Question about Bulova Watch
Nina Myers interchangeable watches
How do you chnage the bevels and straps
  • Anonymous Dec 29, 2008
    I have a Nina Myers interchangable watch but cannot work out how to change the face or the strap.
I need a replacement band for a fossil watch number 741010; I see a number on the band of 7413500. Could you help me find a replacement band?
On the back of the watch should also be a 6 digit code consisting of 2 letters and 4 numbers. For instance CH3000.
With that code you should be ablte find your strap here: http://www.mastersintime.com/en/straps/
Oct 17, 2017 | Fossil Watches
Where to get a new. Watch strap
You can get Watch strap and everything of watch from The Prime Luxury Boutique. It is an authorized luxury watch retailer. http://theprimewatches.com/
Aug 09, 2014 | Rado Diastar Anatom Jubile watch
How to change the watch strap, resin type
One way to change a watch strap, is if you have any old watch straps you can use them. There should always be a bump by the actual clock. You should be able to manuever the watch out of the two small holes by using your fingers. You can then interchange watch straps!
Jul 14, 2011 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
My diesel DZ1131 watch's strap has broken for the second time ina row..i wou like to replace it with metal starp....would it be possible///
Unless the watch has a unique design on lugs for the strap, you should be able buy a strap that is interchangeable with the existing one form most watch shops.
They will usually fit it for you for nothing.
Mar 06, 2011 | Diesel Strap DZ1131 WW Watch for Men
I need a replacement watch strap for my diesel DZ7100
Many stores such as Wal-Mart, Target, etc. sell replacement watch straps in their jewelry department. They may even replace it for you. Also many jewelers will have replacement straps and will install it for you. It looks like this watch has a very wide strap, so if you can't find exactly what you need, you may have to contact the watch manufacturer directly. Google Diesel watches.
Jan 13, 2011 | Diesel Strap DZ7100 WW Watch for Men
BJ8050-08E can the rubber strap be replaced by the s.s.band.citizen says no,but i find it hard to belive they would change the case between the 2 models
I was also looking to replac the band on my BJ8050-08E. Beleive it or not, the models have different cut outs and are not interchangeable. Below are photos of the two different cases.
Apr 15, 2009 | Citizen Eco-drive BJ8050-08E Wrist Watch
Change ******** Anne Klein watch
Your watch comes with interchangeable bezels, not faces. Bezel is a ring or rectangle (depends what shape your watch has) surrounding a glass.
All bezels are mostly friction fitted,so, to remove your bezel you need to use a strong knife blade and press it between the bezel and the case. The bezel should lift up.
To get the bezel back you have to press it into place.
For changing the strap you have to turn watch upside down and using the knife or lug tool try to squeeze sprigbar end out of the watch lug. Sprinbar is the piece which holds a strap attached to watch. The end of springbar you will find exactly where the strap is attached to watch. Push it inwards and it must come out. The rest is like 2x2.
Good luck.
Dec 19, 2008 | Timex 1440 Nylon watch
Bulova Watch Logo
573 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
