Question about Garmin nuvi 250W GPS Receiver
Will not power On
Why will my Garmin not turn on??
I've plugged it into the outlet and turned my car on and still nothing....
  • Anonymous Jan 08, 2009
    will not start ..jack. sweden
I had this problem on my Nuvi 260W. What I did was to slide the switch to the "on" position ....not quickly...but this time, do it and "hold it" in the ON position, count to 10, then release it. Did it power up?
Posted on Dec 28, 2008
How to turn on my garmin 265w
your battery in your garmin does not have enough power to stay on. You have to charge through your car outlet or usb port on computer. Only other option is to replace battery if it doesnt charge from car outlet since you said wont connect to computer.
Jul 13, 2014 | Garmin nuvi GPS
Why does Garmin nuvi 1250 power on but dim to almost black when plugged into power outlet?
Make sure you have your time and time zone set to match your area. Also look in display settings to see if it is set to night mode versus auto adjust.
Jun 28, 2014 | GPS
'93 Jeep won't start - used cigarette lighter for gps instead of power socket
Sounds like a bit of a stretch... (nah).
"Lighter" is a GREAT OUTLET...
Has been for decades.
Perhaps it is just time to consider some BATTERY MAINTENANCE... cable and terminal cleaning
or even A REPLACEMENT battery.
I ASSURE you a cigar/cigarette lighter ELEMENT
pulls a lot more power than your Garmin Nuvi 1450LMT.
Get your JEEP battery checked...!!
Carnac the Magnificent
Jan 07, 2018 | Garmin Nuvi 1450LMT
Garmin nuvi 40 will not charge
Sounds like a defective unit. You've tried everything their support people would walk you through.
Sorry...
Oct 31, 2012 | Garmin Nuvi 40
We have a Garmin Nuvi 205W GPS. Was plugged into car outlet when it went to a black dot display. Nothing happened when blk dot was pressed. Now we can't get it to turn on at all.
Have you tried resetting the 205W. There is a reset button on the bottom of some of the units if not power off the unit and then hold the power button for about 10 seconds till it starts, it should go through a start up and then reboot itself. See page 42 of manual. I will attach a link to the manual, click here.
Thanks for using FixYa
Jul 23, 2011 | Garmin nuvi 205W GPS Receiver
When I stop and turn off my car, my Garmin 255W stays on. Hows do I turn it off?
If your GPS is plugged into your power outlet in your car, it just means that the power outlet retains power when your vehicle is off as well. Meaning it is not an "Accessory" power source. Not a big deal, simply slide the power button on your garmin unit to the left. The power button is located on the top left side of the GPS. It is spring loaded so when you slide it to the left, hold it there for a second then it will spring back into place. Just release it and the unit should power down.
Jan 04, 2011 | Garmin nuvi 255W GPS Receiver
Garmin nuvi 5000 wont turn on. I can plug up the usb up to the computer and the screen shows garmin logo with a gps connected to a computer like its charging. But when i press the power button weather it...
Your nuvi 5000 does NOT have a internal battery and that means that you cannot operate it unless it is connected to a 12 volt power source. Connecting it to your computer via USB allows you to install map updates, check for firmware updates, etc, but you will not be able to use it as a gps while it is connected to the computer. There is nothing wrong with your gps.
To use your gps in the home you need to purchase a 12 volt adapter, there are several types, plug the adapter into your wall outlet and connect your gps to it. If you can sit near a window it will help in picking up the satellite signal. Just keep in mind that you cannot connect the 12 volt power supply and use the usb cable at the same time. Enjoy your gps.
Jun 11, 2009 | Garmin nuvi® 5000 Car GPS Receiver
Garmin won't turn on or charge.
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 23, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin nuvi 250W GPS Receiver Logo
98 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
