Question about Fujitsu 24C1 Air Conditioner
No heat unit works on cooling but at heat comp doesnt come on
    President:
  • 267 Answers
There is nothing you can do , the heat (and everthing else) is controled by the main control board and a few sensors . be carefull who you call to work on this you realy need to know you stuff about this control board , your normal ac guy will waste you time and money guessing ... good luck
Posted on Jan 17, 2009
Hi I have an Omni AOS - 09HR4F split system air cond and when I set it to the cooling mode the unit outside starts the fan motor running but the air coming out of the head unit inside doesnt get cold?
Could be a lot of reason why compressor is doing that .First make sure your outside unit is clean ,if not wash coil with water .If coil is clean check capicator and replaced if bad .if capicator is good then you might have a bad compressor or a leak in your system and compressor is shutting off on low pressure .
To figure this out you need to install your refrigerant guages to check
Mar 05, 2018 | Heating & Cooling
Amana Wall unit blows cold air before heating
the unit works by chilling air and the byproduct is heat in the compressor, this is used for heating in the winter and then reversed in summer to blow cold air. It has to blow cold and warm up before it can blow heat.
Mar 17, 2017 | Amana Heating & Cooling
I have a Friedrich Ptac unit Model PDH15K5SE-A. The unit turns on ok but does not heat. Need advice what to do. Thanks
Does the unit cool ok? If yes, you likely have a problem with reversing valve. If no, likely a refrigerant problem.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Mar 01, 2017 | Friedrich Heating & Cooling
Condensing unit
need to programe the comp board on unit for heat and cool mode
Jul 31, 2009 | Amana PTH123B25AJ Heat Pump Air...
Home unit 3 ton won't run
The small capacitor is for the fan motor the other for thecompresor .You can try conecting a booster (or hot start) in paralel to the comp.capacitor .If this doesnt work you have to replace the compresor.
Mar 29, 2009 | Heating & Cooling
Heat Pump Stops Working only in the Early Morning
When the unit does what you say does the fan motor outside stop also , if it does that means it is in defrost mode and should kick back over to normal after the system heats up the coil enough
Nov 24, 2008 | Weather King 12AJA4801AH Air Conditioner
Ruud heat pump outside fan
You may be right in looking at the motor. It uses a different speed on heat than cool. The heat cycle uses low speed, usually red. Some manufactures use blue (medium). Cool uses black, high speed. If you are confident, switch the low speed wire with the high speed and see if this changes anything. If the fan motor isn't the problem, check the other setting (cool) if the overload trips, you may need to look into a new capacitor or compressor, if so, you can install a hard start kit. these are start boosters, and are inexpensice, sometimes they will give another year out of the comp. but I've put them on and they have lasted 5 years.
Mar 15, 2008 | Heating & Cooling
Fujitsu 24C1 Air Conditioner Logo
133 people viewed this question
Top Fujitsu Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
