My Marantz SR 4400 Receiver. I hooked up blu ray to it with an optical audio cord. When It gets loud or I'm not sure of the cause the reciever turns off and I can't turn it back on until I unplug it and plug it back it. This keeps happening especially at high volumes
  • snides007 Apr 10, 2009
    Same problem, except was on a dvd bought from thailand which i know are good copies, it did say it was comming thru in dolby digital ES which i have never had problems with before. Wonder if been copies they were maby copied off a blue ray disc in HD sound and overloading the amp? Anyone else with ideas?
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
  • 905 Answers
SOURCE: No Audio when I play Blu-Ray discs with Dolby TrueHD
For dolby digital to work you have to have the optical or coax cable hooked up to the reciever ,The HDMI cable is for digital video and audio output but does not support dolby digital out the cable into your reciever , so just turn off the dolby digital on your reciever and you should hear the sound.
here is more info
Dolby TrueHD is an advanced lossless multi-channel audio codec developed by Dolby Laboratories which is intended primarily for high-definition home-entertainment equipment such as Blu-ray Disc. It is the successor to the AC-3 Dolby Digital surround sound codec which was used as the audio standard for DVD discs. In this application, Dolby TrueHD competes with DTS-HD Master Audio, another lossless codec from Digital Theater System.
Dolby TrueHD uses Meridian Lossless Packing (MLP) as its mathematical basis for compressing audio samples. MLP was used on the earlier DVD-Audio format, but details of TrueHD and DVD-Audio differ substantially. A Dolby TrueHD bitstream can carry up to 14 discrete sound channels. Sample depths up to 24 bits/sample and audio sample rates up to 192 kHz are supported. Like the more common legacy codec Dolby Digital, TrueHD bitstreams carry program metadata. Metadata is separate from the coding format and compressed audio samples, but stores relevant information about the audio waveform. For example, dialog normalization and Dynamic range compression are controlled by metadata embedded in the TrueHD bitstream.
Posted on Oct 06, 2008
gotgeek2
  • 565 Answers
SOURCE: I have the following hardware:
Remove the HDMI cable (out) to the speakers from the receiver.
Connect regular speaker wire from the receiver to the speakers.
Of course, remove the (now extra) HDMI cable from the tv.
That will remove the loop.
Posted on Jan 25, 2009
mlapres
  • 757 Answers
SOURCE: Got a Kenwood vr405 surround receiver, a Sanyo
If you would like to use high definition audio decoding, connect the HDMI from the blu ray player to the receiver. If that it not an option for you due to lack of equipment such as an additional HDMI cable to go from the receiver to the television for the video portion of the signal, then connect your optical cable again. After the optical cable is connected, make sure the Dolby Digital decoding is enabled on the receiver, and that the media you are playing also has a version of 5.1 surround sound. Then, enter the setup menu of the player (which I suspect this is actually where the problem might reside in your case) and make sure that Dolby Digital and DTS are not set to "downmix." Dolby Digital should be set to output Dolby Digital and so on and so forth...hope this helped.
Posted on Jan 14, 2010
Testimonial: "Thank you for the insight. I may have figured this out on my own eventually but this definitely got me situated much much faster. "
  • 3 Answers
SOURCE: my Marantz sr 4001 receiver has no output. Is
my friend has the same problem with an SR 4001. the tech said it was an internal fuse soldered to the board. the display showed an error code that clued in the tech of the problem. I am trying to find the fuse on the board, and trying to get a value(Volts-amps) of the fuse
Posted on Jul 28, 2010
TRYING TO HOOK UP MARANTZ SR4000 TO A MITSUBISHI HC300 TO DIRECT TV. HAVE PICTURE BUT NO SOUND
Try changeing around your patch cords,You probaly have the input end output patch cords mix up.If they are not hooked up right you will get no sound. Unless there is a problem with the jacks on your amp or reciever
Sep 20, 2012 | Marantz SR-4000 Receiver
No audio produce in optical connection
Typically when you use the optical connector from a DVD player there are several steps to getting everything ready to hear sound.
First: The Marantz Receiver will have a setup menu option for changing the DVD player to "optical" or it will say "digital" input. Once this is done, you should immediately get Sound.
Secondly, the DVD player (may) have an option to be switched to a digital output through the optical port. You would be able to find this out with it's user manual.
I really hope this helps,
Best Regards,
Mark
Jan 24, 2011 | Marantz SR-4400 Receiver
Have to turn way up in order to hear
Have you gone into the TV's menu to make sure that the audio outoput is not set to "variable"?
On my Sony I have the option to set the audio output as "fixed or "variable"
make sure its set to fixed
if that's not it try a different input on your receiver. you can use anything EXCEPT PHONO.
Lastly on my Denon receiver I have to specify how each input should get its signal if you are using an optical cable then you may have to go into the menu and tell it to look for a digital signal not an analog one.
Hope that helps
Jan 22, 2010 | Marantz SR-4200 Receiver
How to connect Panasonic BD60 Blu-ray disc player to 2 components
If there are red and white RCA jacks on the back of the BR player and on the receiver you should be able to get sound. The same as your VHS.
Dec 29, 2009 | Panasonic DMP-BD60K Blu-ray/DVD Player
No sound from fiber optic 2 jack hooked to a blu ray
IN THE RECEIVER YOU HAVE TO CHANGE THE TYPE OF SOURCE YOU ARE USING (EXAMPLE DIGITAL OPT) AND SOMETIME YOU MIGHT HAVE TO CHANGE IT ALSO IN THE BLU RAY PLAYER TO DIGITAL OPT
Dec 06, 2009 | Audio Players & Recorders
Audio glitch on Marantz SR-19
It's probably not heat due to the Marantz' large frame and heat-synchs.
This could simply be a mismatch of impedance. The amp is 120w per channel, so make sure the speakers can handle this. Check the impedance (ohms) of the speakers and the amp as well. Clipping can be caused by overpowering the speakers, which could damage the speakers in the long-run.
If this is only from 1 source- (i.e.- Blu-ray player or cable) then it could be digital clipping.. This Marantz can decode 96kHz PCM or normal Dolby Digital & DTS. If this is a Blu-ray it may be streaming 192kHz PCM... (but most likely the Marantz will not even attempt to play that audio)
I hope this helps.
May 31, 2009 | Marantz SR-19 Receiver
Replacement power cable
Dose not matter use one with 3 holes as you put it,it will work ok.
CABLE GUY.
Apr 18, 2009 | Marantz SR-4400 Receiver
I have the following hardware: Marantz SR-4003 Receiver, Samsung LN52A650 HD TV, Samsung BDP-1500 Blu-Ray player, Scientific Atlanta Explorer 8300HD cable box, two Paradigm Millenia 20 LCR Bookshelf...
Jan 25, 2009 | Marantz SR-5600 Receiver
here is more info
May 19, 2008 | Marantz SR-7200 Receiver
363 people viewed this question
 Grubhead
Grubhead
