I have downloaded WMA files to MP3 player, but it does not open them. What can I try to make this work? Thanks.
    President:
  • 373 Answers
Convert the wma files to mp3 using any audio conversion software like say audio jack. you can find many software free versions online to help on this.after conversion you can later add them on your mp3 player
Posted on Dec 25, 2008
GazllFixIt
  • 103 Answers
SOURCE: Unknown Format
It sounds like these wma files have DRM protection.
You can still play these songs on your mp3 player, but you must use Windows Media Player to transfer them.
To do this, connect your mp3 player to your computer, then open Windows Media Player. In WMP select "Sync" & you should see your mp3 player in the right-hand pane. Drag & drop your wma files across. It's a slow way to do it, but the only way to transfer wma files with DRM.
Let me know how you get on!
Posted on Jan 10, 2008
SOURCE: Can I download WMA audio book files onto by Coby MP3 player?
copy and paste the files
Posted on Feb 03, 2009
hakmilton
  • 79 Answers
SOURCE: I have an Etec 4 GB player not playing wma files.
please check out this link as the audio converter may solve your problem (its free)
http://www.nch.com.au/switch/plus.html
Posted on Jan 31, 2010
Thermo King
  • 593 Answers
SOURCE: Can't play WMA protected files?
You may be able to, if our player supports MTP mode. You will have to see if the mode can be changed from MSC mode to MPT. for a better explanation of these terms go to this tip posted here -- Solve your MP3 Player Connection Problem.
SOURCE: I am trying to download WMA files to a Jensen
I went through the same thing then I found the Disk. But while looking I found the software on line.
You need a .AMV Converter the player resolution is 208x176
Here is the software your looking for...... it is the same as what is on the disk. If you use the arrow to the right hand side it should let you send the converted file to the player when it is finished.
http://www.megaleecher.net/AMV_Video_Converter
Good Luck....... I had a time looking for this program
James
Posted on Jan 17, 2011
How can I download music from computer to Mp3 player
1. Get on Computer 2. Plug in USB cord in the USB slot on the main computer. 3. Open My Computer and it should say on the side there is a USB device or the type of MP3 players name. 4. Open up another My Computer window. 5. Goto the location your music files are located and make sure both windows are visible on the screen. 6. Drag your music files to your MP3's music file section. Sometimes the music files wont work so first try the WMA (windows media audio) file first. If the WMA files dont work on your MP3, convert them to MP3.
Jan 06, 2014 | Craig Cmp616f Mp3 Player
Convert .wma to .mp3
Click here and click on download now after that install on your system and see whether it's helpful to you or not?
Thanks for using FixYa
Aug 29, 2011 | Computers & Internet
My mp3 says file format error when I try to listen to the music.
It's possible that the file type of the music file(s) you are trying to listen to are not a supported format of your mp3 player. Your player only supports MP3 and WMA audio formats. You should check the music files you are tying to play to confirm they are of a compatible format.
http://www.cobyusa.com/files/manuals/MP300_MN.pdf
Mar 02, 2011 | Coby MP300 MP3 Player
My sons got a mw249s from their mom for xmas. i have itunes istheir anyway to put itunes music on the player? I tryed drag and drop the device showed the music loaded but cant play it.
You will first need to delete all the music from your MP3 player that you put on it. Use this method to do that: Hook up your mp3 player to your computer Go to your desktop and double left click on "My Computer" When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there. Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible. Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete" Now you mp3 player should be clear of the files/songs you do not want. BE CAREFUL AND DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER. ---------------------------------------------------------------------------- I tunes is an AAC format, it will not work with your player... You need WMA format to make the songs work on the GPX-MW3836 What you can do is covert the songs from ACC to WMA using a format converter. Then put them in a folder/file and drag and drop them to the player, or download the songs to Windows Media Player after you have converted them and then download them to your player, as Windows Media Player is WMA format. ----------------------------------------------------------------------- You can download a free format converter at this website: www.formatoz.com/ Good Luck, I hope this helped Please rate me, Thanks
Dec 26, 2009 | GPX MW3836 MP3 Player
Plays wma books, will not play mp3 books
convert the mp3 files to wma on a computer and then try
May 31, 2009 | SanDisk Sansa Clip MP3 Player
I can't get my MP3 to download and play WMA Format
Here is the asterisk behind WMA compatibility - there are two types of WMA files - protected and unprotected. 90% of WMA files are DRM-protected, hence they are either not usable in mp3 players that say they can play WMA's, or the song has a DRM restriction on it that prevents it from being played on an mp3 player without purchasing additional rights.
To avoid the problem completely, only download songs that are in mp3 format. It may be more expensive initially, but they are better in the long-term - even if you found a WMA file that eventually works with your mp3 player, the protected WMA files have an expiration date, so they would stop working after 30 days, 90 days, 1 year, or 2 years depending on the specific license for each song. Mp3 files never expire, never give you error messages, and work with nearly (if not all) 100% of mp3 players.
-Tha Mp3 Doctor
Mar 30, 2009 | Audio Players & Recorders
Disney mix max problem
Connect your player to the USB port on your computer using the USB connector on the Mix Max. A 'MIX-MAX' window will appear in your My Computer folder which is the player's internal memory. To add more files and songs to your player simply drag and drop MP3 or WMA files from anywhere on your computer into the 'MIX-MAX' window.
For Windows XP, you can utilize Windows Media Player 10 software to convert music on an audio CD into MP3 or WMA format as follows:
Open the Windows Media Player 10 Browser, then click on the 'Rip' icon on the top tool bar. Insert a Music CD into the CD-ROM drive of your computer.
Click on the 'Tools' menu option at the top menu bar, then click on 'Options'; the Option setting menu will appear. Click on Rip Music and set the Rip music to the desired location on the newly ripped music (MP3 format or Windows Media Audio format). Adjust the audio quality as desired. When finished, click 'OK' to confirm the settings.
Click on the 'Rip Music' icon to start ripping the music to your computer.
When the music tracks are ripped; connect the player to your computer. Open the 'MIX-MAX' window and open the ripped music location window.
To add the transferred/ripped music file/songs to your player simply drag and drop the MP3 and/or WMA files into the 'MIX-MAX' window.
When the files are finished loading into the player, follow the 'Safely Remove Hardware' procedure as shown below.
Note: For Windows 98SE, Windows ME, and Windows 2000, please use the Windows Media Player 9 to convert music on an audio CD into MP3 or WMA format.
Downloading WMA files with DRM using Windows Media Player 10 (for Windows XP)
To download WMA files with DRM, follow the procedure described below using the previously installed Windows Media Player 10. Before beginning the procedure please turn the unit on and connect the unit to the computer as previously described.
Open the 'Windows Media Player Browser 10' and click on 'Sync'.
Click on the 'Sync List' pull-down menu to locate the music files you wish to download. Then make sure to click the box next to the files.
Select the Portable Device that you want to copy to from the right side drop-down menu. Click 'Start Sync' to start downloading the WMA file(s) with DRM to the Portable Device.
After finished downloading all the desired files to your unit, follow the 'Safely Remove Hardware' procedure as shown below.
Note: For Windows 98SE, Windows ME, and Windows 2000, please use the Windows Media Player 9 to download WMA files with DRM to your player.
Jun 16, 2008 | Disney Mix Max Digital Media Player
Istage mp4 player
buy one that actualy works
Jun 15, 2008 | Acer MF35 MP3 Player
Unknown Format
Jan 05, 2008 | Nextar MA566 MP3 Player
Will not read the sandisk card
When RCA first came out with the Lyra series the only way to get music1.gif onto the device was by using musicmatch jukebox that would convert your mp31.gif file to mpy before downloading it to the device. But now RCA has come out with a new firm ware update for these mp3 players that improved the players playback quality plus enabled it to use .WMA files. so first go to RCA support http://support.rcaaudiovideo.com/select.aspx?u=downloads and find your player and download the firmware and drivers (if needed) upgrade and install to your player its very easy and instructions are at the same site. You can now convert your music to .wma or use the free Real player that will convert mp3 to wma1.gif at the kbps that you request before loading it on. If your music is all ready in wma format you can use windows media player to send the files to your player. One last thing the .wma files that you put on your Lyra player need to be at least 128kbps or higher enhanced playback quality of wma files (160 kbps to 256 kbps).
Oct 25, 2007 | RCA Lyra RD1080 MP3 Player
 Grubhead
Grubhead
