Question about Sirius Satellite Radio S50-TK1 Satellite Radio Receiver with Car Kit
Live feed will not prodcast
When docked into either vehicle or home docking station live feed will not prodcast anymore. It locks up on the Sirius logo. I can enter into my playlists but can no longer receive a live feed. I worked all possible solutions including updating software and restoring defaults. Neither providing a solution. Any suggestions?
Re: Live feed will not prodcast
Go to device settings and scroll to reset channels and press it. after the update the unit will not lock up anymore.
Posted on Oct 22, 2007
Re: Live feed will not prodcast - Sirius Satellite Radio S50-TK1 Satellite Radio Receiver with Car Kit Home Satellite Radios
Could be the connection pin problem.
Posted on Oct 10, 2007
0 characters
3 Points
Keeps coming up no antenna detected...changed antenna ...same problem
Sounds like it could be the dock itself, but could also be the radio. Do you have other docking stations to test it out in? If it works in one dock but not the other, we know its the dock that needs to be replaced. If it does the same thing in both docks it is probably the antenna connection in the receiver.
Jun 14, 2011 | Sirius ST5TK1 XM SIRIUS Radio Receiver...
I'm considering purchasing a Sirius Stiletto 2 Satellite Radio Receiver - just wondering if it can it be connected to my new Harmon Kardon 3600 avr or do I need to buy the Sirius connect SCH1 Home...
You will need to use the aux input from the top of the unit, or from the back of your home dock. If your receiver has a built in or add-on dock for the XM2GO line of radios, you will need to read here:
Jan 08, 2011 | Sirius Stiletto 2 Satellite Radio Receiver
Antenna not found sirius satellite radio
You may have a defective satellite antenna or cable
Nov 09, 2009 | Sirius Satellite Radio Receiver
Sirius Sportster 5 won't power up.
Check the fuse in the power to the dock. They blow out all the time.
Mar 16, 2009 | Sirius Sportster 5 Satellite Radio...
Logo only
Bad news my friend. That model isn't supported anymore. Sirius is pretty good about replacing the radio for free and discounting the accessories. You will get one for free. The docks are reasonably priced. The boombox you might be able to get a discount for. The new docks are more designed for multiple units should this happen in the future to you again (like Stratus radios).
There isn't much to service on the radios. If the board is dead it isn't worth fixing. It's cheaper for Sirius to replace it.
Aug 26, 2008 | Sirius Satellite Radio Sirius Starmate ST1...
Audio stuck on high
You cannot adjust the volume when the stereo cord is plugged into the back of the dock. Instead, plug the stereo cord into the front headphone jack of the dock. You will be able to adjust the volume then.
Mar 11, 2008 | Sirius Stiletto 2 Satellite Radio Receiver
S50 got hot
I have the same I also live in AZ...I even bought a new battery online but that did not work. The unit will not power up in the car dock or on my home dock...even with a new battery. Not sure what to do...I do not want to have to buy a whole new unit since I have all the docks for car and home...Help on this would be great!
Dec 12, 2007 | Sirius Satellite Radio S50-TK1 Satellite...
Sirius sportster sp-tk1, always displays "acquiring signal"
Sirius does not stand behind their products, There is no out of warranty repair for their radios,  and they do not offer sites for repair. Seems  like this is a definite problem with this model. Their solution is to buy a new radio,(with all the new-docking,boombox etc) accessories. also they charge $75.00 to change to the new radio.I liked my sportster 1 because of the FM modulator. It just had to be centrally located and all the radios in my home picked it up(no docking) the new radios require $50.00 docking stations for each stereo location and radio location, unless you bring a boombox everywhere, and the sound isn't the same.    I feel there should be a class action lawsuit against Sirius for these reasons and I might look into it. What do all you think?
Dec 03, 2007 | Sirius Satellite Radio Sirius Sportster...
Live feed will not brodcast
From what I've read you might simply call Sirius or go on-line and re-initiate your subscription. Try it, it might work for you.
Apr 15, 2007 | Sirius Satellite Radio S50-TK1 Satellite...
Sirius Satellite Radio S50-TK1 Satellite Radio Receiver with Car Kit Logo
135 people viewed this question
Top Sirius Satellite Radio Home Satellite Radios Experts
Colin Stickland
Colin Stickland
Tom Chichester
Are you a Sirius Satellite Radio Home Satellite Radio Expert? Answer questions, earn points and help others
