Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Filter light on refregerator
Filter 4396508. Our light to change filter comes on more frequently than normal. Only 2 using refrig, and not very much water used.
My question is: Does the light come on based on some sort of timer, or does it come on based on restriction.----- in other words clogged up and no longer is able to filter?
If by restriction, can I install an inline filter on the water supply line to essentially pre-filter the water for a longer life of the expensive 4396508? We are retired and $80+ dollars a year for filters is a little rough on us.
Thanks, Allan
You don't need the filter if you have city water or if you you prefilter or have pretreated water. Take it out and the fridge will operate normally. I took mine out last year based on advise from a tech and no problems since (actually works better and makes better ice)
Posted on Jan 06, 2009
AFTER I CHANGED WATER FILTER IN WHIRLPOOL FRIDGERATER THE WATER COMES OUT HOT
Are you sure that your water line is hooked to cold water. It sounds like you are hooked up to hot water and not cold.
Jul 30, 2014 | Whirlpool Refrigerators
I cannot find the Water Dispenser filter. The red light alerting me to change the filter has come on and I am at a total loss. Please help.
inside the fresh food side in the back at the top shelf. filter is round and twist out and new one twist in . easy job to replace / the part # for your model is 12527301 ( orher # is WF401S ) EITHER # IS SAME FILTER .. . THANKS **** HOPE THIS HELPED ..
Jul 22, 2010 | Amana ARS266ZBS Side by Side Refrigerator
I have a ED2FHEXN Whirpool Refrigerator. Where is
Your fridge was made with 2 different types. it will be either one or the other.
the first one could be:WF-NL240 part number :#4396508 use replacement NL240
should run about $32.99
the second one could be:WF-L400 part number:#4396508 use replacement L400
this as well should run about $32.99
I would highly recommend that you contact whirlpool to find out which filter you will need since they used 2 different ones on your model.
You can reach them by phone or e-mail.
phone:1-800-253-1301
e-mail:www.whirlpool.com
I hope this helps you. IF you need further assistance please feel free to contact us at any time.
Jan 08, 2010 | Whirlpool ED2FHEXN Side by Side...
How do I change the water filter?
changing the water filter is a easy job on most ref . how ever there different models / so i will look yours up / i wil get back with you in just a min . _______ I back the part # 4396508 is located down by your toes. in the grill . .remove the grill and 1/2 turn and pull out . change the filter . you don't have to remove grill but those thad do will be able to clean the coil. ( very important . good luck hope this helped **** ..
Jan 06, 2010 | Whirlpool GS5SHAXN Side by Side...
No flow after filter change.
G E waterfilters , can be bad when new (all , not just G E ). Put your old one back in , if water flow was fine , and you replaced just because the light came on . Or , use the plastic bypass piece , which came with the refrig , when new . The replace light , works off time and/or usage times only . If you have good water flow and the cubes are normal size , don't change the filter when the light comes on , just reset the light . All "filter" companies , have found the way to sell more filters , the light on dispensors .
Sep 11, 2009 | GE Refrigerators
I have a friend with a Whirlpool ED5PHAXMB00. It's producing ice, and dispensing ice, but no water will dispense. She changes the filter evey time the light comes on, so am thinking it's not that. Have...
Some refrig's , water goes to filter first , some thru water valve first and then the filter . On this model , it goes to the water valve first , then the filter .
1) never change the filter just because the light says to . Only replace when icecubes get small or when water flow from dispensor slows . A filter can last 6 mths- 1yr. and sometimes longer .
2) the resevoir is in the refrig section , behind the lower crispers
3) the water valve is probably the problem
pt# 4389177
Sep 09, 2009 | Refrigerators
Changing filter
It looks like it is in a grille area near the floor.  There is a picture at:
http://www.fridgefilters.com/whirlpool-water-filters-4396508.html
If you call them they should be able to tell you where to look.
May 29, 2009 | Refrigerators
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
82 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
