Question about Brookstone Pure-Ion UV Air Purifier
Stopped filtering dust...
I bought a Brookstone Pure-Ion UV about 6 months ago that was working wonderfully night and day. Recently I noticed that there is no dirt collecting on the cylinders. I pulled them out and vacuumed/wiped off a lot of dirt that was inside the unit. I paid careful attention to the contacts at the bottom that supply the voltage to the cylinders. I've run it overnight and still there is no dust/dirt stuck to the cylinders. The fan runs, the UV lights, and it sounds the same. What else can I try? I have a multimeter. Are there ways to can check voltages, shorts, or opens?
  • Mark Laney May 10, 2007
    Any ideas or similar experiences?
  • 41 Answers
I just got one from some one that wash trashing it because it quit. The problem with this one was a bad power regulating transistor. $1.69 at Radio Shack. I also found that the board that supplies the voltage to the grid had several bad solder joints on it. Take the bottom/stand off: four screws. Take the next 4 screws you see out then the bottom should come off. The small board next to the motor energizes the grids. The transistor on that board needed to be re solderd. Also the flimsy black wire was loose too. Hope this helps.
Posted on Feb 28, 2008
SOURCE:
How do i clean my Brookstone Pure-Ion Uv Air Purifier
[PDF]Pure-Ion® Pro - Brookstone
www.brookstone.com/webassets/pdf/630285p_manual.pdf
BrookstonePure-Ion® Pro. Air .... Use this unit only for its intended use as described in thismanual . 4 . .... Position the unit so the cleaner air flows to your desired location .
Aug 30, 2015 | Brookstone Pure-Ion UV Air Purifier
How remove and clean filters from Brookstone pure ion uv air purifier?
how to remove and clean filters for the Pureion UV air purifier?
May 21, 2010 | Brookstone Pure-Ion UV Air Purifier
Cleaning tips for my Brookstone Pure Ion
I have Bridge Stone Ionic Air Cleaner and I cant figure out how to take it a part to clean the filter. It's a few years old, used very little and I don't have a manual. Can anyone help. thanks
Nov 06, 2009 | Brookstone Pure-Ion UV Air Purifier
How to troubleshoot a Pure Ion #AP-75 non-working
My ionair cleaner doesn't clean the air what so ever. All four filters are perfectly clean after running for over two months. All of them are properly inserted and seated as specified. No filter warnings turn on and the unit works in all other ways. There is an ongoing fire in the hills nearby and our house if full of hazy smoke.
Aug 08, 2009 | Brookstone Pure-Ion UV Air Purifier
Brookstone pure ion filters
You need to reset it, unplug the unit and take out both filters. Then, plug it back and and simultaneously and firmly slam both filters into the back of it at the same time. Before putting both filters back inside the until, also vacuum out the insides in case there is hair/dust inside of it that has accumulated.
Also, make sure your filters are 100% dry before every putting them back inside the unit.
Mar 02, 2008 | Brookstone Pure-Ion UV Air Purifier
Pure ion uv light does not turn on
Where can I get a replacement ultraviolet germicidal lamp? I have been to Brookstone store and on line without help. My unit is a Pure Ion.
Thank you.
Dec 25, 2007 | Brookstone Pure-Ion UV Air Purifier
Manual for Oure Ion Advanced
the clean filter light will reset itself once the filter is completely clean. Try dust off the areas where the filter is inserted into as well.
Oct 30, 2007 | Brookstone Pure-Ion UV Air Purifier
Help! My air ilter quit!
I bought one a year ago and never thought it work well in cleaning the air. I get more dust on my counters than collects in the pure-ion. I recently got a letter from an attorney saying they are settling a class action suit on these purifiers because the are not effective. I called brookstone and they said they will refund my money because of the law suit. Good luck.
May 10, 2007 | Brookstone Pure-Ion UV Air Purifier
Brookstone Pure-Ion UV Air Purifier Logo
142 people viewed this question
Top Brookstone Air Purifiers Experts
senbukan
Level 1 Expert
ray gallant
ray gallant
Dennis Webber
Are you a Brookstone Air Purifier Expert? Answer questions, earn points and help others
