Question about Magellan Roadmate 760 GPS Receiver
Magellan Roadmate 760 won't stay on
My Roadmate 760 will just stop working. It starts up with the power cord from the car or the AC cord. The slightest jarring of the unit causes it to turn off. It may later start up on its own. When working it works normally It is getting harder to get it to start at all. I have cleaned the cradle connect but not open the case
    Novelist:
    Scholar:
  • 86 Answers
U6 is what I think it's called. those cases weren't exactly built around the insides.. (the circuit board).. there's a small IC chip on the backside of that same card with the cradle connect. . more then likely your case has shoved off a tiny little black IC chip. if you open the case and you see a little black peice.. save it. you might have to take apart your unit though. . careful when your opening it as the RF cable will be a hazard as soon as you crack the case.. so open the case just a little bit.. then find that cable I'm talking about.. and just pull it off.. then you can open it without any further restrictions.. If: this small IC chip is the problem, then you either need to solder it back on yourself.. or have someone else do it. So.. if you open the case u pand this isn't the problem let me know.. don't put the unit back together yet. and let me know. _+Daniel
Posted on Apr 29, 2007
Part number 702142-02 has a loose connection where the power cord plugs in. I need that part and can't seem to find it online.The unit I have is the Magellan Roadmate 760
Have you had any luck with this problem.. I'm having the same issue.. Obviously a product defect... Please let me know, if you have any sollutions.. Futuresportinc@yahoo.com
Thanks in advance...
Aug 02, 2010 | Magellan Roadmate 760 GPS Receiver
How can I get the code to unlock the European map Magellan Roadmate 760
You will need to pay Magellan for the authorization code, they are the only one that can provide you with an EU code for your Magellan 760 RoadMate. Sometimes Auto Nav 2000 Plus, Inc can also assist. They have direct connection with Magellan to assist issues with Magellan products. Good Luck
Aug 04, 2009 | Magellan Roadmate 760 GPS Receiver
Stopped connecting to satellite
check battery condition also go into set up and see that the baud rate and port are set correctlyb in accordance with the manual.
Please rate my help++++Thanks for using FIXYA
May 20, 2009 | Magellan Roadmate 760 GPS Receiver
I'm trying to update a Magellan map update on my 760
plke1691
I think your problem is that you are using XP with SP 3, you cannot use anything more than XP SP2, so find yourself a friend that have an older operating system and update it. I bet you will not have any problem
Auto Nav 2000 aka GPS4ME
Apr 30, 2009 | Magellan GPS
The weakness of the 760 is the cradle. Is the power wire or the cradle loose or wiggles? You may need to buy a new cradle if that is the case. They are expensive. I soldered my power wire right into the cradle and it worked fine.
Aug 26, 2008 | Magellan Roadmate 760 GPS Receiver
Magellan 760 no satellite signal
I got a Roadmate 760 from my employer to use. It won't pick up my current location and is not working right. Help!
Jun 14, 2008 | Magellan Roadmate 760 GPS Receiver
Magellan Roadmate 760 map update problem
Just push the antenna firmly back into the base; it pivots on a coax connector.
This is typical when you drop it.
The antenna is removable.
May 24, 2008 | Magellan Roadmate 760 GPS Receiver
The cord for the roadmate 760 takes a 3 amp 250 volt fast blow fuse.
Feb 09, 2008 | Magellan Roadmate 760 GPS Receiver
Magellan 760
sounds like your power dock is the culprit, not the internals, you can purchase one from circuit city or tigerdirect.
Sep 19, 2007 | Magellan Roadmate 760 GPS Receiver
this is a known issue with the power dock on the back. It needs to be replaced.
Aug 14, 2007 | Magellan Roadmate 760 GPS Receiver
Magellan Roadmate 760 GPS Receiver Logo
184 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
