Question about Lands Phones
At&t digital answering with 4 expandable model # E5913B
I have 2 remote phones with the at&t answering machine. All three are showing "connecting" in the window. When I punch the menu button it will show "de register - no?" when I push the menu button again it shows "place in charger". How do I get these 3 phones back into operation???
The answering machine still works.
SOURCE: Uniden DCT648 register phone problem
I have contacted Uniden about solving this problem. They suggested I clear the eeprom on the handsets and reset the base. To clear the eeprom detach all of the batteries and reattach while holding the star and pound. You'll hear a beep. Press select and the unit will clear the eeprom. Now hit end and the unit will say "Welcome...something or other". Next unplug the base unit reattach while holding delete. Next hit delete twice...the base is reset. Apparently this is the last possible solution to marrying the handsets and base. This didn't work for me and the units have been declared dead. Good luck in solving your electronic problems.
Posted on May 14, 2007
SASSYBEAR
  • 148 Answers
SOURCE: vtech,5.8 3-phone w/digital recorder, model
To deregister ALL handsets:
Step 1: Press and hold FIND HANDSET on the main telephone base for 10 seconds.
Step 2: When the IN USE light starts to flash, release the FIND HANDSET button.
Step 3: Press and release FIND HANDSET again. The IN USE light will turn off and in a few seconds, all handsets will be de-registered.
Step 4: All handsets will show NOT REGISTERED.
To register a handset (register 1 handset at a time):
Step 1: Place the handset in the base unit or a charger that is connected to a power outlet. If PRESS FIND HNDST 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and place in base or charger again.
Step 2: On the telephone base, press and hold FIND HANDSET for four seconds. Release FIND HANDSET once the IN USE light comes on.
After a while the handset will emit a series of tones, the newly registered handset will be assigned the lowest extension number not previously assigned to another system handset (1-4) when successfully registered. Repeat Steps 1 and 2 if the handset does not successfully register to the telephone base within two minutes.
REPEAT THE REGISTRATION PROCEDURE FOR EACH SYSTEM HANDSET.
Make sure the handsets are not receiving interference from other appliances, cell phones, etc.
IF deregistering does not work .. you will need to reset the entire system
Step 1: Disconnect the power to the telephone base.
Step 2: Disconnect the handset battery.
Step 3: Wait a few minutes and then reconnect the power to the telephone base.
Step 4: Reconnect the handset battery
Step 5: Wait about one minute for the handset to re-establish a link with the telephone base and then test the phone again.
You will need to set the time and date again after resetting the entire system.
Posted on Mar 11, 2008
SOURCE: Phonemate 8800 answering machine (micro
"E3" says "Incoming message tape is missing, stuck, or broken. Replace the tape" I had the same message. My drive belt broke. I put a rubber band in it's place and all works OK now. I need to order a new belt, but haven't yet.
Posted on Mar 18, 2009
  • 44 Answers
SOURCE: phone numbers not showing on caller id LED screen.
disassemble the handset (if you can figure out how to get it open). Flip the LCD screen over so that you can get to the end of the wire ribbon. You want the end that is connected to the phone, not the LCD screen. Carefully use a heat gun or hair dryer to heat the cable being careful not to melt it. Your goal is to melt the glue that connects the tiny wires to the electrodes. When glue is melted use a pencil eraser to press the wires so that they make contact again. Let it cool and try it out. It should work well after that. Put your phone back together.
Posted on Jun 28, 2009
SOURCE: cant register/install a new dect 6.0 uniden 2060 phone
When you select register on the base, you need to press and hold # on the phone... the instructions below worked for me, finally, to get the stupid waterproof handset registered. whew!
Registering the Handset
If you have purchased this accessory handset separately, it must
be registered to the base before you can use it.
Notes:
• The handset must be fully charged before attempting to register.
• Only one handset can be registered at a time.
1) If the other base has an LCD display:
• With the phone in standby, press [Menu/Select] on the base. Press [down] to move the cursor to REGISTER HANDSET and then press [Menu/Select]. HANDSET
REGISTERING appears.
If the other base does not have an LCD display:
• Disconnect the base AC adapter. Then press and hold
[find hs] or [find] while you reconnect the adapter. Keep
pressing [find hs] or [find] until the charge/in use LED
starts to blink.
2) On the handset, press and hold [#] until the handset beeps and displays HANDSET REGISTERING.
3) When the handset finishes registering, it shows REGISTRATION COMPLETE in the display.
Posted on Jul 20, 2009
I have e5927b base & e5913b only showed connecting only how to reg ??
The replays met phone#e5927b trying to register to bruised at 4 unit
Jan 24, 2015 | Lands Phones
Remotely turn on answering machine
Select the model of your Uniden 5.8GHz system from the list beginning at http://www.uniden.com/owners-manuals/cordless-phones/scat/cordlessphones_mnl to download a copy of the manual.
Feb 06, 2013 | Uniden 5.8GHz Expandable Cordless Phone...
Power out for 10+ hours. Two of three handsets not connected - say "searching". Can't find the manual. How do I reconnect? DECT 6.0
Since you declined to specify the model of your Uniden DECT 6.0 system, select it from the list beginning here to download a copy of the manual.
Sep 09, 2011 | Uniden 5.8GHz Expandable Cordless Phone...
I have a DECT 6.0 and lost the manual. How do I retrieve messages remotely.
There are several models of DECT 6.0 phones by Panasonic. The manuals for most can be found by finding your model in this list: http://www2.panasonic.com/webapp/wcs/stores/servlet/PNAEndecaSearchCmd?N=779832097&Ne=&Ns=&Nr=12001&No=0&Ntt=75513&Ntk=CategorySearch&URL=vSupportSearch&cn=DECT+6.0+Phones&cmTag=true&catalogId=11017&storeId=15001 .
For the phone I know, the remote access code must be enabled. Dial the home phone number (with a touch tone phone) and at the greeting enter the remote access code. Then press 4 to hear new messages and 5 to hear all messages. Press 1 to repeat a message or 2 to skip a message. Press *4 to erase the message currently being played. *5 deletes all messages. When done press *# or hang up.
See the manual for more information. There is a default code listed in the manual.
I hope this helps.
Nov 17, 2010 | Panasonic DECT 6.0 Expandable Cordless...
I have a uniden dxai8580-2 answering machine. how do i get messages from a remote location
The remote access cheat sheet is at the bottom of the first page of this manual.
Aug 13, 2010 | Uniden 5.8GHz Expandable Cordless Phone...
How to remotely access answering machine
Since you neglected to specify the model of your Uniden cordless system I can only suggest you select it from the list beginning here to download a copy of the manual and the remote access instructions.
Oct 01, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Lost my manual and cannot remember how to get messages remotely
Since I have not idea what exact model you have this may or may not work... I hope it helps, as it is for a Uniden answering service phone.
Remotely Operating Your Answering Machine
Note: The answering machine will only playback messages for four minutes and then it returns to the command waiting mode.
To continue playing your messages, press [#] then [2] again within 15 seconds.
To operate from a remote location, use any touch-tone telephone and follow these steps:
1.) Call your telephone number and wait for the answering machine to answer
2.) During the greeting message, press [#] and enter your PIN code within 2 seconds;
How to enter a PIN
To play your messages from a remote location, you will need to enter a two-digit Personal Identification Number (PIN) or PIN Code.
Press the MENU soft key. Select the ANSW. SETUP menu, and then the SECURITY CODE submenu.
Enter a two-digit security code (00-99) using the number keypad [0-9].
Press the OK soft. You will hear a confirmation tone.
The answering machine announces the current time and the number of messages stored in memory.
You hear "To play incoming messages, press pound-two. For help, press pound-zero." You will hear a beep.
Enter a remote command within 15 seconds, each command there after must be entered within 2 seconds. You may select a command from the following:
# then 1 Repeat a Message
# then 2 Playback Messages
# then 3 Skipping a Message
# then 4 Deleting a Message
# then 5 Stop Operation
* # then 6 Answering Machine On
# then 7 Memo Record/Stop**
# then 8 Greeting Record/Stop**
# then 9 Answer Machine Off
# then 0 Help Guidance
Apr 27, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
SW Bell FA-980 Answering Machine
Here is a link to a similar model: http://www.swbfreedomphone.com/ib/ibansw/fa970.pdf Here is what it says: TONE REMOTE OPERATION Remote Security Code To access answering functions from an outside line, you will need to enter the three digit security code located on the bottom of your unit. Write this number on the Remote Access Card, which you can keep in your wallet. Remote Turn On If you forget to turn on your unit: 1. Call your unit from a touch-tone phone. 2. Wait 12-14 rings until the machine answers. 3. The FA970 will automatically answer by playing your greeting. You may hang up the phone, and subsequent calls will be answered. Remote Message Playback 1. Call your unit from a touch-tone telephone. 2. After your FA970 answers, it plays the outgoing greeting and beeps once. Dial your three digit security code within 20 seconds after the beep, pressing and holding each digit for 1-2 seconds. Allow a 2 seconds interval between each digit. 3. Your FA970 will sound one beep to indicate the code was entered correctly. (If there are no beeps, enter your code again.) 4. You can press the following buttons on your keypad: Option Press Playback Mailbox 1 Messages (1) Playback Mailbox 2 Messages (2) Record Memo Message (3) Record New Greeting (8) Turn Off Answer Mode (9) If you press ?1? or ?2? (to playback messages), you have the follow options: Option Press Erase Current Message (0) Repeat Current Message (4) Repeat Previous Message (4) repeatedly Stop Message Playback (5) Skip to Next Message (6) To SAVE messages, hang up the telephone. Note: Your FA970 will sound a series of beeps if there are no messages. Remote Record New Greeting If you press 8 (to record new greeting): 1. When you hear a beep, begin recording your new greeting (up to 30 seconds). 2. When you have finished recording your new greeting, press (5). The unit will beep, and the new greeting will playback to you. 3. Hang up the telephone. Remote Record Memo If you press 3 (to record memo message): 1. Within three seconds of pressing ?3?, press ?1? or ?2? to select Mailbox 1 or Mailbox 2. Otherwise, the memo will be recorded in Mailbox 1. 2. When you hear a beep, begin recording your memo (up to 60 seconds). 3. When you have finished recording your memo message, press (5). 4. The corresponding Mailbox message count will be increased by one. To Retrieve Messages when Recording Memory is Full 1. When the message capacity is full, the unit will sound 3 beeps after answering the phone. 2. Within 20 seconds after the 3 beeps, dial your 3 digit security code. 3. Your FA970 will sound one beep to indicate the code was entered correctly.
Mar 22, 2007 | Southwestern Bell FA970SN Digital...
Lands Phones Logo
88 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
