Question about GE PSS26SHRSS Side by Side Refrigerator
GSS22KGMC WW side-by-side refridgerator not cold anymore
I have a GS22KGMC WW side-by-side refridgerator that is not cold anymore. The freezer side is melted. The compressor seems to be running continuiously. I have now set the temperatire gauge to 9, in order to see if it makes it even slightly coldoer. SO far, it has not changed anything, and the whole unit seems to not be cooling anything anymore.
  • rebekahjoy79 Dec 28, 2008
    In response to the intial reply- by MNTECH, yes- I could hear the fan and the compressor running all along. It was just pushing out normal air temp. No cold air at all.
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    Is there any frost on the back wall of the freezer compartment? Do you hear the fan in the freezer running? How about the fan by the compressor?
I have no idea to this day, what caused the complete lack of cooling in my freezer and refridgerator. However, it seems to be working fine now. All I did was turn the compressor and fan totally off, let it rest for a few minutes, and then turn it back on. It seems to have "re-booted the system, and now everything is working normally. The ice-maker is once again making ice! It has been three days or so now, and so far, so good!
Posted on Dec 28, 2008
Ge refrigerator model gss22kgmc
check defrost element, if good check defrost thermostat, if good change defrot timer/control board depending on your specific model you can look at this link provided its a diff model but none the less quite similar
am searching for Main PBA for fridge freezer model no SRL 629EV The number...
Sep 02, 2014 | GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC...
My ge refrigerator side by side gsh22jfta ww freezer is cold enough but the fridge is not there is a vent between freezer and fridge, but I don't feel any cold air comming from it. Plz help me
The "damper" that open and closes is not working. It is controlled electronically with a thermostat. Here is the part to order.
All parts come with a 365 day, any part, any reason return policy
Apr 06, 2013 | Refrigerators
GESS25LGMB WW Side-by-side fridge/freezer won't cool.
call a repair service it probably need freon added to system and that is not a consumer FIX
Aug 27, 2017 | General Electric Refrigerators
Ge tfx25jrbb-ww refridgerator not cooling
The first thing to check is if you can hear the fan running inside the freezer. This not only keeps the whole freezer cold it alspo circulates air down to the refrigerator keeping it cool as well.
May 28, 2012 | GE Refrigerators
Freezer has to be thawed out every 2 to 3 days. The refridgerator side isn't staying cool enough to keep milk from spoiling. It is a Hotpoint Model #HSS25GFTA WW and is only 2 1/2 years old. It is a side...
Could be multiple problems. First, check the freezer compartment and make certain that the freezer fan is running. This fan moves cold air from the freezer compartment to the refrigerator. If it's not running, inadequate cold air gets to the refrigerator.
Your having to defrost manually sounds like there could be a problem with the defroster circuitry; however, check out the fan operation first.
The fan should be at the top of the freezer. There is probably an access panel you can remove to see if it's turning. However, you should be able to hear it if it's turning.
If the fan is not turning, you will need to remove it and replace it.
Oct 11, 2009 | Refrigerators
Looking for a troubleshooting guide for ge model gss22kgmc ww. Freezer coils ice up. Suspect there is a defrost timer, or some type of sensor that monitors this function. I need a little jump start to find...
In the event this may help someone else here's a link to the technical service guide.
www.applianceaid.com/pictools/gefridge1.pdf
Reasonably priced parts can be sourced at
www.repairclinic.com
It's not hard to do most of the work with simple tools.
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge isn't cold
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
May 28, 2009 | Refrigerators
GE PSS26SHRSS Side by Side Refrigerator Logo
623 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
