Question about Fedders A3DH30B2A Dehumidifier
Not dehumidifiing The dehumidifier powers on ok,and to all appearances is working,but does not produce any water in the reservoir. I took the back off and the one side is getting cold, the one with the black insulation on it, the other line is getting hotter. Any ideas as to what is wrong? Is it low on coolant? It is new but has never worked. The other dehumidifiers we have work fine in the same area that we tried to use this one. Thanks, Gary
  • Fedders Master
  • 43,501 Answers
There are many reasons for a dehumidifiernot dehumidifiing - 2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 14, 2010
My DeLonghi DD50PSC dehumidifies but the pump never comes on. Everything is ocnnected to the continuous draiining using the pump. Suggestions?
A blocked drain tube was the cause of the pump not working issue with this dehumidifier. I removed the back cover (5 screws on back, 1 screw on each side) and cleaned out the accumulated gunk in the small, clear reservoir on the back right. It took a little time using compressed air and pipe cleaners, but the effort ultimately worked.
Jun 14, 2012 | DeLonghi DE500P Dehumidifier
Tip
Dehumidifier VS. Air conditioner
A dehumidifier is basically the same thing as an air conditioner but both coils (condenser and evaporator) are in the same unit meaning a dehumidifier exhaust warm air in the same room it is in. running a dehumidifier would make an air conditioner run more because of the warm exhaust, when you run an air conditioner it acts like a dehumidifier and dries the air. As far as saving energy it all depends on the size of the AC and dehumidifier and the size of the room. If you want warm dry air, use a dehumidifier; if you want cool dry air run the AC but not both.
How do all these parts fit together to pull moisture from the air? It's fairly simple, but very effective:
  1. A fan collects air from the surrounding area and pulls it into the dehumidifier.
  2. As the air passes through, it comes into contact with the dehumidifier's cooled coils. These coils use condensation to pull moisture from the air. The collected moisture remains on the coils and drips into the dehumidifier's reservoir.
  3. The dehumidifier reheats the air and exhausts it back into the room.
A dehumidifier usually has a removable plastic bucket for are reservoir; most buckets also have a place where you can hook up a hose so the collected water can drain straight into a floor drain or pump. This frees you from having to remember to dump out the water. But don't worry too much about the reservoir overflowing -- most dehumidifiers also have an automatic shut-off. If you're using a dehumidifier in extremely moist conditions,however, or if you need to keep your dehumidifier on all the time, you should look into a unit with a built-in condensate pump, which regularly pumps water out of the unit's reservoir rather than simply relying on gravity to empty it as a hose does.
on May 18, 2010 | Dehumidifiers
The dehumidifier runs, but does not collect water in its reservoir. (the lights all light up, it cycles on and off, but all it appears to be doing is running the motor - not actually functioning.) And,...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Jun 22, 2011 | Kenmore 54701 Dehumidifier
Unit appears to operate normally, but does not produce water
heatman101
Apr 18, 2011 | Whirlpool Dehumidifiers
Hi my comfort aire dehumidifier is brand new. It was working fine controlling the humidity and the reservoir was filing with water. All at once, it acts like it is contolling the humidity, but there is...
heatman101
Apr 10, 2011 | Comfort-Aire BHD-501 Dehumidifier
I have a Amcor MD 250 about 5 years old..Everything appears to be correct but it is not producing water. Can you help
There are many reasons why a dehumidifier will not work or collect water.
heatman101
Feb 13, 2011 | Amcor MD250 Dehumidifier
AD50DSL5 portable dehumidifier is 6 years old. Now it powers up, the fan blows, coil heats up, but no water is produced. Any idea what is wrong?
heatman101
Jan 02, 2011 | Whirlpool AD50DSL Dehumidifier
My DeLonghi Portable Dehumidifier Model DEM10 has stopped working. It doesn't make the same noise when you turn it on anymore i.e the slight refridgerator sound. Does this sound like a repairable problem...
First, make sure the reservoir is empty. If you plug the unit in and see a green power light, but the unit won't run, make sure the reservoir is properly inserted. Many dehumidifiers have switches or sensors to make sure that the reservoir is placed so that it won't leak. Look for these sensors and make sure the reservoir is engaging them. If your dehumidifier has a float or switch to indicate a full reservoir, make sure this switch isn't being tripped accidentally.
Good luck.
Aug 13, 2010 | DeLonghi Dehumidifiers
When my dehumidifier is on, it says there is 90 humidity. I come back an hour later, it is still running and no water in the bucket.
If there's no water in the reservoir, first make sure that water is getting to the humidifier. The humidifier must have a good stream of water available to it. If there's water in the water line but the reservoir doesn't fill, replace the float mechanism inside the humidifier.
Take care.
Jul 29, 2010 | Haier 45-Pint Dehumidifier
Dehumidifier runs but does not produce any water.
heatman101
Jul 01, 2010 | Fedders A7DH65B2A Dehumidifier
Fedders A3DH30B2A Dehumidifier Logo
215 people viewed this question
Top Fedders Dehumidifiers Experts
Steve Allison
Steve Allison
Bill Long
dadr
Level 1 Expert
Are you a Fedders Dehumidifier Expert? Answer questions, earn points and help others
