Question about Nikon D2X Digital Camera
ERR MESSAGE, NIKON D2X
Lately my camera is sending me ERR messages. This happens after I take a picture and to resolve it I need to depress the shutter release button again. Is this a sticky shutter blade? or something more serious that I need to send it to Nikon for diagnosis and repair? I have 68k actuation's as of yesterday.
Regards,
Amado Royola
  • leocinicolo Mar 15, 2009
    The exact same problem happens with my Nikon D2x, a shot is fired, but I need to depress the shutter again to take a fresh shot, the mirror is not locking up, but a "ERR" message appears until I fire the shutter a second time.
    Problem Solver:
  • 15 Answers
The only time i have ever seen this message on my D2x is when the lens is not all the way snapped on. try re-seating the lens.
Posted on May 07, 2009
Press shutter releas button for error are coming ,wat is the Problem
1. Turn off the camera. 2. Remove the lens, battery, and CF card. 3. Allow the camera to sit without power for approximately 20 minutes. 4. Insert a fully charged battery, and turn on the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR ' message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps: 1. Turn off the camera. 2. Insert the CF card. 3. Turn on the camera. 4. Format the CF card in the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR ' message appear? If so, then the CF card is the most likely source of the issue. Try using a different card. If the message does not appear, please complete the following steps: 1. Turn off the camera. 2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body. 3. Reattach your lens. 4. Turn on the camera. 5. Depress the shutter button as you would to take a picture. If the "ERR ' message only appears when one particular lens is attached, then that lens should be examined by a service technician. If you see the "ERR ' with a different Canon lens attached, then the camera should be serviced.
Nov 17, 2010 | Nikon D40x Digital Camera
Nikon D2X - How do you lower the mirror if it gets locked up by mistake ? Had an err message on the upper view screen, tried the repair from this site, by tapping the front leftside of camera front and...
Normally, you can manually lock-up the mirror for the purpose of cleaning the sensor. To do this, you need to connect the camera to the optional EH-6 AC adapter. If after removing the lens and inspecting the mirror, you cannot gently nudge it back down (do not touch it...use a cotton swab) then you'll need access to the EH-6. If you don't have one, possibly a camera store near you would have one and be willing to let you plug in your camera so you could try to access the mirror lock-up function in the set-up menu.
Nov 08, 2010 | Nikon D2X Digital Camera
My D90 sometimes has an err message and also a CHA in the the ISO mode. Also there is a green LED on the back of the camera that stays on. The only way to get all this cleared is a battery pull. When this...
CHA indicates a problem with the SD card. ERR indicates a camera malfunction. Try reformatting the card which may clear the problem or try a different card. The card may be creating the ERR message. On page 259 of the D-90 users manual, Nikon says this error can be cleared by releasing the shutter but the shutter will not release unless you turn the camera off and back on. Rarely, I have to remove the battery and reinstall it before the shutter will release. The camera will not function at all until the battery is reinstalled.
If you cannot resolve this problem using the above suggestions, I'd recommend that you contact Nikon technical support at www.nikon.com and see if they can help.
Sep 12, 2010 | Nikon D90 Digital Camera with 18-105mm...
Nikon d80 problem (err flashing with r09 in the lcd display)
I belive this isn't a fault but more to do with how you are using the camera. The r09 message is to do with the camera buffer and how many more pictures it can hold. You do have a memory card installed, right? The r09 is normally not an error, but simply an indicator of how many more pictures you can take in the current burst before the buffer fills. The number will vary according to the image quality and size settings.
Jan 17, 2010 | Nikon D80 Digital Camera
Nikon D90 ERR message after taking picture -
Is there a memory card in the camera?
Also try cleaning the contacts on the lens (light rub with a pencil eraser works).
Aug 07, 2009 | Nikon D90 Digital Camera with 18-105mm...
My Nikon D2x is having shutter problems, HELP!
the only time i have ever seen this on my D2x is when the lens isnt snapped all the way on. but since you have tried several lenses, i am sure they are snapped on. this leads me to believe something is wrong with one of the contacts on the camera where the lens snaps on--check them to be sure they are springing out and clean. check the owners manual to see if there is another cause for this message.
Mar 15, 2009 | Nikon D2X Digital Camera
My camera say err CF
These are steps to Fix Err 99's, have a go and see if resolves your other problem too.
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Dec 28, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Nikon D70s Err message
I had the same problem with my D70.
Ended up having the shutter repaired at the tune of $135.
Works fine now.
Had the work done at Gary Camera nad Video
6750 Broadway
Merrillville, IN 46410
219-769-2451
Hope this helps
John
Oct 16, 2008 | Nikon D70s Digital Camera
Error message on D70 freezing camera operations
I got this info from Nikon for D70...
When you see Err on the control panel, LCD monitor or viewfinder of your digital camera it refers to a camera malfunction. Try the following:
  1. Remove all accessories from the camera.
  2. Install a freshly charged battery into the camera.
  3. If your Nikon camera offers resets such as the two-button reset or a hardware reset please follow those instructions provided in the product manual.
If these steps do not resolve the Err message we recommend having a Nikon Authorized Repair Technician evaluate the Nikon camera.
Hope this be useful for you to resolve problem.
Oct 07, 2008 | Nikon D70s Digital Camera
Nikon D70 Flashing
ERR is i think an error message generated when the camera can not read the cf card ? have you had an problems with corrupted images ?
Sep 24, 2008 | Nikon D70 Body Only Digital Camera
Nikon D2X Digital Camera Logo
336 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
