Question about Uniden BC72XLT Handheld Scanner
Radio Shack PRO-91 scanner keypad doesn't work
The radio is scanning on frequencies that were previously programmed, and when the manual button is pressed, it beeps, the display clears, but the keypad buttons don't respond and you cannot enter frequencies. Is it possible to re-set the microprocessor? Will this help, and how is it done? Any suggestions appreciated. This is a nice scanner, which worked great until XMAS day!! Thanks in advance for your help- Mike.
  • 31 Answers
Try a master reset. You will lose all of your current programming but it resets the unit back to its original state when you purchased it. here are the directions from page 53 in your manual.
Resetting the Scanner
If the scanner's display locks up or stops operating
properly, you might need to reset the scanner.
Caution: This procedure clears all the information
you have stored in the scanner. Before you reset the
scanner, try turning it off and on to see if it begins
working properly. Reset the scanner only when you
are sure it is not working properly.
1. Turn off the scanner.
2. While holding down 2, 9, and Hold, turn on the
scanner. It takes about 3 seconds to initialize
and CLEAr appears.
Posted on Jan 08, 2009
How do i reset the blocked channels ? my son filled it up lol and i need to block some open channels so it will scan
To block (lock out) a frequency that you no longer wish the scanner to stop on, press the L/O button at the lower left of the keypad while the scanner is stopped on that frequency. To remove the lock out, manually select the desired channel and then press the L/O button. To permanently delete an unwanted frequency you can program 0.0 (zero point zero) into the channel. Need the manual for your scanner? You can download and print it, at no cost, here:
Bill B.
Listening in since the 60's
Jan 25, 2011 | Radio Shack Pro-2018 Scanner
Pro-95 stopped scanning
Try to turn off unit and remove battery pack, then reinstall it after 10 mins and while its off press scan button for 5 seconds and turn it back on. it should automatically go to scan mode on WX
Apr 30, 2008 | Radio Shack Pro-95 Handheld Scanner
Scanning problem
Jun 08, 2007 | Radio Shack Pro-95 Handheld Scanner
I need to program a weather scanner for a pro 2018 weather scanner from rdio shack
Weather frequencies are factory programmed into the PRO-2018. Just press the weather button to start scanning them. You can also program one or more manually if you wish. For a list of NOAA weather broadcast frequencies, follow this link:
Need the manual for your scanner? You can download/print it here:
Bill B
Sep 05, 2010 | Radio Shack Pro-2018 Scanner
Dont know how to program
To program a known frequency into the PRO-82:
1. Power the scanner ON
2. Press the PGM key
3. Enter a channel number between 1 and 200 (you might want to start with 01).
4. Enter the frequency, including decimal point (Ex: 146.26).
5. Press ENT
6. Press PGM to advance to the next channel
7. Restart at number 4 above.
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
Bill B
Jun 13, 2010 | Radio Shack Pro-82 Scanner
I am looking for codes to program a radio shack pro-2041 scanner
The "codes" you refer to are actually radio frequencies. For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
Bill B
Apr 28, 2010 | Radio Shack Pro-97 Handheld Scanner
My scanner will not scan
You need at least 2 or more frequencies programmed, and
adjust the squelch knob until there is no more static, then press the scan button.
Here's a manual
Feb 09, 2010 | Radio Shack Pro-82 Scanner
Stuck on scan mode
Hi, It sounds to me like your keypad is locked. Pg 63 of your manual.
***using the keylock ***
Once you program your scanner, you can protect it from accidental program changes by turning on the key lock feature. When the keypad is locked, the only controls that operate are FUNC, key , SQ, and VOL. You cannot activate the keylock while you are entering a frequency into a channel. To turn on the keylock, press FUNC then key . Key locked appears for about 1 second. Key locked appears when you press any key after locking the keypad.
To turn off the keylock, press FUNC then key . The scanner beeps three times and Key unlocked appears.
The only other choice I see if that does not work would be to initialize it. Pg 84 of your manual. Hope this helps you,, Mechanic
Jan 04, 2008 | Radio Shack Pro-97 Handheld Scanner
Radio Shack Pro-95 handheld scanner issues
Here is the online programming tutorial:
Here is the full manual Should include Quick guide:
Here is FREE programming software for the PC:
Includes hardware info. You can buy programming cable at Radio Shack to connect to your PC.
Jan 02, 2008 | Radio Shack Pro-95 Handheld Scanner
1000 scanner radio shack
press the manual button a few times, and make sure there are actually some freq. programmed into the unit. if there are freq other than 000.000000 in there, press the s/s (lockout) button and see if this unlocks the frequencies to allow them to be scanned.
Aug 19, 2007 | Radio Shack Pro-94 Scanner
Uniden BC72XLT Handheld Scanner Logo
543 people viewed this question
Top Uniden Radio Communications Experts
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
