Question about Black & Decker Dewalt DW3123 12" x 32 and 80 Tooth 1" Arbor
Nut thread is stripped
It also says dewalt on it. the problem is the nut that holds the blade is stripped ,the shaft threads are ok. I need to know the size of the nut and number of threads. Father was trying to make Christmas gifts but this has been a hard item to find/or to fix. This is a 1975 Radial Arm Saw. Please help.
thanks Carl.
  • bonniexcarl Jan 03, 2009
    Thanks for your help. Saw is fixed he is back at making the Christmas gifts. (a bit late but its the thought) A+++++
  • 2,176 Answers
This is an older saw and DeWalt does not have it online to check parts. They suggest that you contact a local service center for that information. I also tried a couple other sites that sell replacement parts with no luck. If you cant find it let me know and I am in contact with a local Dewalt center where I work and will call them for you.
Posted on Dec 28, 2008
  • David Ford
    David Ford Dec 29, 2008
    checked with DeWalt today and they think that part number is 80109-00 list for 10.48. There computer does not give the thread size. Hope this solves your problem.
    Dave
LT2000 craftman mower bolt and nut that tightens blades keep coming loose
Get some red lock tight and put it on the spindle shaft threads. Sounds like the threads are worn down and just won't hold the spindle nut tight any longer.
Jul 02, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need to know how to change blades on 42in zoom z turn
To make it easy for repair, jack up lawn mower from the front, use jack stands to support the front frame, if you have a engine puller handy you can hook a chain to the front frame. There should be a 5/8 or 9/16 bolt or nut on lawnmower blade, need a impact driver to remove, do not remove with a wrench or hand tools or you risk of breaking the mandrels. Be sure to check the splines that hold the blade on place for ware and when installing them be sure you have a snug fit and hold the blade in the slot and insert nut or bolt back in place, if the blade is not in the slot you can strip the shaft and it will have to be replaced. It is good to put anti seize on the bolt or nut threads to make it easier to remove and install.
May 19, 2014 | Ariens Zoom 42 In 165 HP Briggs Stratton...
My saw powers up but blade is not moving
Is it belt driven and the belt is slipping or broken?
Is the shaft nut holding blade on loose?
Reverse threads are used on the nut to hold the blade. Was the wrong nut used and the blade is not tight?
The bearing on the blade shaft could be frozen.
Some of the possibilities I could think of so I hope this helps.
Oct 07, 2013 | Saws
I need an owner's manual for a Rockwell 34-660 model table saw. I want to replace the blade but the entire shaft turns when I try to remove the shaft nut from the shaft.
You might be able to find a manual here.
You need to lock the blade in place so it doesn't rotate when you loosen the arbor nut. Many older rockwell saws actually had a detent ground in the shaft behind the blade that allow the use of a second wrench to hold the shaft from spinning while the nut is loosened. It takes a special thin wrench to get in there, and the ones that came with the saws were bent just behind the head of the wrench to get around the blade and out the throat, but if you know anyone with a delta tablesaw they may have one you can borrow, or perhaps you can grind down an old cheapy that fits.
If that's not the case, try the instructions I gave in this link.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 05, 2011 | Saws
How do I change the blade on a dewalt compound (12 in) miter saw?
With the saw unplugged - The blade needs to be locked in place so it will not turn when you put a wrench on the nut located on the left side of the blade that holds the blade on. This is done with a locking pin on the right side of the blade. Push the pin in and rotate the blade by hand until the pin locks into the blade and prevents it from moving. With the pin pushed in put a wrench on the large nut on the left side of the blade and turn it. This may be reversed threaded, so you may have to turn the nut clockwise in order to loosen it. When tightening the nut after replacing the blade, you will have to once again lock the blade with the same pin.
Perhaps this video will help you locate the locking pin.
http://www.youtube.com/watch?v=oKmIB-0AE1w&feature=related
Aug 28, 2010 | Dewalt Saws
Shaft turns while trying to remove blade on B&D MM875 elec. mower
Here's the scoop on the MM875: it has a plastic piece called a "blade insulator" (part # 241381-01) that "locks" the shaft to the blade, so that you can remove the nut by stopping or blocking the blade. If it has been damaged or stripped out, then stopping the blade won't do anything. However, the metal spacer directly under the nut IS still locked to the shaft (because of its shape), so you can use a pipe wrench or something to hold that in place and unscrew the nut. You might even be able to get someone in a home improvement store to do this for you. But you will still need to replace the insulator, which is only a few dollars.
Jul 22, 2010 | Black & Decker 19" Electric Lawnhog...
Troy Bilt 34073 mower - stripped spindle-shaft?
Bet on it- you might try adding an additional nut of the right size/thread or several washers to utilize the remaining healthy threads.
May 14, 2010 | Troy Bilt 5.5hp Self Propelled Mower
How do I remove the fan from an electrolux EGC652 oven
The model no. does not seem correct.but it seems as if the hole in the fan blade which is normally D shaped has worn round.The thread on the shaft is Left handed and you will need to undo by turning clockwise. If you can get a vice grips at the back of the blade to hold the shaft then try again,or you will need to get into the back casing and try jamming the shaft at the motor housing you may need some help.Then if that works you will need to undo the 3 bolts holding the Motor body to the rear casing.The new fan would normally come with new bolts,blade and nut.To tighten fan blade nut use a 10mm socket hold the fan blade and tighten anticlockwise.Hope this is helpful.
Good luck.
May 04, 2010 | Electrolux Ovens
Are the nuts holding on the blades reverse threaded?
If a blade, when viewed from above, rotates clockwise, it will have right-handed threads. This is because the shaft is turning to the right, and the resistance imparted on the blade will tend to tighten a right-handed fastener. If a blade rotates counter-clockwise it will have a left-handed fastener. I don't know this mower, but this is a universal thing.
Apr 23, 2010 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
Lost the brass retaining nut which holds the saw blade in place
You can probably find one at http://www.toolpartsdirect.com/ But I can't help you much because you didn't provide enough info about your saw. One thing that might be helpful to you is to know if it's a right- or left- handed thread. If you view the arbor from the end where the nut goes on, and the blade rotation is counter-clockwise (which is the case for most table-saws) it will be a right-hand thread. If the blade rotation is clockwise (which is the case for probably all radial-arm saws) it will be a left-hand thread. Another thing is to know is the diameter, 5/8 inch being the most common. I don't think there is a lot of variation in the thread pitch for a given diameter. If this is helpful, please vote.
Jan 28, 2010 | Dewalt Saws
Black & Decker Dewalt DW3123 12" x 32 and 80 Tooth 1" Arbor Logo
299 people viewed this question
Top Black & Decker Saws Experts
Craig Butler
Craig Butler
Frank Mangiapane
Level 1 Expert
Mike
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
