Question about Denon DCD-425 CD Player
Having a problem with my CD Player's drawer
I have a DENON DCD-325 CD Player. The problem is that whenever I attempt to push the "Open/Close" button in order to load a CD, the CD drawer gets opened then re-closed immediately. Do you think where this problem could be derived from? Rubbers? Gears? ..or even the worst of all the timer.. Thanks
  • Anonymous Mar 24, 2014
    The cd player doesn't read cd's in the slot, in order for the music to play. What can I do to correct it?
  • Anonymous Mar 27, 2014
    There is power to the machine but the CD drawer won't open
    Problem Solver:
  • 11 Answers
This has to do with a mini switch inside the door mechanism that it pushes once but with the bounce phainomenon in electric pulses it thinks that you pushed the cd door inside manualy and it tries to close the door. Try replacing this mini switch. this will solve your problem.
Posted on Aug 10, 2007
SOURCE:
When ejecting a cd the housing would open and close right back sometimes. How can this problem be fixed?
It sounds like the open switch inside the door is dirty & cannot make a connection when the CD door opens. Clean the switch & it should function properly. Otherwise, replace that switch.
Jan 08, 2011 | Denon DCD-3000 CD Player
I have a Denon dcd 600 cd player. Old but little used and in good condition. Used to put in a cd, close the drawer and the entire display would light up, the disc having not been read at all. After...
it's most likely the belt that drives the cd tray has perished over time and certainly if you tilt the player to help it, that's just gravity giving it a push. replace the belt and all should be ok. hope this helps?
Jan 06, 2010 | Denon DCD-425 CD Player
CD DRAWER DOESNT OPEN
Is there a small hole on the front of the load tray? If there is use a straightened out paperclip to push into the hole to remove the stuck cd. That might help you out.
Nov 19, 2009 | Denon Audio Players & Recorders
Denon CD player DCD 920. When using the open/close button once, the CD-door opens but when it is open, without any waiting time, it immediately closes again. If i operate manually the open/close switch on...
Off the power, and plug off the switch, and try opening it manually. DO NOT force open it. I don't think it would close back since it has no electricity already.
Oct 14, 2009 | Denon Audio Players & Recorders
Draw doesn't open
Hi...
I would say "belt" 1st too.
http://www.encompassparts.com/models/?DENDCD620
Belt is there.
Mar 24, 2009 | Audio Players & Recorders
Denon DCD-425 CD Player Logo
859 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
