
Hopefully you have more than one account with administrative privileges on your computer. Then this should help:
Turn your computer on, and press F8 until you see the startup menu. Use the up/down arrows to select Safe Mode, and hit enter. Press enter again on Windows (whatever your operating system is).
1. Click Start, Control Panel, Administrative Tools.
2. Click Computer Management.
3. Double click Local Users and Groups, double click the folder Users.
4. Right click on the account name that is locked out, and click on Set Password.
5. You may get a warning message about changing the password, simply click proceed.
6. Leave the New Password box blank, also leave the Confirm Password box blank.
7. Click OK, and OK again.
8. Then close all Windows, reboot the system and try to log in.
May 03, 2008 | Computers & Internet
Acer Aspire 1662WLMi Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
