Question about Helio Ocean Cellular Phone
How to reset security password
I have a preowned cricket samsung messenger
    Problem Solver:
  • 6 Answers
***SOMETIMES**** when you add the esn of that phone to your account the security password will be "changed" to the last four digits of your phone number. Don't freak on me if this doesn't work. I see it happen a few times. Good luck!
Posted on Jan 29, 2009
How to reset Admin password on Samsung SDR-C5300N Digitalvideo recorder
If you have forgotten your admin password on a Samsung Security DVR, most experts would suggest that you have to contact Samsung and/or send it back to Samsung to have the administrator password reset. While this is true in some cases, it is not always necessary.
Many Samsung Security DVRs have a built-in reset that will allow you to wipe the settings of the device and reset the configuration, including the administrator password. Note that if you perform one of these resets, all settings will be erased and you will have to setup the DVR again. So you should only do this as a last resort - but to reset an admin password, the last resort is the only option.
Reset Procedures for Samsung Security DVRs
There is more than one reset procedure for Samsung Security DVRs, depending on the series and model. But in total, this only amounts to a handful. Since one reset can apply to several different models, I'll provide the resets here so you can try them on yours - I won't associate any one reset with a single model because a complete list of which reset works with what model Security DVR simply doesn't exist. Some of these won't make sense based on the buttons available on your unit or your remote. In those cases, just skip that reset procedure.
If you can perform a reset (in other words, if the instructions match what you have available on your Samsung Security DVR and/or Samsung Security DVR Remote), try it, and let us know in the comments if it works and on what model. If you tell us which model Samsung Security DVR you have, along with your results of each reset procedure, we can compile a complete list of reset procedures by model so that it will be easier for those seeking this information in the future to reset their Samsung Security DVR. Also, if you have a reset that you have used and you know works, let us know and we will add it here. I will update the list of Samsung Security DVR resets/recoveries as I encounter them.
So if one of these doesn't work for you, you may want to check back occasionally. In fact, if you leave your model number in the comments and any specifics about your problem, I'll try to get that specific reset for you. For any of these comments, just use the comment section at the bottom of this page - it is checked regularly.
Samsung Security DVR Default Password
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Steps to Reset your Samsung Security DVR
Samsung Security DVR Reset Procedure #1
Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
Then enter the 4321.
Samsung Security DVR Reset Procedure #2
Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3
This reset will work on Android based DVRs only. All steps are performed on the device itself.
Turn the device Off
Wait 2 minutes
Press and hold the following buttons
POWER,
HOME
VOLUME UP
The unit should power on. Once it does, you can release power.
Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
Activate the reset using the HOME button.
When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4
This reset will work on SDR models. It may also work on other models.
With just the cameras showing, press the following in quick succession using the remote:
Freeze
Alarm
Freeze
Alarm
Freeze
Menu
Enter
Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5
This reset will work on SDR models where procedure #4 failed. It may also work on other models.
Press the DVR Button to place the system in DVR Mode
Press:
Freeze
View
Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
Samsung Security Reset Procedure #6
Courtesy Sergio Ayala
To factory reset the SDR-B74301
Reboot the DVR
Once the DVR has rebooted, enter the following sequence on the remote:
UP, RIGHT, 5, 3, 3
You will be prompted to do a factory reset. Confirm
This has been confirmed by several people. Thank you, Sergio! If this works for you, please thank him in the comments below.
These reset procedures cover many Samsung Security DVRs, but not all.
CCTV Networking Technical Support
Oct 07, 2017 | Samsung Home Security
Tip
How to fix lock codes, loop issues and other problems with Samsung Messenger 2...
Download SAMSUNG PST for the SCH-R560... It will say Cricket but it also works for the Metro PCS version. Here you have a variety of options such as Backing up your Data, Reloading the Software. Changing the BIN...(Flashing).., also It has a Refurbish option which will reset the phone to where it acts like it just came out of the box. THIS WILL DELETE ALL YOUR INFO, and you will have to reactivate your phone so be careful.
Download SAMSUNG PST for SCH-R560 (Messenger II)
http://www.megaupload.com/?d=M1NG4K1Q
Email me at carcrazy2320@yahoo.com if you need help!
on Aug 08, 2010 | Cell Phones
How to reset password for a samsung SDE-3004N DVR home security system. There is no remote for the system and have lost the password.
  1. Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
  2. Then enter the 4321.
  1. Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3 This reset will work on Android based DVRs only. All steps are performed on the device itself.
  1. Turn the device Off
    Wait 2 minutes
    • POWER,
    • HOME
    • VOLUME UP
  2. The unit should power on. Once it does, you can release power.
  3. Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
  4. Activate the reset using the HOME button.
Samsung Security DVR Reset Procedure #4 This reset will work on SDR models. It may also work on other models.
  1. With just the cameras showing, press the following in quick succession using the remote:
    • Freeze
    • Alarm
    • Freeze
    • Alarm
    • Freeze
    • Menu
    • Enter
  2. Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5 This reset will work on SDR models where procedure #4 failed. It may also work on other models.
  1. Press the DVR Button to place the system in DVR Mode
  2. Press:
    • Freeze
    • View
    • Return
Samsung Security Reset Procedure #6 Courtesy Sergio Ayala
  1. Reboot the DVR
  2. Once the DVR has rebooted, enter the following sequence on the remote:
  3. UP, RIGHT, 5, 3, 3
  4. You will be prompted to do a factory reset. Confirm
Sep 18, 2017 | Samsung Home Security
My screen is shattered so I forgot my voicemail password and called but I can't see the default number can you send it through my email
We don't send anything via email.
You need a new screen.
A shattered screen has nothing connected to you forgetting your password.
Contact cricket.com direct
https://www.cricketwireless.com/support
Feb 12, 2016 | Cell Phones
Samsung r261 shuts itself off
Pl try resetting it.The procedure is as follows:
  1. Press the Menu softkey > Settings > Phone Settings > Security
  2. Select Security
  3. Enter Lock Code
  4. Note: The default lock code is the last four digits of your mobile phone number
  5. Select Reset Phone
  6. Press Yes
SCH R261 Chrono FAQ List Cricket Samsung
Jun 14, 2014 | Samsung Chrono R261 R 261 Cricket Camera...
Can't remember password
According to me you can use "Forgot Password" option to reset your password (you will need to answer your security question or to provide alternate email address to send password reset mail). If still you are not able to reset password (with "Forgot Password" option) then you can use messenger password recovery software (click http://lmgtfy.com/?q=yahoo+Password+Recovery+stellar to search) to recover it.
Nov 15, 2012 | Yahoo Messenger
How do i unlock a cricket samsung messenger when you forgot the security code
hi,
reset eeprom to return in 8 zeros (00000000 ) your password ..to do this type in your phone , *2767*3855# wait until reboot ,then type it again *2767*2878# ...i hope this will fix your problem..thanks for trusting fixya
Jan 28, 2011 | Samsung SGH-D900 Cellular Phone
Is there a way to master reset a samsung SCH-r211 phone? And can you direct me to a source for secret codes and functions of this model of phone?
This seemed to fix a glitch I was having with mine.
How Do I Reset My Cricket SCH-R211 Phone?
To reset the handset, to the factory default settings, follow the steps below:
  1. From the standby screen, press the left soft key for Settings
  2. Select Phone Settings (5)
  3. Select Security (3)
  4. Enter the lock code, default password is the last 4 digits of cell phone number
  5. Select Reset Phone (4)
  6. Press the left soft key for Yes to confirm resetting the handset to factory default settings
Note: Reseting the handset, to the factory default settings, will not delete any contacts
Source:
http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view.jsp?SITE_ID=22&PG_ID=557&PROD_SUB_ID=799&PROD_ID=1597&AT_ID=149386
Dec 26, 2009 | Cell Phones
Cannot sign-in in yahoo messenger
hello, you have to click on that password recovery botton and enter your security question and anwser so they can reset your password for you
Nov 09, 2009 | Yahoo Messenger
I really need the code to unlock my cricket phone
select reset to defalt. it will reset the system to the way you got it at the store. it WILL NOT format your mp3. it only resets it incase a problem like this happens
Jan 12, 2009 | Sanyo S1 Cellular Phone
Helio Ocean Cellular Phone Logo
382 people viewed this question
Top Helio Cell Phones Experts
Shehu Pro
Shehu Pro
Computer Repairing
Computer Repairing
Are you a Helio Cell Phone Expert? Answer questions, earn points and help others
